Old 07-18-2003, 06:33 AM   #1
qqq
qqq's Avatar
Rancho shocks setting
I have Ranchos on my Chevy PU, I tow with ball only, should I leave them on 5 (maximum)
Hart
qqq is offline   Reply With Quote
Old 07-19-2003, 05:12 AM   #2
qqq
qqq's Avatar
Maybe I should reformulate my question: is it better to have a very stiff & bouncy rear end (of truck) or is it better to have a softer setting
Hart
Old 07-19-2003, 10:47 AM   #3
The stiffer the ride, the more you punish the front end, especially if the trailer running gear is not balanced correctly.
Rivet heads at the front hold down plate area, would be the first to show signs of a stiff rear end suspension on the tow vehicle.
Old 07-19-2003, 11:14 AM   #4
Chas's Avatar
Images: 22
Why do you need them?
I had the Rancho adjustables on my 3/4 ton truck and had them set on the firm when I was in my slide-in truck camper phase. They were ok but the airbags made the biggest difference. I have since taken them all off and went with KYB non-adjustable gas shocks and no air bags or overload springs. My camper weighed around 3,000 lbs., thus the need for them. I doubt if you would need them just to pull an Airstream. If you want to keep them I would leave them on the 2 or 3 setting.
Chas
Chas is offline   Reply With Quote
X-Ref on shocks? RonJudi Mechanics Corner - Engines, Transmission & More... 4 03-18-2004 07:02 AM
What shocks? Silver Annie Shocks 6 11-03-2002 11:14 PM
Shocks for a 68 Avion T-22 Dual Axle? 68 Suburban Shocks 1 10-18-2002 12:45 AM
ProComp Explorer Shocks BobbyW Shocks 0 09-25-2002 08:16 PM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 10:13 AM
