Old 01-09-2016, 02:05 PM   #1
oKLAHOMA cITY , Oklahoma
Question from a newbie...
So, we have the opportunity to take ownership of a, Airstream, something we have been wanting to do for quite a few years now. One hitch so to speak, is can we tow it?
So, it would be a 23' dual axle trailer.
Our 2 vehicles,
#1 is a 2004 Suburban LT AWD, 5.3l V8, 8,200-8,400lbs listed towing capacity.
#2 is a 2004 Dodge Durango, 4.7L V8, 3,700 to 5,750lbs listed towing capacity
After doing some research online, I feel that either of these vehicles are able to comfortable tow an Airstream, the Suburban in particular. However, i am looking for real world experience.
For those of you who tow a similiar size trailer and do not use an f350, Ram 3500, or other heavy duty vehicle, are you comfortable towing? More importantly, are you comfortable stopping?
Thanks for your help.
jaystekan is offline   Reply With Quote
Old 01-09-2016, 02:15 PM   #2
blucloud's Avatar
2007 27' International CCD FB
1987 25' Sovereign
1977 23' Safari
North Olmsted , Ohio
Images: 20
I've been a fan of Chevy & GMC. We have towed 30ft, to 20ft trailers with no problems. Our last Airstream was a 25ft and we towed from Fort Pierce ,FL to Oh. Only problem was the 2004 Suburban did not have a tow system.
2006 we upgraded to 2500 Diesel .
Not sure about the Dodge, The Suburban will do the job.
Dave
You never know what you can do
until you try to undo what you did.
blucloud is offline   Reply With Quote
Old 01-09-2016, 02:19 PM   #3
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Your suburban is very capable of towing a 23ft Airstream or even bigger. I tow my 25ft with a RAM 1500 & I also use a Equalizer WD hitch.
Hope it works out for you.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 01-09-2016, 03:27 PM   #4
2010 23' FB Flying Cloud
Smithville , Texas
You will be fine with either of your vehicles. I'm pulling the 23' with a diesel because I can, not because my F-150 didn't do the job.
Matt & Virginia Kline
2010 FC23FB
2016 F-350 6.7 Diesel (Overkill and loving it)
Matt Kline is offline   Reply With Quote
Old 01-09-2016, 04:19 PM   #5
1973 Argosy 24
Los Alamos , New Mexico
2004 Suburban Tow vehicle
I tow my "73 24' Argosy (probably about 4000 #) with a 2004 Z71 Suburban with the 5.3l engine and 4:11 rear end ratio. It does an excellent job in the mountains of Northern New Mexico.
hprshtr is offline   Reply With Quote
Old 01-09-2016, 06:27 PM   #6
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I tow my 1977 23' Safari with a 2005 Toyota Tundra with a 4.7 V8 and couldn't be happier. We've been through mountains and towed on very hot days with no problems.
I've also towed my enclosed car trailer with my '54 woody wagon in it and had no issues. The woody probably weighs as much as the Airstream.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 01-09-2016, 10:31 PM   #7
2015 28' International
Ofallon , Missouri
I have a Nissan Armada V8 AWD. I have been towing a 25' Airstream for several years now. I agonized for quite a while before buying it as I was considering 23 and 25 - I was concerned with the 7000 GW of the 25. In the end I went with the 25 and my Armada did a fine job. I do have elect brakes on the AS. I just upgraded to a 28' International with 7600 GW.
I highly recommend a weight distributing sway control hitch.
mpsgolf is offline   Reply With Quote
Old 01-10-2016, 05:22 AM   #8
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
I tow with an older Ram 1500. Your Suburban should work just fine. Post some pictures of your trailer when you get it.
Old 01-10-2016, 06:03 AM   #9
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Tow our 2015 23D International Serenity with our 2007 Mercedes ML320 CDI diesel. It is a perfect match for both power, braking and axle ratings. Use a Hensley Arrow hitch. Cruise 55 mph. Handles 6% grades east of Phoenix fine up and at 35mph in second gear will hold speed due to Diesel engine back pressure when going down.
Old 01-10-2016, 10:38 AM   #10
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
We tow with a 1997 Tahoe with the 350 V8 and a tow package on it. No issues
kdickinson is offline   Reply With Quote
Old 01-10-2016, 11:07 AM   #11
Lovin' the Mountains
2015 25' Flying Cloud
Pine , Colorado
Tow Vehicle
Hi Jay,
I have towed a 25' Flying Cloud for several years with a 2011 GMC Yukon XL with no problems. I live in Colorado so hills are the norm.
Tomsos
tomsos is offline   Reply With Quote
Old 01-10-2016, 11:25 AM   #12
gecko's Avatar
2009 28' International
Pacific Palisades , California
We towed our 7309 max (6980 real world weight) 2010 international 28' for years with our 2000 Suburban 2509 with the 5.3 liter and 3.73 rear end (Equalizr.) with no problem, even at higher speeds in Texas on the straightaways. We replaced it with a new Sprinter 3500 (rated for 7500 towing and with a massive payload safety margin.) the small 3 liter diesel, mated with the with the 4.1 rear end generates the same torque as the Suburban, but less hp, so it's more challenged holding high speeds but otherwise just fine. We've slowed down a bit.
You'll have no problem with your GMC product, but spend some time weighing the parts of your rig and tuning your WD hitch--that will really pay off in excellent handling.
gecko is offline   Reply With Quote
Old 01-10-2016, 12:06 PM   #13
GbatPDX
gary1burke's Avatar
2016 27' International
Happy Valley , garyburke
Interested in your experience - we have a recently purchased 2015 25' Serenity. We have an opportunity to purchase a 2007 MB ML320 Cdi which my wife LOVES. Have read elsewhere that late 2007 models were rated at 7000lbs towing capacity. Would love to hear feedback on this choice.
gary1burke is offline   Reply With Quote
Old 01-10-2016, 01:01 PM   #14
1996 25' Excella
Tillsonburg , Ontario
I have pulled two 25 ft AS with my 03 Dakota for 13 years now. ( 4.7 Quad Cab 2WD Auto, 3.55 rear end) Your 23 should be a walk in the park. The Durango will need to have a Tranny cooler, and you tow with OD off!
JCWDCW is offline   Reply With Quote
Newbie help request from Newbie southsaglejim Plumbing - Systems & Fixtures 18 09-10-2014 07:39 PM
Newbie here, have cleaning question.. Wolf General Interior Topics 27 12-30-2003 01:45 PM
Another newbie question... fan on roof??? flamingo-kid1 Roof Vents, Skylights & Fans 5 07-27-2003 09:12 PM
NewBie Question Chitown AirStreamers 1965 Safari 9 05-13-2003 08:27 AM
Newbie question Rog0525 Our Community 2 05-27-2002 01:30 PM
