Old 02-19-2008, 01:19 PM   #1
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Reflections on 3/4 ton ownership
After owning our 2006 DuraMax/Allison through 2 tow seasons and getting ready for the third season, I started thinking about how upgrading to a ¾ ton chassis and diesel has effected us. If you are in the market for a TV,this information may help you decide.
If you have not seen my post about the evolution of our towing experience, you may be interested in how we got to this point; http://www.airforums.com/forums/f238...ice-28886.html
Some thoughts in random order;
  • It only took one trip to convince me, there is no doubt in my mind that towing with a ¾ ton chassis is the way to go.
  • It is not really about hp or torque (of course you would not want to be seriously under powered), but it is the frame, brakes, and suspension that really make the difference. For me, I was not going to a ¾ ton unless it was a diesel, but this is personal preference.
  • This is our first diesel, and despite some initial concerns about increased maintenance cost, availability of fuel, etc, none of this has proven to be true. Don’t get me wrong, I do not NEED a diesel, (no one does to tow an AS), and I am not 100% sold on diesel (maybe 99%-talk to me after 150k miles or so) but I am more and more convinced that diesel will be the fuel of choice in the future both for environmental reason and for economy. My Wife will be due for a new car soon, and it is likely that will be diesel.
  • The economy of diesel has proven true for us; 21 mpg unloaded on the highway. 14-15 locked and loaded (usually with several water toys on the roof of the truck=increased drag).I get a kick out of driving a full size truck and getting this kind of mpg! I was never able to get this kind of mpg with a small block ½ ton gas truck (Too bad diesel is not yet available in ½ ton, and then this would not be true!) so there is no argument for better mpg with ½ ton’s. If anyone can return this kind of economy with a gasser, please let the AS community know!
  • There has been no difference in the day to day experience versus a gas motor. None. Not cold weather, not finding fuel. Nothing. Just start it and go (the new glow plugs warm up in seconds).
  • Smell and noise? Not anymore, the new common rail injection has eliminated these concerns. Can you smell exhaust? Of course, but I don’t care to breath gasoline fumes any more than diesel fumes. Noise is a non issue, the old clatter traps are no more.
  • All of the big three make competent HD trucks, but boy, this D/A combo is a dream to tow with. (Let’s hope Ford’s new diesel fairs better than the last one-the new Ford HD’s are VERY sharp looking!)
  • Often the diesel pump at the fuel station is located separately, offering more room for big rigs, trailers etc, an added benefit!
  • Yes, the ride was harsher than a ½ ton, but once I smartened up and let some air out of the tires, when not towing, there is not much difference in ride quality. Some, but not much. (And the opposite is true when fully loaded-this is when the difference becomes crystal clear.)
  • I have owned and towed with probably 7 or 8 ½ ton vehicles prior to this truck, as long as I have something behind me, I will be in a ¾ ton truck from now on. A ½ ton vehicle is a compromise between truck and car like ride. A ¾ ton is purpose built; it is a tool, no compromise.
  • A ½ ton truck for light loads and shorter trailers (5000#, 23’) and limited tow miles (a couple of trips/year) does provide a nicer ride as a day to day vehicle. (The white knuckle experience of being fully loaded and driving for several hundred miles can quickly make you forget about a nice soft ride!) But again, you really need to reflect on just how much towing you will be doing each year. We knew we would be camping more and traveling further and this has proven to be a good move for us.
  • Traveling at close to max capacity, not knowing who is in control (trailer or truck?) does not make for good vacations.
  • I would never understand this if I had not experienced both.
In summary, for those of you entering the AS lifestyle and looking at TV’s, or those of you looking to replace a TV due to age, or a questionable experience with a lesser TV, I am convinced a ¾ ton is the way to go. I, and others here, feel that once you get over 25’ or 6000# or so, it is time to get in a ¾ ton. There is a reason those of us with ¾ ton trucks preach the experience; we have been there, done that. I will amend my previous recommendation and would now say; even if you are towing lighter than that, if you are full timing and/or towing significant miles each year, then you could not go wrong with a ¾ ton. If you fit any of the suggested parameters above, do yourself a favor, keep your family safe, save yourself some aggravation, some $ (there is no real cost difference between ½ ton and ¾ tons), and ask yourself how do see your Streaming a couple of years down the road? See more, do more, live more.
We have found no negatives in our ¾ ton experience.
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 02-19-2008, 01:39 PM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by BillTex
...(there is no real cost difference between ½ ton and ¾ tons)...
Bill
Really??!!!??! this must be something new, because when I bought my truck, the difference between it and an otherwise identically configured 3/4+deisel was $10,000.
TEN THOUSAND DOLLARS.
thats a lot....to me.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 02-19-2008, 01:40 PM   #3
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Smile Hi,
Dittos on the 3/4 ton. I have one with gas 350 Vortex. My new TV will be a duramax.
Regards from Russell in sunny and warm Tucson Az.
RUSSELL is offline   Reply With Quote
Old 02-19-2008, 01:46 PM   #4
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Bill, You make some valid points...but,
A couple of points where my thought diverge from yours....
1. I have never had a "white knuckle" experience. I just delivered a 29' A/S trailer to the midwest, I tow my 25' Safari all over with no problems.
2. I do feel that I am keeping my family safe. I see too much of the other to NOT consider this.
3. If I were to change one thing, it would be power, and diesel does provide that. Aside from that, I have experienced NO aggravation with the 1/2 ton.
4. Cost IS a factor.
A couple of years ago I had the opportunity to take a work related class in a remote area, and towed my Safari with the department owned late model F-250 Diesel. I was not overwhelmed with the difference.
For me, the 1/2 ton works out great. Most of my driving is without the trailer and this is what works for me.
If we all saw alike, there wouldn't be the "Big Three" now would there?
Dave
Fyrzowt is offline   Reply With Quote
Old 02-19-2008, 01:49 PM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
Proper rating is the key
Well said, BillTex.
Since I have owned (and put LOTS of miles on) all three weight ranges (1/2. 3/4, and 1 ton trucks) I can attest to the importance of matching the manufacturers rating to the load you want to tow and/or haul.
You might be able to "get by" for a while by undersizing, but when it comes to comfort, ease of towing, and safety there is no substitution for a properly rated Tow Vehicle.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 02-19-2008, 02:45 PM   #6
myboyburt's Avatar
1993 25' Excella
Full Time , Anywhere USA
Images: 12
Leon and I are in the market for a new tow vehicle right now and have found the difference in price between a 1/2 gas and a 3/4 deisel is $10,000.
It's a big jump in price for us too but we will be going for the 3/4 deisel.
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 02-19-2008, 02:52 PM   #7
1 Rivet Short
1989 25' Excella
Chuck; Gas for gas (the original post did not say gas vs diesel-it says "1/2 ton vs 3/4 ton), the difference would be minimal.
Obviously, there is a premium to get into a diesel.
Bill
Old 02-19-2008, 03:08 PM   #8
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I believe he was talking about gasser to gasser...at least that's how I read it. I read that he preferred diesel, but the minimal cost difference between a 1/2 ton to 3/4 ton is fairly accurate, unless you opt for the diesel.
Incidentally, only a fool pays the full ticket on the diesel upgrade. It's like buying an Airstream....you have to use your horse trading skills. If not, and you don't mind, you pay full boat. $10k is sticker.
Old 02-19-2008, 04:03 PM   #9
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I specifically remember the breakdown, and it was about 5K for the 3/4 ton, and another 5k for the deisel itself. Both significant numbers, imo. certainly not "minimal".
and I used to sell 'em...I know what the markup is. it ain't that much.
now...if you happen to be one of those "airstream millionaires"...well, then sure. 90g's for the new 34' classic, + another 60 or so for the luxury SUV...what's a few grand extra for a deisel? chump change.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 02-19-2008, 04:17 PM   #10
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
Ditto and a diesel fuel question
Bill,
For all the reasons you mention, we LOVE our 3/4 2008 HD Ford with the diesel engine. I am constantly looking in the rearview mirror to see if the AS is still attached. Even going up hills, the tranny doesn't kick down very often. Aside from power it brake, handles, and stops so very calmly. I ALWAYS feel like the driver is in charge and we NEVER feel the least bit worried that we are overdriving or overtowing our rig. On the downside, diesel fuel is $0.20 more a gallon than premium right now. That hurts but the increase in miles per gallon makes up the difference in cost.
As an aside, can anyone tell me why diesel should ever cost more than gas? When we bought our truck last April, diesel was $0.20 LESS than regular.
altamont is offline   Reply With Quote
Old 02-19-2008, 04:49 PM   #11
Fyrzowt's Avatar
Images: 8
I've wondered the same, since it doesn't have to go through as much refining.
I can only figure market pressures as more folks go diesel.
Old 02-19-2008, 05:19 PM   #12
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Santa Fe , New Mexico
When we had our 22' International, we towed it with an F250 V10 gas. Worked fine - could hardly tell it was there, even though you could see the gas gauge slowly creeping south...
Got the 30' Classic and we could sure tell it was there and the gas gauge wasn't creeping slowly anymore...! More like it was playin' chicken with me all the way to the gas station. Traded the V10 in for a F250 Turbodiesel. World of difference! Wouldn't go back. The 250/diesel makes for a much less strenuous towing experience, get up & go is much better as well as the mileage...
Wouldn't even consider towing the 30' with a 150. My old one was great with the Coleman pop-up. Handled that like my 250 handles the Classic!
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 02-19-2008, 05:58 PM   #13
Key Biscayne , Florida
I'm still just trying to come up the learning curve here and certainly don't want to get in the middle of the always contentious debate between 1/2 and 3/4 ton pickups.
However, if you're convinced you want to go with 3/4 ton or larger diesel and are looking for a deal, I've noticed that Dodge seems to have a very large number of 2007 leftover Ram 2500 and 3500 trucks with the Cummins 6.7 litre diesel engine...at least here where I live in South Florida. One dealer is even advertising up to $14,000 off of the list price of their trucks, depending on model. This still doesn't make it cheap, but you could get a brand new diesel Ram 3500 for less than $30k. Please note that I have no opinion on Ford vs Chevy vs Dodge, nor do I work for Dodge. I just thought this information might be useful to those who may be in the market for a new TV.
Bonzai30b is offline   Reply With Quote
Old 02-19-2008, 06:13 PM   #14
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin , 28734
Duramax
I upgraded from a ford f150 to a Duramax 2500 HD and it was the best thing I have done. Besides the Airstream 27 ft. I pull a small backhoe and tractor at times also I have a dump trailer I haule dirt and stone in. The problem with a lite truck is it will not stop a heavy load. I shopped around and found a used Duramax with 45,000 miles on it and saved about 15,000 dollars over a new one. It now has over 100,000 miles on it with no problems. My work car is a VW bettle with a TDI diesel it gets 50mpg. I also think you are going to see a lot more diesels 2010 Ford and Chevy are putting V6 diesels in all of the 1/2 ton trucks and SUV's.
Ramp is offline   Reply With Quote
Old 02-19-2008, 06:38 PM   #15
1 Rivet Short
1989 25' Excella
Chuck, let's take "one for instance" a 5.6l F150 and a 5.5l F250, depending on how they are packaged, would have an awful lot of overlap (let's not get into every Mfr and every model-this would result in hundreds of price points...) but the point is; if you were getting ready to lay out some cash (let's keep it low by todays numbers) and say you were going to drop $30G on a new truck, this could get you either a F150 or F250.Very easily. If you're objective is towing, then the decision should be easy.
If you were selling trucks, couldn't you have arranged a better deal? For yourself?
The real price differential, when we bought the D/A versus a gasser was between $3-$4k. And I saw this at several dealers, after looking at dozens of trucks and invoices...and I didn't know anyone at these dealers.
Anyway, while I am very happy with the diesel so far, the point of the post was the advantage of 3/4 tonners vs 1/2 tonners, not diesel vs. gas. As noted, even 1/2 ton's have enough juice to move any AS out there. It is the platform, not the engines, that makes the difference.
Bill
Old 02-19-2008, 06:54 PM   #16
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Easy Rider
Two cents from the "girlie" side of the fence.
I traded a 2003 3/4 ton gasser Suburban for a 2008 3/4 ton diesel Silverado around Thanksgiving. (I traded in the Lexus too, so the big quad cab-long bed IS my daily driver.)
I get happier every week. Got 11-15 mpg not towing on the Burb. Got a dismal 9-12 mpg towing. The new diesel Silverado started out getting 13 mpg either towing or not. I'm still in the break-in phase, and my non-towing mileage last week was 18.3 mpg! Even with the higher price of diesel, I'm making out like a bandit. Everything the original post said about quiet ride, huge breaks, and powerful transmission, is true (but I do have to turn off the engine at Starbucks or my order gets messed up).
Since the 2007 and 2008 models require ultra-low-sulpher fuel I do have to watch out when refilling, but I've found several places close to home and on the road, a Shell or Citgo that sells diesel is almost is usually easy to find. The big truck stops will come over to ULS sooner or later, then I'll be in hog heaven.
Happy Trails, Paula
Old 02-19-2008, 07:19 PM   #17
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I'm for the 3/4 ton, that's a given. Our TV is an '05 2500 Suburban 4x4x4. What I am unsure of is the diesel factor. We pull the Airstream extensively. Just about everywhere we go there is always a line at the diesel pump. The diesel is generally 30-40 cents more per gallon. The Duramax option on a GM pick-up is curretnly $7,500.00. Even with the 40-50% better mpg, the cost per mile factor is not much different than a gasser.
I have gone back and forth over this issue for the last year. I am now back at gas. The gas Sub pulls great in all situations. I just don't know if the diesel is worth the hassel.
Convince me otherwise.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 02-19-2008, 07:22 PM   #18
Aluminut
2004 25' Safari
. , Illinois
Again, simply false (except for the diesel, which does add significant retail costs to the packages, but are NOT availible in 1/2 ton anyway, so we are NOT comparing apples to apples:
Straight off the Chevy site, same base 4x4 LTZ extended cab long bed and mind you, these are retail numbers, your horse trading skills may yield better:
3/4 ton
2008 Silverado 2500HD Ext. Cab Long Box LTZ
Extended Cab Long Box
4x4 Drive
MSRP:$39,585.00Colors & Options: $0.00Total MSRP*:$39,585.00Current Offers:- $2,250.00Net Price:$37,335.00
1/2 ton
2008 Silverado 1500 Ext. Cab Long Box LTZ
4x4 Drive
MSRP:$36,540.00Colors & Options: $0.00Total MSRP*:$36,540.00Current Offers:- $3,000.00Net Price:$33,540.00
Difference $3795 to upgrade to a 3/4 ton (non diesel- before horse trading)
That's $3795 for better engine, better trans, better hubs, better rear axle, better suspension........seems both reasonable and minimal to me.
Old 02-19-2008, 07:24 PM   #19
altamont's Avatar
Tracy , California
One word: torque!
Old 02-19-2008, 07:28 PM   #20
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Brian
I'm not selling either one but when we had to get a new truck the F250 PSD got real affordable at %1 financing.
After getting the PSD I can tell you hills may as well be flat ground to the PSD.
Fuel is easy and the only long line experience I've had is in Barstow, Ca.
Wait til the 4X4X4 either dies or the big 3 are making "deals of a lifetime" to unload unsold units.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
1/2 ton vs 3/4 ton towing? subfan1 Tow Vehicles 7 12-13-2007 04:10 PM
When do I get my cert. of ownership? marta5 Title, VIN & Registration 1 12-11-2007 05:01 PM
Big 3 1/2 Ton vs 3/4 Ton Trucks Streamer1 Tow Vehicles 40 11-20-2007 11:13 PM
The anticipation of Ownership! Moonstruck Member Introductions 7 12-08-2006 12:56 AM
