01-22-2018, 02:25 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
Rear Gear Ratio & RPM's
I have a RAM 1500 with a 5.7 hemi, 8 speed and 3.55 rear.
At 60 MPH on level ground the RPM's are about 1500. If I had the same engine with the same transmission how much higher would the RPM's be with a 3.92 rear?
Is this difficult to calculate?
Thanks!
01-22-2018, 02:41 PM
2018 27' International
Southeastern MI
, Michigan
The ratio of the two rear ends, multiplied by the original engine speed, gives 1656 rpm. (3.92/3.55)*1500
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
01-22-2018, 04:13 PM
Tavares
Is it really that simple?
2018 27' FBT Globetrotter
2019 RAM Limited 2500 w/6.7 diesel
BRN 22721
01-22-2018, 08:30 PM
2016 30' International
Florence
, Alabama
Yep. A higher ratio means higher RPM for the same speed, but more torque as well.
So the simplest answer to your question is to compare the two ratios.
01-23-2018, 11:10 AM
Lynn
Beaverton
, Oregon
Hi there, on a different note, I have an 08' ram hemi, 5 speed trans with a 3.92 rearend averaging 13 MPG pulling a 25' AS in and around the high desert. Thinking about upgrading to a new dodge with the 8 speed trans, hemi. Not sure to stay with the 3.92 or going with the 3.55. What average mileage are you currently getting?
Lynn
01-23-2018, 11:33 AM
2017 19' International
Tallahassee
A ratio question ... if towing with Ford’s 10-speed automatic transmission, is careful selection of the rear-end ratio important?
With 10 gears to choose from, it might be easy to work out an effective final drive ratio, no matter what’s spinning in the rear end.
01-23-2018, 11:45 AM
Tavares
Lynn
I currently am pulling a 25' AS with my RAM 1500. I have the 3.55 and am thinking of going to 3.92. That's why I asked the question about RPM's. I currently average 11.5-12.5. Now that includes hilly country (not mountains but what is common in the east). When running on level ground I can average 13.0.
The 2019 RAM 1500 has new tow package that specs a 3.92 rear. It's too early to get a MPG rating but they expect it to be better. The tow package also includes the new e-torque hybrid system.
01-23-2018, 03:01 PM
2014 25' FB Flying Cloud
Des Peres
, Missouri
I would wait for the 2019 Ram
It will have 2500 lb load capacity and 12,700 towing with the hemi
They are trying to bridge the gap between 1500's and 2500's
01-23-2018, 04:23 PM
1976 31' Sovereign
CLAYTON
, Georgia
You must have skipped basic math in grade school!!
01-23-2018, 05:43 PM
2017 28' International
Jim Falls
, Wisconsin
That new Ram will be interesting to see how it specs out. Any idea when it is supposed to be in production?
01-23-2018, 05:50 PM
Tavares
It just so happens that I stopped at a dealership today and asked that same question. I was told that limited production has already started. The salesman said they expect to have a few by the end of Feb. Of course this is a salesman talking!
BRN 22721
01-23-2018, 05:53 PM
Tavares
I skipped a lot of things in grade school! Thanks for pointing out one of them!
BRN 22721
01-23-2018, 09:42 PM
Jim Falls
, Wisconsin
There you go. I have a 2017 Ford Ecoboost so I won’t be ready for a pickup for at least 2 or 3 years. That will give plenty of time to see if this new RAM has some significant bugs and what people think about it as a TV.
