Old 12-22-2007, 08:31 PM   #1
Profile:  Currently Looking...
Aurora , North Carolina
Question on Towing???
I would like to know if anyone is towing a 30' S/O Classic with a 2007 Toyota Tundra w/5.7 engine; 381 HP, 401 FP torque. I am considering this but would like input from someone who is towing.
World Travel is offline   Reply With Quote
Old 12-22-2007, 11:15 PM   #2
2airishuman's Avatar
Profile:
hi world travel and welcome to the forums!
there are a few folks towing 30/slide units here...
most are using true 3/4 ton tow vehicles....
the tundra has a payload rating of approximately 1500-1600 lbs right?
well the tongue mass on a 30 slide is one of the heaviest made....
and will EAT ALL of the available payload IF anyone or anything is IN the tundra.
yes the tundra has great brakes and a nice engine, but it is NOT a 3/4 ton unit...
the rated towing capacity is too close 4 me, but the payload issue is a real deal breaker.
towing a 30/slide with any 1/2 ton horse is gonna be an issue.
my 34/without slide isn't much heavier than a 30/with, and i'm happy to use a 3/4 ton diesel truck.
cheers
2air'
jcanavera http://www.airforums.com/forums/memb...navera-56.html has the most posts and info related to towing a 30/slide unit...so search a bit and read.
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 12-23-2007, 07:07 AM   #3
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 65
Airstream Registry
I tow with a 5.7 Tundra and think it is a great truck. It's got a powerful motor and great brakes, but it is still a 1/2 ton truck. The classics with SO have a bunch of hitch weight (1K+) add to that the weight of propane, water and other stuff you will be pushing the limits of the truck. With an empty trailer and no payload in the truck you might squeak in under the limits, but is that how you want to travel?
Richard
Charter Member Four Corners Unit
Old 12-23-2007, 09:47 AM   #4
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Airstream Registry
I concur with the others. You would be at the towing limits of the Tundra. This combo would not be within my comfort zone, but others are not as particular as I am. A 30 SO has a super hefty tongue weight which would not leave a lot of cargo capacity for the truck bed.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 12-23-2007, 01:50 PM   #5
"CLOUDSPLITTER"
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 52
Airstream Registry
Welcome...
Very capable truck......but.
Too close for comfort, I think most would agree, you really need that
payload capacity.
Good luck and keep us posted!!!
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 12-23-2007, 07:21 PM   #6
Andrew T's Avatar
Profile:  2008 34' Classic
1960 17' Pacer
London , Ontario
Hi
I might be able to offer some assistance here as we have set up a few Tundra's. Do you already own the Tundra? If so what box and Cab does it have.
Andrew T is offline   Reply With Quote
Old 12-27-2007, 08:46 AM   #7
Andy, thanks for your reply. Yes, I own the Tundra, but not a trailer yet. Am interested in 30' with slideout. The Tundra is 2007 double cab (not the max work cab) w/ 5.7 engine, 6 ft. box with towing package. I will be interested in your take on this. Reply to maxinecharles@embarqmail.com.
Old 12-27-2007, 11:49 AM   #8
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Airstream Registry
This is going to be a problem.
Your 30 Slideout is heavier than my 31 Classic. I tow my 31 Classic with a F-250 Diesel. I towed it with a F-250 Gas. That was ok but the truck was under constant load. Flat and level the diesel is just humming along.
The wheel base is ok but the power was just not there.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 12-27-2007, 11:54 AM   #9
ProPride, Inc.
Sean Woodruff's Avatar
Profile:  Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
If Andrew T can't offer any assistance then I would say no one can...
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Sean Woodruff is offline   Reply With Quote
Old 12-27-2007, 11:55 AM   #10
U.S.Navy Retired
Safari-Rick's Avatar
Lakewood , California
DiTTO
Been there, Done that !
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 12-27-2007, 12:02 PM   #11
Profile:  2004 30' Classic Slideout
Kerrville , Texas
Towing a 30'w/so
I have a 2004 30'w/so and this is a heavy trailer when you get it ready to go camping. I had a 1994 F250 gas (460) when I bought the trailer. It did ok but would really labor in the Mtns. I now have a 2006 F250 with the 6.0 diesel what a difference. It handles any situation with ease.. You defiinitely need a 3/4 ton truck and the diesel to make your towing enjoyable!!
Richg
richg is offline   Reply With Quote
Old 12-27-2007, 12:03 PM   #12
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
As others have said, you will be at the limit on tongue weight/pay load and IMO, you will be at the limits with towing horsepower. The consensus here on the forums is not to exceed 80% of your TV's towing capacity. Does a 30' Classic S/O do this?
I'm no expert by any means, but my personal $.02 is that in the Safari line, 25' is the border line for 1/2 ton tow vehicles and in the Classic line, well, they are heavier at all lengths and I personally wouldn't consider a 1/2 ton to be a comfortable towing vehicle for anything in the Classic line. That's my opinion and isn't gospel among anyone else on this forum.
Since you already have the Tundra (a great truck BTW), my recommendation is this: if you are close on the 80% and close on the payload and really want the 30' Classic S/O, get it if YOU are comfortable with the numbers realizing that you will trade tow vehicles long before you trade Classic travel trailers. The 30' is a good compromise size as far as not too long to handle for the novice and not too small for a couple or even family. The slide out will make it feel larger so you won't feel like you should have got the larger one and want to trade up in a year or two. With tow vehicles on the other hand, you will want to trade up in a year or two.
However, if you plan on using the trailer really often, or plan on frequent trips in the mountains, or plan on full timing, you might as well bight the bullet and go for broke and get a nice 3/4 ton tow vehicle and 30' Classic at the same time...you'll be glad you did.
Family of Disney Fanatics
WBCCI# 4821
streamin across america
Old 12-27-2007, 03:03 PM   #13
ZoominC6's Avatar
Blacksburg (College Town USA) , Virginia
World Traveler,
Inquiring prior to purchasing your Airstream will save you inumerable headaches for sure. I tow our '04, thirty foot slide out with a 3/4 ton, 4X4, Duramax, crew and can assure you that it's most likely too much truck for the trailer. A 3/4 ton, gas, crew would suffice. The wheelbase rule of thumb for the trailer length would be perfect, the suspension not quite so hard on the Airstream and I'd have ample power. Having said all that, I wouldn't trade down because pulling the hills would be a bear unless I had a 411 rear end and a huge fuel tank. As is, I hardly know our Airstream is back there. Did I mention the Hensley hitch?
My opinion mirrors most of the others here. You won't feel comfy, safe or happy pulling the 30'SO with your truck which is a fine vehicle for most other activities.
Good luck with your research and impending purchase.
HAPPY TRAILS ONE AND ALL
ZoominC6 is offline   Reply With Quote
Old 12-27-2007, 05:35 PM   #14
jcanavera's Avatar
Fenton , Missouri
Images: 143
Airstream Registry
Dependent upon the year the trailer, the hitch weight is large. My slide out is around 1,200 lbs or so. I had to upgrade my GM factory hitch to a class V to carry that load. I'm pulling with a 3/4 ton GMC van, 6.0 liter V8 with a 4.10 rear axle. The big difference between the 3/4 vehicle and 1/2 is frame, brake, and wheel related. I can tell you when the road gets rough and you start dealing with the undulations of the road, that 3/4 ton chasis and components make the difference. I've pulled with a 1/2 van with a 27' Safari and it's amazing the difference in suspension and handling.
My towing capacity of the van is 9,900 lbs. and I can't imagine towing with anything smaller. Keep in mind that the 30' Slide is the heaviest trailer that Airstream makes on a tandem axle. My estimate is that without water and normal camping load of food and clothing, I'm pulling between 8,200 and 8,300 lbs.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
OH NO! ...Not another towing question blucloud Off Topic Forum 4 02-11-2006 05:29 AM
A towing question... sequoiacoast Hitches 5 11-28-2005 05:00 PM
Towing Question joshua32064 Towing, Tow Vehicles & Hitches 1 09-27-2003 06:19 AM
Another towing question Dbraw Towing, Tow Vehicles & Hitches 18 07-11-2003 06:24 PM
Another towing question ipso_facto Our Community 27 03-22-2003 07:06 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
