Old 06-22-2016, 04:30 PM   #1
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Purpose Built Tow Vehicle
A purpose built tow vehicle is not the norm. Very interesting to find one.
This is a 1999 that the current owner purchased in 2012. He said that it was one of the early years that Freight Liner built a tow vehicle. Weighs 12K lbs, has 8-1/2" of ground clearance, and is powered by a CAT. Only issues mentioned were that it rides like a buckboard without a load and the AC is a little light duty for hot climates.
Travel safe. Pat
Old 06-22-2016, 04:48 PM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Can he switch to air ride? or at least in the seats.
sgschwend is offline   Reply With Quote
Old 06-22-2016, 05:19 PM   #3
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
A bit overkill for an airstream, any 3/4 ton diesel pickup will do about all you want,even have an exhaust brake
Old 06-22-2016, 06:30 PM   #4
1974 25' Tradewind
Calgary , Alberta
So what do they offer that will tow more than a Bambi?
Alumineer is offline   Reply With Quote
Old 06-22-2016, 06:59 PM   #5
PKI
PKI's Avatar
It has air ride and the owner is looking to upgrade it for a better ride, however with his trailer hooked up, it rides Cadillac smooth. Air ride on the hitch too.
Bambi - surely you jest.
Why? Look at all that storage. No payload constraint. It has a low center of gravity. It has a long wheelbase. It has a short overhang. No need to wait for Tesla to develop high capacity battery for AS. Just install a lead acid high capacity bank in the bed. Get it worked on at any truck stop. No one will mistake it for a minivan. Should last a million miles. What is not to like?
Travel safe! Pat
Old 06-23-2016, 12:08 PM   #6
1982 31' Excella
Missoula , Montana
Wait till you buy your first set of tires, or want to drive to downtown Scottsdale and shop. Thats why I bought my airstream so my daily driver is with me at all times. I get my tires rotated for free, my oil change is $69, and I can run it thru the car wash.
Vernbots is offline   Reply With Quote
Old 06-23-2016, 12:15 PM   #7
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
The cowboys and rodeo folks have been using those light/medium rigs for several years, since the availability of the RV/horse combination trailers.
Of course, with a rig of that sort, one could simply haul his Airstream trailer instead of towing it.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 06-23-2016, 03:16 PM   #8
PKI
PKI's Avatar
Regards,
JD
JD - yes, that is how this one was sourced. Family was no longer using it and ready to pass it along.
VB - Tires should not be so bad, since the size is much smaller than the monsters you see on big tractors. They were one of the upgrades made in the first year. The original spec tires on the front were overloaded and performed poorly. But you are right. It's not a daily driver.
Enjoy your toys and travel safe. Pat
Old 06-23-2016, 03:47 PM   #9
2014 25' FB Flying Cloud
Micanopy , Florida
My best friend from way back had one of those. Towed 38-40 ft 5 th wheel. He said it was the worst riding vehicle he ever had . Actually had air ride installed, seats and frame at the insistence of his wife. Big bucks! They were full timers. 1 yr later they got rid of it and bought phaeton coach. Good luck with it.
Offack is offline   Reply With Quote
Old 06-23-2016, 07:57 PM   #10
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
I recently pulled up to a diesel pump and one of these rigs was in the adjacent aisle. I thought it was a regular tractor then noticed the small 5th wheel plate so asked what he towed so he showed me a photo on his phone. As I recall, it was a 40' 5er but what got my attention was the Fiat riding across the back of the cab. Glad he had his fuel bill and I had mine.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 06-23-2016, 08:20 PM   #11
1977 31' Sovereign
Lynnwood , Washington
I knew a guy that had one of these about 15 yrs ago. His rig had a sleeper cab. Much like a professional truck driver, he was a private contractor and hauled RV's all around the country.
Tom
TomKirk is offline   Reply With Quote
Old 06-26-2016, 05:47 AM   #12
2014 27' Flying Cloud
Wenatchee , Washington
No offense intended but a truck without 4WD is worthless to me. My '12 Ram 3500 SRW CCSB CTD 4x4 pickup does just about everything I need a truck to do, to include towing our '14 FC 27FB without difficulty. YMMV.
2012 Ram 3500 CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 06-26-2016, 02:43 PM   #13
PKI
PKI's Avatar
21 - no offense taken. It's not a rig that I would purchase as I have my dedicated tow vehicle, but the idea of purpose built solutions is intriguing. The equipment boxes on that rig seem much better than having to heft stuff into a pickup bed. A low center of gravity should be safer for towing. The rough ride seems unnecessary with an air ride independent suspension. Always thought CAT power was really cool too.
Understand that while most folks do not need 4 wheel drive, some folks really do use it. It certainly comes in handy when the weather gets a bit snotty. Torque vectoring kind of helps too. Have always wondered if the original HumVees would be a good tow vehicle. Independent suspension all around, wide stance, diesel power, and a rigid chassis. Unfortunately, you don't see many and cost is a significant hurdle.
Now, you travel safe. Pat
Old 06-26-2016, 07:18 PM   #14
Sioux Falls , South Dakota
Some of the high end 5'ers can weigh 24,000 pounds. With 25% of the weight on the pin, that's 6000 pounds right over the axle. Add 250 pounds for the hitch itself and you can see why a heavier truck is needed. Remember that nearly anything can drag a trailer down the road (for a ways, anyway), but the real test is stopping it. That's why so many of the full-timers with those heavy 5'ers use at least a medium duty truck, and quite a few use a heavy duty truck (think semi). Yes, they either carry a tiny car on the back or one person drives the truck and the other drives the car.
Right now our Foretravel weighs just under 30,000 pounds and tows about 5000 pounds of Jeep. When we switch to the Airstream and F250 the pair will be under 20,000 pounds. I just wish that I had the $$$ to buy a new truck and have a custom bed on it.
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
What is the purpose toastie Repairing/Replacing Floor &/or Frame 16 11-12-2009 03:26 PM
Tow Vehicle for 1971 Ambassador built between 1970 and 1989? Pschoerrn Tow Vehicles 2 08-11-2006 01:49 AM
What's the purpose/function of the stainless(?) "sleeves" on the A/S trailer tongue? Dave Jenkins Our Community 5 08-20-2003 09:08 AM
