Prev Previous Post   Next Post Next
Old 10-19-2003, 01:19 PM   #1
joshua32064's Avatar
Profile:
Question regarding GVWR
I have a question regarding GVWR. Let's say that you purchase a trailer that has a factory weight of 5,745 pounds and has an additional allowable weight of 1,555 pounds. From my understanding, the GVWR would be 7,300 pounds.
Let's say you purchase a trailer that has a GVWR of 7,300 pounds. From everything that I have read on the forum, your tow vehicle should really be capable of pulling 9,000 pounds.
Here is my question. What if your tow vehicle isn't capable of pulling 9,000 pounds but only 7,700 pounds shall we say. As long as you don't put 1,555 pounds of extra things in the trailer, shouldn't you be OK? From what I have read, if we know that fluids, gasses, etc., will weigh approximately 600 pounds. Wouldn't someone with a 7,700 tow capacity be capable of pulling a 28' trailer as long as they did not bring a TON of stuff? 5,745 pounds plus 600 pounds is only 6,345. That's also assuming that you would always have your trailer fully loaded with fluids, etc.
Is it cutting it to close? I look forward to your answers.
joshua32064 is offline   Reply With Quote
Tri Axle Question HowieE Axles 30 10-27-2004 09:44 PM
Oil in Generator Question flyfisher Generators & Solar Power 4 12-29-2003 04:50 PM
Rust Question drober05 Airstream Motorhome Forums 6 10-05-2003 03:09 PM
wheel chair setup in GVWR bob.rita Tow Vehicles 4 08-02-2003 12:18 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 06:01 AM
