Old 02-27-2010, 06:12 AM   #29
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
but the dealers suck....
at least in this instance....jiffy lube has stepped up to the plate big time and paying for the entire repair ...which is approaching $3000 US Dollars...I guess i will buy my own supply of this lubricant...at $40.00 a quart....
kingfisher24 is offline   Reply With Quote
Old 02-27-2010, 06:56 AM   #30
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
''but the dealers suck....."
I resemble that remark, granted some do, whether Airstream or Auto.
But like a lot of things today competition is changing the market.
I worked at some marginal ones, it didn't take long to realize that fact and move on. Take a look at the service shop, in most cases the cleaner more organized the shop the better experience. PRIDE
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-18-2010, 09:44 AM   #31
1965 22' Safari
Richland Hills , Texas
Most dealers don't even know there is a special lube P/N. When I went to the dealer for the groaning noise they wanted to replace my rear brakes. I did my own research and ran across a QS forum and found people had the same noise. From what I have found, the so called "special lube" @ $45/qt is just nothing but synthetic lube w/ an additive for the limited slip already added in it.
Quadrasteers have different style lockers than all other GM trucks (remember QS trucks have Dana 60 center sections not the more common 14 bolt). The lockers in QS trucks are an auburn clutch pack style, the reason for the need of the additive just like the old posi-tracks from years past.
TexasSafari is offline   Reply With Quote
Old 04-19-2010, 11:04 AM   #32
1970 31' Sovereign
danville , California
It sounds like the same problem my old man had is in f350, did a rear end service with 75-140 red line full synth that had the fiction modifier, he drove it mybe 200 miles and the tires were cherping constantly, I told him he probably needed to add the friction modifier and after some convensing he did and the noise went away.
So mybe a rear end service is in yoru future just make sure to use the right oil and possible modifiers.
gmwelder86 is offline   Reply With Quote
Rear Bed or Rear Bath photocodo Sinks, Showers & Toilets 1 11-23-2009 05:17 PM
Problem area in rear of 1964 Tradewind fatwgn Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 08-29-2009 08:36 AM
Temperature Differential Expected JimGolden Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-28-2005 10:48 AM
Battery problem or converter problem Paul Daugherty Airstream Motorhome Forums 31 07-01-2003 06:16 PM
split differential or locking differential cindy foxx Tow Vehicles 6 01-22-2003 07:48 PM
