Old 11-28-2009, 08:09 AM   #29
1963 19' Globetrotter
Moline , Illinois
For me a 4x4 is a necessity as I need it for the farm and use it quite often. I also do a lot of fishing and it is very handy on many of the boat ramps. As far as the trailer goes I don't ever remember needing it but I am glad to have it if I do. Kevin I'm just curious, but could you have used the lemon law in Illinois to get your vehicle replaced?
63air is offline   Reply With Quote
Old 11-28-2009, 08:56 AM   #30
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by AnnieD View Post
I am not considering a 4x4 TV becuase of the money added to the price of the truck ... AND because i wont be in any ice and snow or bad weather...and i am certainly not going off road with it.
my question is..... do i NEED 4x4 for any reason if i am not going to be in bad weather? wont towing with it on bring down the fuel mileage?
i want to keep the price of this truck down as much as i can but i dont want to be stupid about anything.
at this point i am trying to get an idea of what i have to spend to have peace of mind that when i am towing... the truck will be able to do its job with no worries.
i am leaning towards a diesel... to keep for a long time.
is dodge better than ford for that?
thanks for your opinions.
I got "stuck" on dry short grass backing into my spot at last years area 33 rally. I also got "stuck" turning my truck and trailer around in a level but wet field. Engaging 4 wheel drive got me out of the situation.
You have to be careful what is called 4 wheel drive. This usually means power is being applied to all four wheels but they are not necessarily going to drive all four wheels. Depending on how the rear differential is set up one wheel can still spin and the other do nothing. I have been told the Ford front differential only locks one side so you can turn while in four wheel drive. Not sure I completely believe this one. I have driving evidence to the contrary.
I had a limited slip differential from the factory thinking it would lock up when I needed it. That turned out to be wrong. I burned up three clutch packs. The last one was out of warranty so I replaced it with a selectable locking rear end. This was not cheap but works great!
Michelle TAC MT-0
Sarah, Snowball
Old 11-28-2009, 09:25 AM   #31
i have moved north to VIRGINIA CITY , Nevada
Thanks again everyone for your comments.... i am starting to see the value of a 4x4. its more about not having to worry about getting in and out of somewhere... peace of mind.
aside from Kevins horror story i do see the need for it now. i will most likely be going to places i have not been and i dont know what kind i will encounter.
honestly.... i dont WHAT i would do if i didnt have this airstream community to answer my questions.
i bet i would be making ALL the wrong decisions. LOL
but then.... i am sure people managed JUST fine without this....before computers.
AnnieD is offline   Reply With Quote
Old 11-28-2009, 10:48 AM   #32
Road Ruler's Avatar
Images: 38
Yes there are many variations and technologies. The newer 4 wheel powered BMW x3 for example has the ability to transfer over 90% of it's power to one wheel if that wheel is the only one that has traction.
Old 11-28-2009, 11:13 AM   #33
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Question about 4x4 TV ...
Originally Posted by CrawfordGene View Post
Kevin, you have a lot of patience. I would have written to GM years ago and demanding a real solution. Once fixed for the 4th or 5th time, I would have sold it.
Gene
Three different dealers (all of whom have been in business in excess of 30 years) have replaced the Electronic Control Modues, and each has had the complete repair history that I carry in a 3-ring binder stashed under the back seat. The Zone Rep has been called in twice and offered very little to me or the dealer's service department.
Quite honestly, I don't feel the need of four-wheel-drive, I authorized replacement of the defective part so often thinking that one time I might need it to be operable. A failed module has never stranded me so I have been able to wait to have it replaced by one of the three dealers that I trust. Over the years, I have been told that the part has been revised three times with little improvement in its longevity. Now, I realize it would be far cheaper to just call either AAA Plus RV -- or Good Sam Roadside Service and have them deal with the situation if I ever get stuck.
A new Suburban is out of the question as a loaded model like the one that I have now is priced way beyond my budget and I never buy someone else's troubles (Used/Pre-Owned). I special ordered my Suburban in January of 1998 so I have the attachment that this vehicle is equipped exactly the way that I wanted. Mechanically there has never been a problem with the motor, transmission, or rear differential; so if I get the four-wheel-drive system defeated or removed my major expense will be gone and forgotten. Unless the Suburban is damaged beyond repair in an accident or storm, I intend to keep it, and replace the motor and/or transmission when they wear out with new Good Wrench parts (I hate trading vehicles and grow very attached to my vehicles so don't mind driving something that is decades old).
Kevin
Kevin D. Allen
AIR #827
Old 11-28-2009, 12:25 PM   #34
WK57ABF's Avatar
2007 25' Classic
kendal , cumbria, UK
AnnieD
I would say go with four wheel drive. I wouldn't be without it and use if frequently.
Also it's nice to help out fellow campers stuck on sodden rally fields. Most favours see a bottle of red!!!
John in the UK
WK57ABF is offline   Reply With Quote
Old 11-28-2009, 12:43 PM   #35
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
While I didn't consider it an option since I wouldn't have wanted a new Suburban with the 6.0 Liter (I really like the 7400 VORTEC). My problems didn't begin until the vehicle had over 30,000 miles -- in fact just a bit over 36,000 miles (and two years of service) so it was really beyond the Lemon Law as it stood in Illinois at that time.
Kevin
Kevin D. Allen
AIR #827
Old 11-28-2009, 01:09 PM   #36
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
I have a relatively steep concrete driveway. Last Christmas, I got stuck on that very concrete in my 2WD Chevy dually with a so-called limited slip differential. It had rained the night before, and I had moved the truck to the bottom of the driveway to make extra room for visiting family to park. The truck simply wouldn't go up the hill on the wet concrete. I never leave the pavement with that truck and thought I'd never need four wheel drive. If I had it to do over again, I'd buy a 4x4.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 11-29-2009, 12:28 AM   #37
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
No 4X4.
Hi, I have been in all kinds of situations with my trailer in tow and I have always got out of it with out using another vehicle. [on ice] There are several driving techniques to help prevent you from getting stuck or getting you unstuck. These are not something I can teach over the internet.
My nephew bought a used Jeep CJ-5 and I bought a new Jeep CJ-5 and although the vehicles were very similar our attitudes were different. Somebody would tell my nephew, "You have a four wheel drive Jeep so you can go anywhere" and he would [with a big smile on his face] say yes I can. When that same statement was said to me, my answer back was that I can only go a little further than I could with a two wheel drive vehicle. Your attitude will get you stuck.
As for all the modules replaced on Kevins truck, my experience with situations like this tells me the dealers/mechanics never fixed the real problem. Any time an electrical part is replaced more than twice, it means that something else is causing the failure. A poor ground, an intermittant short/grounded hot wire, an over charging condition, and even a vibration situation because mounting installation was incorrect can cause multiple failures of a part. This is not a part failure, it is a failure of the mechanics to find the root cause. I have personally repaired similar situations where another dealer [and mechanics in the same dealer as me] gave up and the car was sent to me.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
'99 Suburban 4X4 Components--What Next?? overlander64 Tow Vehicles 15 08-20-2009 12:12 AM
Ford 250 4x4 diesel westernviews Tow Vehicles 43 04-07-2007 06:10 AM
4x4 Class 3 MH outclimbs A/S! Astrodokk Airstream Motorhome Forums 5 11-02-2003 04:53 PM
4x4 tow vehicle... or not? Cheryl Tow Vehicles 11 08-22-2002 11:00 PM
