Old 04-17-2015, 08:11 PM   #1
NoNameinNM's Avatar
2016 28' International
Albuquerque , New Mexico
Ram 2500 Auto Level Rear Air Suspension
We are planning to order a Ram 2500 turbo diesel (with that beautiful RamBox option) for our International Signature 28.
We are wondering if anyone who has purchased or driven one with the "auto level rear air suspension" option can answer a few questions.
When not towing, does the ride differ noticeably from a Ram 2500 not equipped with that option?
How do you like it when towing your Airstream? Is it wonderful? Is it overkill? Any experiences/tips to share?
We are planning on the ProPride hitch, if that makes a difference.
Jamey
NoNameinNM is offline   Reply With Quote
Old 04-17-2015, 08:51 PM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Those RamBoxes may preclude installing a camper top to protect and secure gear in the bed of the truck.
I installed the complete Kelderman level ride air suspension system at their factory in Iowa. The truck now sits level regardless of the load in the bed or the trailer being attached. It softened the ride tremendously when the truck is unloaded. My 2012 2500HD diesel came with Michelin LT265/70R17E tires and the manual suggested 45 psi in the rear tires when empty and 70 when loaded. I run the fronts at 70 and the rears at 80 when towing.
We also use the ProPride hitch when towing the new Classic that has a 10,000 pound GVW.
Old 04-17-2015, 09:08 PM   #3
NoNameinNM's Avatar
I installed the complete Kelderman level ride air suspension system. The truck now sits level regardless of the load in the bed or the trailer being attached. It softened the ride tremendously when the truck is unloaded. My 2012 2500HD diesel came with Michelin LT265/70R17E tires and the manual suggested 45 psi in the rear tires when empty and 70 when loaded. I run the fronts at 70 and the rears at 80 when towing.
We were always planning on a tonneau cover, so that's not a worry. I test drove a certified used one with a shell and wasn't crazy about it. I'm 5'2" on a good day and while my husband is 6'2", he's got a bad knee-- so we'll never even be in that truck bed without a ladder anyway. I can reach all the way down into the RamBox, though, so that will help us keep many of the essential items needed when the Airstream is in tow.
It's very helpful to know that the air suspension system you installed aftermarket softened the ride.
Out of curiosity, does the air suspension make the ride in your truck feel more stable? The 2012 we test drove felt like we were going to roll over at any moment when changing lanes or turning corners (I don't know if it was the leaf springs or something else). The newer models we've driven don't sway/roll anywhere near as much.
Old 04-17-2015, 09:14 PM   #4
switz's Avatar
2014 31' Classic
Images: 8
We tend to leave the gear in the truck as it is not a daily driver. Thus we are always at or just above 8,000 pounds. So the ride is firmer and more stable. We have upgraded all the steering gear and that helps with the vague steering. It will never drive like a sports car. And the 4x4 option raises the CG too.
Old 04-17-2015, 09:22 PM   #5
NoNameinNM's Avatar
Thanks-- that helps!
This will be a daily driver, so anything that makes that ride more stable is fine by me.
I should have thought to ask these questions while the certified pre-owned 2012 was still on the lot, because it was in impeccable condition!
Old 04-17-2015, 10:52 PM   #6
Boxite's Avatar
2008 22' Sport
Not a 2500...I have a 1500, and the Rambox option is fantastic. I installed a BakFlip F1 hard tonneau cover and it doesn't allow even a DROP of water despite heavy rains and pressure car washes. I keep a 3 gal hot dog compressor in one side and it provides plenty of 100 psi air for tires and tools from a 400 watt inverter.
I like the Triaxon tailgate ladder but wanted heavier construction so made my own out of 1" sq. tubing. It's perfect for getting in/out of the bed for old folks like us!
http://www.amazon.com/Traxion-5-100-.../dp/B003VDX5D2
Sounds like you have a good plan, but you might wish to visit Inland RV's website to see Andy's comments about rear auto levelling systems when towing.
Old 04-17-2015, 11:45 PM   #7
daveswenson's Avatar
2012 28' International
Issaquah , Washington
I have the 2500 with the air suspension. I can't compare it to the non air suspension model because this is the only one I've driven. But compared to 3/4 ton Fords I've driven this is a much more comfortable ride. Plus it's nice hooking up the trailer and then watching the back of the truck level up.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 04-18-2015, 05:41 AM   #8
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Exactly the same for me. My only concern is that I have no idea if the camper is level because the air ride adjusts the height, so how it looks sitting still in park might not match actual setup in drive. I guess my concern is that I don't know what logic it's following.
I got out and looked at it when we pulled into one campground and watched as the air ride adjusted it even then. So I don't know if it's truly level when underway.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 04-18-2015, 06:14 AM   #9
BAB
BAB's Avatar
2015 30' Classic
Greensboro , North Carolina
I have the Ramboxes on my '14 and they are just awesome for trailer-towing. I have spaces for everything from a fire extinguisher to hitch tools, chocks, etc. BTW, I have a Bedlocker tonneau cover....push a button and the aluminum louvered slats roll up and back. Not many people order the Rambox option due to the expense, but if you pull a trailer, they are WAY slick. You will love your new truck....the Cummins is unstoppable in the mountains (going up with the turbo diesel, and down with the exhaust braking systems).
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 04-19-2015, 12:35 AM   #10
NoNameinNM's Avatar
Thanks for the input, everyone. We ordered the truck today. After some additional research we decided against the auto level rear air suspension, knowing that there are aftermarket options if we should eventually decide we would be better off with it. It's odd how these things come together sometimes--- after months of study and visits to see and test drive Ford, Ram, and GMC/Chevrolet, we decided on the Ram 2500 in early January and had pretty much determined everything we wanted within a few days save for this one option!
Boxite and BAB-- those are two of the tonneau covers we've been considering. Sooner or later we're going to have to make up our minds.
Old 04-30-2015, 03:44 PM   #11
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
If you did have air suspension would that negate the need for a wd hitch?
Old 04-30-2015, 03:47 PM   #12
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I would think not. The air suspension would raise the back end, but do nothing for transferring weight to the front axle.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 05-01-2015, 12:48 AM   #13
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Not to hijack, but I use the heck out of the Rambox's on my truck. I simply cannot imagine a vehicle without it now.
And YES to the above, you'd still need a WD hitch.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 05-01-2015, 03:04 PM   #14
2015 30' Classic
Pleasanton , California
I'm towing a 30' classic with the pro pride hitch, RAM 2500 w/Cummings engine, auto-leveling rear suspension and it's great! You'll love it!
I also have the RAM boxes and a RollX cover - both highly recommended. All in all it's a pleasure to drive, with and without the trailer and I have no worries when pulling the trailer.
Enjoy!
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
2014 Dodge 2500 rear suspension change crispyboy Tow Vehicles 0 07-03-2013 06:14 AM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
2010 Ram 1500 Suspension AirHeadRik Tow Vehicles 10 12-07-2010 05:15 PM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
Will 2000 Dodge RAM 2500 with Cummins 5.9L tow A/S well? idahosafari Tow Vehicles 23 03-11-2004 02:34 PM
