Old 06-17-2010, 12:44 PM   #1
AxelBruijnis's Avatar
1978 31' Sovereign
Gasselternijveen , drenthe
Send a message via AIM to AxelBruijnis
Quadrasteer troubles, any experts ?
When i bought my 2004 Quadrasteer suburban, it had a custom dual exhaust system.. 2 months ago, the tie-rap that held the cable harness away from the exhaust snapped, and the cable melted completely.
a non-GM car shop repaired the harness , and steering still did not work
i bought a new quadrasteer computer on ebay , no luck...
I read that the new computer needed to be re-introduced to the car, so I drove to a company with a Tech 2 system.. they tested the system .. and told me the new computer creates all kinds of error codes, and when they re-installed the old one, it only gave them 1 code : DTC C0527
Apparently this can be the result of 4 conditions :
when Hall 1 2 and 3 have 12 volt as their output
when Hall 1 2 and 3 have 0 volt as their output
when the Hall sensor supply circuit is open
when the Hall sensor ground circuit is open
i think this can be because :
1 the halls are bad
2 the cable harness is not repaired properly *
3 the computer does not read the hall outputs correctly
* the DTC documents state ( in bold and red ) that if the wiring harness to the steering gear motor is damaged in anyway , it MUST be replaced.
Since the harness is probably most affordable, i will replace that first ..
but. what partnumber do i look for ?
help !
Axel , in the Netherlands
1978 Sovereign 31 Mid Bath
1969 Overlander 27
2000 dodge 2500 diesel
AxelBruijnis is offline   Reply With Quote
Old 06-17-2010, 01:16 PM   #2
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Forum member VAJEEP is the only guy I've known to have purchased one of these and to my knowledge he's had no problems with it. You may want to PM him with this. Good luck.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 06-17-2010, 01:23 PM   #3
airstream66's Avatar
1966 30' Sovereign
Bethany , Illinois
Images: 22
Axel,
Hate to say it, but it sounds like you should visit your nearest GM Dealer.
Love your rig, by the way.
Cory, Angie, and 'Lucy'
1966 Sovereign International
2003 Black Chevy Silverado w/q-steer
airstream66 is offline   Reply With Quote
Old 06-17-2010, 01:29 PM   #4
1978 31' Sovereign
Originally Posted by airstream66 View Post
Axel,
The problem is that there are probably less then 3 QS vehicles in Holland , the GM dealer i went to for the Tech-2 system had never seen one before.
( i never saw another one here )
axel
1969 Overlander 27
Old 06-17-2010, 01:56 PM   #5
1966 30' Sovereign
Bethany , Illinois
Images: 22
Over here, most dealers don't know how to work on them either. Try a new harness and then the steering gear motor, and if that doesn't work, prepare to live without it. I am if or when mine dies.
Disclaimer: I am no expert.
Good luck.
Old 06-17-2010, 02:14 PM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
You may have to sign onto this page to read this but it is a free site. There are several threads on quadrasteer bowards the bottom of this page. A different serach may bring up more.
Diesel Place
2004 Excursion 4x4
Old 06-17-2010, 02:56 PM   #7
1978 31' Sovereign
Good luck.
thank you !
Since parts for the suburban cost 1/3rd in the USA , i am looking for the part numbers so i can order them online ..( and bypass the european dealer )
i found this page :
2003 Chevrolet Suburban 2500 4WD Steering Control System, /Rear - TC0669601L76M70K25906
but they don;t have a part numbers on the cable harness..
You are correct, its still a wonderful car /drive , even without QS
Axel
1969 Overlander 27
Old 06-17-2010, 03:00 PM   #8
1966 30' Sovereign
Bethany , Illinois
Images: 22
forum member MOOSETAGS has 2 quadsteer suburbans.
You might PM him.
Old 06-17-2010, 06:48 PM   #9
richinny's Avatar
2011 34' Classic
there is a member with gm dealer experience. stay tuned in. i have a feeling he will post something here.
Ricky
Old 06-18-2010, 05:37 AM   #10
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
You might PM him.
I do have two Suburban 2500 Quadrasteer tow vehicles, an '05 4WD with 85,000 miles on it, and an '04 2WD with 65,000 miles on it..
I can't comment on the issues in this thread as I have not experienced any Quadrasteer problems with either of my Suburbans. It does sound like a new wiring harness would be the next thing to try.
Best of luck in getting your problem solved. Please keep us posted.
Brian
SuEllyn & Brian McCabe
Old 06-20-2010, 01:00 PM   #11
1978 31' Sovereign
Brian
Thanks, Brian,
I posted the same question on the quadrasteer forum, hoping that anyone still reads that.
http://quadrasteerclub.infopop.cc/eve
Axel
1969 Overlander 27
Old 06-20-2010, 05:36 PM   #12
APB
APB's Avatar
Escondido , California
I just happened to read this thread and would like to offer the following comments.
I know absolutely nothing about Quadsteer GMs but I do know a little about cables in general and troubleshooting problems.
Cables are not very complex although they can be intimidating to the uninitiated. I would suggest finding a wiring or harness diagram for the vehicle and use an ohmmeter or test lamp to check out the cable. The skills needed to do this are not difficult to learn. The most difficult part may be reading the harness diagram as they can be somewhat obscure at times.
Another approach is to look at the repaired area in detail. All automotive harnesses are color coded so if you see for instance an pink wire connected to a green wire that would indicate a problem.
Another approach is to make sure the green wire at one end goes to the green wire at the other end and nowhere else. This is not fool proof as this is not always the case but if something did not match up that seemed to be connected to the hall sensors involved it would make me really curious.
You should be able to find some electronic technician locally who will do this for you or at least guide you thorough the process.
It is difficult to imagine a harness being so messed up you could not repair it as long as the connectors are in good shape.
I realize this may not be the most cost effective way but then again that far from decent service help who knows.
Good luck in your chase.
APB
Bluegrass is flat picking good!
APB is offline   Reply With Quote
Old 06-21-2010, 01:17 AM   #13
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, a wire harness that has been burned and shorted, sometimes will have bad spots in areas that you can't see. You should remove the entire harness and strip it down so you can see every inch of the wires in it. Bad, or not really good, repairs on modern wire harnesses can change the resistance giving the computer false readings. A new wire harness might be best.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-21-2010, 02:23 AM   #14
Hephzibah , Georgia
good luck on finding your solution.
in america there was a commercial with a silverado backing a cattle or horse trailer into a corral. what they didn't show was that truck not being able to pull out of the corral. one of my tech school instructors worked for GM at the time and the engineers were catching some hell because there was a difference in turning degrees when in reverse vs. going forward. they could back into a tight spot but couldn't get it back out.
nti06 is offline   Reply With Quote
computer, hall, harness, quadrasteer
GM to Drop Quadrasteer RoadKingMoe Tow Vehicles 20 03-09-2005 08:38 PM
Help! Duramax vs. Quadrasteer Hit'the'road Tow Vehicles 24 10-14-2004 05:03 PM
Quadrasteer Tin Hut Tow Vehicles 2 05-06-2004 03:17 PM
Quadrasteer vajeep Tow Vehicles 39 03-16-2004 09:28 AM
Quadrasteer Suburban?!! Jabba Tow Vehicles 16 07-11-2003 05:46 PM
