12-10-2017, 08:55 PM
#301
1991 34' Limited
Wichita
, Kansas
Originally Posted by subfan1
Yes I too found this thread helpful. Last week we sold our 08 Chevy Tahoe and we are waiting for our 18 GMC Sierra Denali to be delivered. I know there are some threads about covers for the bed, ours is a short box. I don't want a solid cover as I think I might use the bed to haul bulky stuff on occasion. Anyone here recommend anything?
Are all of you using premium fuel in your 6.2l engines?
I have used 87 octane for one tank as an evaluation and that worked fine. I wasn't towing and there was no audible knock. However, the power at brisk acceleration was less and I'm sure that the knock retard sensors were retarding the timing. I also felt like the gas mileage was less using 87 octane (I can only get 87 and 91 octane here in Wichita, KS. All the rest of the time, I've used 91 octane. This truck gets better mileage around town than my 2013 Jeep Grand Cherokee with the 5.7L Hemi, so I'm happy!
Steve
12-10-2017, 09:13 PM
#302
Oswego
I should add that my tests were with 87, 89, and 91 octane. Sometimes I find 93, but 91 is very fine for towing. It is important to use TopTier fuel, most especially for any and all direct injected engines.
-Rich-
12-13-2017, 07:25 PM
#303
2015 27' FB International
Montgomery
Report on Chevy/GMC 1500 with 6.2 engine and Max tow pack
In case anyone is interested, I recently ordered a 2018 GMC Sierra SLT 1500 Crew Cab, Standard Box, 6.2 / 8 speed, 4x4, Max Tow. I ended up changing my mind. The payload is 1850. The MSRP is 59,000. It’s currently being offered for 44,000 and some change. The vehicle is available at Beck and Masten North in Houston. Ask for Ariel.
Retirement! Every day's a Saturday and Monday's no longer exist!
12-13-2017, 08:37 PM
#304
2009 25' FB International
2018 27' Globetrotter
Tavares
Just curious as to why you changed your mind if you are will to share?
Thanks!
12-13-2017, 09:38 PM
#305
Montgomery
I have been driving a 2015 1500 SLT Crew Cab with max tow for the last Two years. Although I have 60,000 miles it has been the perfect TV. I decided that it made no sense to trade a vehicle that I have been perfectly happy with and is paid for. The increased horsepower and larger bed wasn’t worth starting over.
12-14-2017, 02:09 AM
#306
2018 27' International
Southeastern MI
, Michigan
60,000 miles is not even broken in yet. Good decision.
12-14-2017, 02:11 AM
#307
Southeastern MI
, Michigan
I've been using 87 in my Ford 6.2 forever. Runs just fine. Just turned 115,000 miles. I'm planning to get a new one at 250,000.
12-14-2017, 05:52 AM
#308
Oswego
Is it a high compression engine? Does Ford recommend premium, like the ecoboost?
-Rich-
12-14-2017, 06:35 AM
#309
Southeastern MI
, Michigan
87 minimum as far as I know. Our other car is an Ecoboost, gets regular too. Yes, both are high compression engines.
I've run 89 in my truck but after many tankfuls there is absolutely no difference in mileage or performance and 87 saves thousands of dollars a year as much as I drive.
12-14-2017, 08:30 AM
#310
Oswego
OK, I did a quick Google check, and I know some of these compression ratios do change periodically (like the 3.5 Ecoboost going from 10:1 to 10.5:1), but I would not consider the Ford 6.2L to be high compression ratio.
Ford 6.2L = 9.8:1
Ford 3.5 Ecoboost = 10.5:1 (of course a turbo)
GM 6.2L = 11.5:1
Thus the reason the Ford 6.2L recommends 87 octane, Ecoboost and GM 6.2L recommend premium.
-Rich-
12-14-2017, 09:11 AM
#311
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert
I didn’t know this thread existed.
The lease was up on my 2015 Silverado LT with the 5.3 and the max tow package. I traded it for a 2018 Sierra 1500 Denali 6.2. No max tow package or trailering mirrors available on the 1500 Denali. I bought the chrome trailering mirrors and will install them this weekend. The stock mirrors seem so small after using the big mirrors for the last 3 years.
I took about a 400lb hit on the payload but this truck rides much better. I only tow about 10% of the time so I’m fine with the softer suspension. My ‘71 Sovereign is lighter than the newer trailers so I’m okay there. I travel solo so I never use all the payload anyway. I only have 300 miles on the truck so far but this 6.2 has great power. It seems quieter but that may be the Denali trim level.
I bought a vinyl folding bed cover for the Silverado on Amazon. I think it was $220. It has great reviews and works fine. Now it sits on the 2018.
12-14-2017, 03:08 PM
#312
Southeastern MI
, Michigan
Ford 6.2L = 9.8:1
GM 6.2L = 11.5:1
9.8 is low, 10.5 is high? Hmmmm.... my old flathead was 7.5:1 so I guess it's all relative. Glad I don't have to pi$$ my money away on premium to get 20 more horsepower.
12-14-2017, 03:17 PM
#313
Oswego
10.5 is "moderate" in my book, but it is a turbo. Rules are different than naturally aspirated, as combustion pressures are much more highly variable.
Don't have to &*@! any money away. Can't speak for the Ecoboost, but the GM 6.2L gas experiment is listed in my post above. Premium is "recommended" per the owner manual, not required.
-Rich-
12-15-2017, 03:31 PM
#314
2019 23' International
La Habra
I don’t know if this was covered but, I’ll ask.
Do I have to connect any wires under the hood for battery charge capability? I’ll presume that the brake controller built in the dash is working and all I have to do is plug our Airstream and go? We will pick our truck up later today. They said it was in.
2019 GMC Sierra Denali
2019 23CB International
12-15-2017, 03:36 PM
#315
1991 34' Limited
Wichita
, Kansas
Your 7 pin connector should be fully operational upon delivery (including the trailer). You can backup to your trailer and try it out soon. You should drive 500 miles for normal break-in before towing.
Steve
12-15-2017, 03:41 PM
#316
1991 34' Limited
Wichita
, Kansas
Your 7 pin connector should be fully operational upon delivery (including the trailer brake controller). You can backup to your trailer and try it out soon. You should drive 500 miles for normal break-in before towing.
Steve
12-15-2017, 03:54 PM
#317
Vintage Kin
Fort Worth
Well, if you run Death Valley, a tow vehicle is better off with premium. Over Loveland Pass, it won’t matter. Any TV.
Prior to FI, about the maximum CR for a tow vehicle was a confirmed 8.75:1 with tight quench. Not what you’d find in a factory tow or truck motor, it would have been 7.5:1 or so what with the degradation of gasoline quality since the 1960s, not just lead removal and lower octane. 8.5:1 was about it for all but Corvettes and the like for a couple of decades.
A tow motor really is all about cylinder pressure. Maintenance thereof. It’s harder duty than racing. Spark control is everything above the mentioned CR numbers. Using premium hardly a burden for the lesser percentage of annual tow miles.
The last V8-440 I had (1990s) was tuned for premium by me. The extra mpg paid off as i ran it hotter than stock and with a faster advance curve. Plenty of details to have sorted to be able to do that.
When the computer de-rates engine power, fuel will be seen to have been cheap.
12-15-2017, 04:02 PM
#318
Southeastern MI
, Michigan
I run Detroit, not Death Valley. I need all the power I can get!
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
12-18-2017, 07:24 AM
#319
La Habra
We picked our truck up yesterday
[ATTACH]
12-18-2017, 08:12 AM
#320
1991 34' Limited
Wichita
, Kansas
Congratulations...It looks great! I strongly recomend that you add the GM Towing Mirrors.
Steve
