Old 11-22-2015, 12:50 PM   #1
Plan-B's Avatar
2016 26' Flying Cloud
2016 25' Flying Cloud
1997 21' Excella
Watervliet , Michigan
RAM Exhaust Brake Tips
I will be ordering a 2016 RAM 2500 with a Cummins soon. I have owned multiple Ford Powerstrokes, none had true 'engine braking'.
I am looking for any advice; does/don'ts and tips/tricks you might have to offer on the newer RAMs with regards to their 'engine braking' setup pulling my AS. Also any experience between using the standard exhaust brake setting vs. the 'Smart' exhaust brake setting would be appreciated.
PS: I spend most the travel season in the mountainous roads out west.
Greg
2016 RAM 2500 6.7L Cummins, 4WD, Crew, Rear Air
Plan-B is offline   Reply With Quote
Old 11-22-2015, 01:00 PM   #2
2016 30' Flying Cloud
Oviedo , Florida
The auto mode attempts to maintain speed when you take your foot off the accelerator, the regular mode slows the truck down as much as possible. I use auto.
The truck will recall the exhaust brake setting when a trailer is connected.
Don't use the exhaust brake when the roads are slick
The exhaust brake doesn't work below about 1000-1200 RPM, so you may have to manually downshift at slow speeds for it to engage.
It seems more aggressive when tow/haul mode is engaged.
Keith
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
khollister is offline   Reply With Quote
Old 11-22-2015, 02:16 PM   #3
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Use the auto mode with Tow/Haul engaged. You'll love it.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 11-22-2015, 02:25 PM   #4
BAB
BAB's Avatar
2015 30' Classic
Greensboro , North Carolina
Like the other folks who have posted, I use the "Auto" setting. You are really going to appreciate this feature of the 2500HD. I've towed through plenty of mountains and it's pretty amazing how infrequently you have to use the service brakes. The "hold back" power of exhaust braking system AND the 800 plus pounds of torque make going down AND up major grades a piece of cake. I have 33,000 miles on my '14 Ram...30,000 towing. I'd also add that my truck has averaged 13.8 MPG while towing.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 11-22-2015, 02:41 PM   #5
Plan-B's Avatar
1997 21' Excella
Really appreciate your input everyone. . Can't wait to order.
Greg
Old 11-22-2015, 03:41 PM   #6
interstateflyer's Avatar
2017 25' International
Los Osos , California
Keith
Keith. Why not use the exhaust brake when the roads are slick?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 11-22-2015, 03:51 PM   #7
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Marietta , Georgia
... Why not use the exhaust brake when the roads are slick?...
For the same reason you don't use cruise control, traction! Either system can become a problem when wheel speed does not match asphalt speed. The exhaust brake does interface with the antilock feature of your brake system.
SeeMore is offline   Reply With Quote
Old 11-22-2015, 04:00 PM   #8
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
With our 2012 Ram 2500HD Cummins, I hardly need the mechanical brakes as the engine can control our 19,200 pound rig down mountain with no problem.
Old 11-22-2015, 04:03 PM   #9
How does an "anti-spin" differential play into this?
Old 11-22-2015, 04:35 PM   #10
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Like BAB, I love mine. We have traveled US421 from I-77 to Deep Gap, NC while towing and not towing with my F-150. Even when not towing, with the F150 I had to downshift and/or use the brakes going down the 6-mile 8% grade near the Blue Ridge Parkway. Towing with the 2013 Ram I had only to tap the brakes for a few seconds once at the steepest part. And going up? Wow!
Over on the Turbo Diesel Forum, many are in favor of driving all the time with Tow-Haul and Auto Exhaust Brake engaged, claiming it keeps the turbo vanes clearer of carbon. I don't do it all the time, and I suspect if may cost mpg when on the highway and not towing, but I do it sometimes. As stated, be ready for the exhaust brake to cut out at slow speed. In traffic you'll have to get on the brake more when you are coming to a stop.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 11-23-2015, 11:45 AM   #11
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Same here - Tow/Haul on with Exhaust Brake on Automatic mode. Works like a charm.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2017 Canopenian
Alphonse is offline   Reply With Quote
Old 11-23-2015, 12:00 PM   #12
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Another thing you'll appreciate is the longer brake life. My 2003 Dodge/Cummins just turned over 114,000 miles, of which over 100,000 of that has been towing. It still has the original brake pads.
The exhause brake wasn't offered by Dodge for the stick shift at that time, so I installed a Gear Vendors system.
For whatever it's worth.
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 11-23-2015, 12:25 PM   #13
Echelon73's Avatar
2010 30' Flying Cloud
Mocksville , North Carolina
I would mirror what others say about the "auto" setting of the exhaust brake. The RAM Cummins really does not have an engine brake though. If you want true engine braking as well then check out the Pacbrake Loadleash. I found it a few weeks ago while looking for some parts. Here is a link: Pacbrake Loadleash Engine Brake | Dodge 6.7L
Echelon73 is offline   Reply With Quote
Old 11-23-2015, 03:25 PM   #14
Plan-B's Avatar
1997 21' Excella
Good point. Thanks for making that clear. These darn auto manufactures have people like me using terms that are not accurate.
Greg
Cummins Exhaust Brake Troubles nwclassic Towing, Tow Vehicles & Hitches 4 06-25-2015 05:12 PM
Seeking 2015 Super Duty Exhaust Brake Feedback burnsdl Tow Vehicles 7 10-16-2014 12:18 AM
Reprogramming the exhaust brake Tony Lee Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 04-06-2014 11:02 PM
Exhaust Brake Stopped Working? JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 6 04-03-2013 04:03 PM
Banks exhaust brake for Dodge Ram wflorencejr On The Road... 9 10-15-2005 09:26 PM
