Old 09-01-2008, 08:43 AM   #1
2009 28' Flying Cloud
Bainbridge Island , Washington
Reese WD Hitch Question
I'm driving to CA to pick up a new 28' Flying Cloud this week and will be getting a new Reese WD Hitch (and possibly brake controller) at the same time. My question has to do with what I've been reading about "ASs liking soft rides". I've got a 2002 RAM 2500 which is pretty stiff so does that mean I should consider undersized trunnion bars?
Also, my truck has an older brake controller in it, are today's versions better (suggesting I should swap to something new to gain anything?)
usa448 is offline   Reply With Quote
Old 09-01-2008, 09:32 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I have a 3/4 ton Suburban and started with the 1200lb bars. Went down to 800lb bars and was a significant improvement. I have a 25er, so my hitch weight is slightly less than yours, and I went down to 600lb bars which were even a greater improvement than the 800lb bars.
I would suggest a max bar rating of 800lbs and you too might also still get some good benefit from the 600s as well over the 800s. I would also suggest the dual cam for that unit. I love mine. Also the Prodigy is a great brake controller.
One other thought is that if you buy the 800s new, you can typically pick up a set of used bars off eBay fairly inexpensively to try the less firm bars. The trick is finding them when they are out there.
Old 09-01-2008, 09:36 AM   #3
I would suggest a Reese dual cam 600 hitch, no more, since you have a Queen Mary tow vehicle.
Please report back your experiences.
Old 09-01-2008, 10:09 AM   #4
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
All I've read suggest that when you use a 3/4 ton tow vehicle you should downsize your WD bars when using the Reese Hitch. But I have an Equal-i-zer so I'm definitely no expert on the Reese Hitch.
Family of Disney Fanatics
WBCCI# 4821
Old 09-01-2008, 10:10 AM   #5
Thanks for the advice. I am going to go with the Reese Dual Cam.
Any downside to using the 600lb bars?
Old 09-01-2008, 10:15 AM   #6
None.
Old 09-01-2008, 10:45 AM   #7
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Agree, also Rvwholesales has the brake control for $90
'77 Sovereign Intl 31' CB
Old 09-01-2008, 03:48 PM   #8
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I dropped to light bars also when I changed from 1/2 ton to 3/4 ton tow vehicle. I did it because the heavier trucks suspension rides better with a load. I found out by accident the rest. My own trial and error. It just so happened I had a couple of sets of bars. Years ago with my family ect. I worried about breaking a bar (1/2 ton truck days) I bought used stuff at the WBCCI garage sale at the international rallies, for spares. ( I rolled at night while kids where sleeping) It almost is crazy when this unit I have only drops the rear 1/2 inch to maybe 1 inch but I have been in to many steering wheel slide situations (snowplow) In a semi because of bad loads.
So I use them ( light torsion bars)
mustang is offline   Reply With Quote
Old 09-01-2008, 08:02 PM   #9
A light film of grease, on the dual cams, will stop the creaking.
Old 09-01-2008, 08:13 PM   #10
Refurbished 89 Excella
DKDarrow's Avatar
Sugar Valley , Georgia
Does this same principle apply to Draw Tight hitches???...........thanks......Dennis
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
DKDarrow is offline   Reply With Quote
Old 09-01-2008, 08:54 PM   #11
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Thanks Andy. I kinda have grown attached to the creek.
Adjusting my Reese Hitch wagnerda Hitches, Couplers & Balls 11 10-28-2007 09:53 AM
Reese Hitch issue Tin Hut Hitches, Couplers & Balls 1 01-10-2006 04:07 PM
Reese Hitch Problems jfowler218 Hitches, Couplers & Balls 17 12-22-2005 01:53 PM
Reese hitch dlorahcof Hitches, Couplers & Balls 3 09-13-2003 04:11 PM
