08-31-2008, 02:06 PM
1978 28' Ambassador
Kenton
Pulling Power On Hills
I know gas vs. diesel has been done to death but I have a simple question about diesels. I have never driven one and know nothing about them other than the get better fuel mileage than a gas engine and have more pulling power. I currently tow with a 1999 3/4 ton Suburban with a 454 engine and it pulls great. I pull a 1978 Ambassador (28ft). It seems that even on fairly mild hills my vehicle downshifts and my mileage goes to pot. I have a Scan Gauge and can monitor my fuel mileage in real time. I understand that diesels have great pulling power at low RPMs. Does this mean that they don't downshift as often on mild hills?
Tom
08-31-2008, 02:36 PM
2003 31' Classic
Valparaiso
, Indiana
Hello:
I have been pulling 31' Classics with a 06 and most recently an 08 Ford Super Duty Diesel and would not give up the pulling capacity of the diesel versus Gas. We hit the bottom of a hill at 60mph and go over the top at 60mph without any problem. We have been averaging 13-15 mpg depending on the terrain. Even with the price disadvantage of diesel vs gasoline, we feel we are ahead of the game. Will be quite a while to make up for the cost of the engine, but I like the power that a diesel gives me. Hope this gives you some insight.
"I can win an argument on any topic, against any opponent. People know
this, and steer clear of me at parties. Often, as a sign of their
great respect, they don't even invite me."
Bob-air # 657
I can win any argument on any subject. People know this and steer away from me at parties. Often as a sign of their respect, they don't even invite me.
08-31-2008, 03:07 PM
1999 27' Safari
Kent
I have a 2006 super Duty gas. The new 5.4 liter 3 v paer cylinder. It also has a 6 speed tranny. 4:10 axles. Deisels do tow alot and they have a loyal following. They say if you drive more than 17000 miles a year a deisel will pay off in the long run. I drive over 17000 miles a year. I chose gas. Biggest reason. I didnt want Ford first year 6.4 liter. My Tranny (6speed) was something to get used to when new I had to goback to the dealer for a updated program in the computer. Now this thing doesnt search, and in Tow Haul mode the tranny stays in gear with out the old downshift to get RPM's up. It is amazing how far these trucks have come in the last few years. When decending down a grade if the computer sees I am applying the brakes it will downshift. I get 12.5 miles to the gallon towing my Airstream. I get 10 with my 24 foot box trailer at about 11000 lbs.
Be Not Afraid JMJ + AMDG
2008 25' Safari
Quiet Green
, Connecticut
Originally Posted by rochar3
Hello:
And remember, if maintained properly, you can expect a MUCH longer lifespan out of that powerful diesel engine - which MORE than makes up for the higher upfront cost, IMO.
At least, that is what I am banking on! '08 Silverado Crew HD w/Duramax Allison combo - even splurged for leather so the seats would last as long as the engine
Will let you know if another 400k miles or so!
08-31-2008, 03:34 PM
_
Originally Posted by tlavergne
...Does this mean that they don't downshift as often on mild hills?...
there may be too many variables for a yes/no answer.
the gearing (final and 1-4), programing, incline, wind, entry speed, tire size and WEIGHT of the load...
along with the power/torque curves unique to each power plant.
along with the drivers FOOT.
these are just a few issues, the automotive wizards can add to this list.
anytime the tow'd load, incline and speed are matched to a given power band, shifting will be less frequent.
some of the turbo diesels have a broad/flat peak torque curve and that reduces shifting, as i understand it.
many newer trucks have 2 or more tranny programs, like the tow/haul mode...
on the ford this feature RAISEs the shift point, so a given gear is held longer going UP and DOWN inclines.
the 'shifting' u mention can be reduced by dropping the tranny into a lower gear before the the hills.
this might be a good thing in areas with many rolling hills with lots of incline variation.
the single best gear or driving style to max out mpg is widely debated,
and the best towing reports all are suspect. (i get 81.6 mpg by adding old motor oil...2 my salad dressing )
while the scan gauge may provide instantaneous fuel consumption data...
keep in mind much of the UPhill loss is recovered going DOWN the other side,
unless punching the throttle and mashing the brakes is part of the driving style.
driving INto the wind or stopngo do more damage to mpg than hills when averaged...
cheers
2air'
08-31-2008, 04:27 PM
1978 28' Ambassador
Kenton
All,
Thanks for the responses. I tend to tow at 60-65 mph anymore. The transmission does not hunt, when going up an incline it will downshift and stay there until the hill has been crested. And yes, I do make up the mpg going down hill. This past summer in W. Virginia I was getting 5-7 mpg going uphill and up to 35 mpg going down. It was fun to watch. But, as is with the stock market, it is probably not wise to keep a constant watch on these things...it will drive you nuts. I am in the process of thinking about replacing the '99 3/4 ton Suburban in the next 5 years or so...got to wait until the kids are out of college. Until then the Suburb is fine. A lot can happen in the tow vehicle world in the interim. Who knows, in the end I might just keep the Suburban. I just wish it got a bit better mileage when not towing. But I can buy a lot of fuel for the cost of a new truck.
Tom
08-31-2008, 04:46 PM
1999 23' Safari
Perrysburg
, Ann Arbor
A 3/4 ton 'Burb with big engine will tow most any Airstream just fine, what with heavier suspension, bigger brakes and ring gears, etc. You WILL get more torque out of a diesel and that MAY give you less downshifting, depending as 2Air says, on so many factors that it'd take a big computer to sort them all out. But there's nothing wrong with downshifting - "it's supposed to do that." I love my diesel ('08 Duramax, Allison trans, etc.), and it gets pretty fair mileage and yes, I like the tow / haul mode when in hills, and all that. But if I'd had a 3/4 ton 'Burb when I started out, I'd have probably kept it, given the additonal cost of a new vehicle.
Well, maybe not - I haul stuff like generators and fuel and my wife is always hauling trees and bushes and piles of manure, etc. Long ago, I had a 1/2 ton 'Burb, and loved it, but I wouldn't haul fuel and such inside it and the manure, etc. was NOT a good inside-the-vehicle load. Trust me on this one. So my pickup is just fine. YMMMV. Literally.
08-31-2008, 07:36 PM
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin
, 28734
diesel
I drove gasser's for years got my first diesel and loved it so much all my vechiles are now diesel. I drive a VW Bettle TDI it gets 45 miles to a gallon and climbs hills without down shifting. My Duramax 2500 HD is the best tow rig I have ever had. I love my truck!
08-31-2008, 07:54 PM
1965 26' Overlander
1962 24' Tradewind
Vincennes
, Indiana
I kept my '01 Dodge so long the leather driver's seat gave out at 600,000 miles but the engine is still strong at 678,000 miles!
Godspeed,
Trent
TV1: Black Sheep, 2001 Dodge 3500, 800,xxx miles, a few non-stock parts here and there...
TV2: Brownie, 1989 Dodge W250, only 256,000 miles!
TV3: 2004.5 Dodge 3500, 415,000 miles, 6 spd
TV4: 2005 Dodge 3500, 478,000 miles, 4spd auto
"Too much of what I once knew I now know not" Me
08-31-2008, 09:20 PM
1999 27' Safari
Kent
Hey Blacksheep my buddy owns the local garage and he like you also loves his dodges. You both have alot of miles on um. Thats cool. Gas or deisel they both definatly have there place.
09-02-2008, 06:21 PM
1979 25' Tradewind
virginia beach
my 2001 dodge diesel does downshift occasionally when going up steep grades but not anywhere like my gasser does. This is my first diesel and definitely not my last. IN fact if I could change all my vehicles to diesels I would.
I recommend you go test drive a diesel and see how you like it. 3/4 ton Burb's are cool. I just wish you could get one with the Duramax and allison combo.
my towing mileage is roughly 14-16 mpg plus when I keep her at 1600 rpm /1700 rpm at 62/65 mph
hey blacksheep, 678,000 miles? that is fantastic.something to be said for the dodge inline 6 cummins
" Dad always said, If you're gonna be stupid you better be tough"
WBCCI #02579
09-02-2008, 07:47 PM
1978 28' Ambassador
Kenton
I agree about wishing they put the Duramax/Allison in Suburbans. That would be a sweet combo. I know earlier Suburbans had a diesel option but it was only offered for a few years.
Tom
09-02-2008, 09:09 PM
1999 27' Safari
Kent
I have heard in the next couple of years alot of the contacts are running out. Dodge /cummins Ford/ Intl ect.. I heard catterpillar is throwing its hat in the ring also. 2012 alot is going to change detroit engineering has said
09-02-2008, 09:19 PM
2007 25' International CCD FB
Gahanna
I don't know that you'll recoup the dollars spent on the diesel option unless you keep the truck for the long haul. I'm towing with the Duramax 2500 HD and I'll never go back. With steady freeway driving as a commuter I get 20.6mpg and it averages out around 17 with stop and go. Towing with full load I'm getting 12 to 14 mpg depending on the hills and traffic. I've never met a hill that I can't top out at 70 mph or more. I don't let myself get stuck in the slow lane uphill.
The tranny is steady with butter smooth shifts. No neck jerking searches for the right gear, no huge jumps in engine rpm. It just flat-out pulls and let's you sit back and enjoy the ride. 70 mph at 1750 rpm.
Large block gassers pull but I'm not certain that they have the longevity of the diesel engine. I've heard that the diesel will far outlast the large gasser. So, in fact when you're rebuilding the large block gas engine, the diesel will still be going... you make up for the difference right there.
I'm a previous VW TDI owner and love diesels. I loved that little engine... I just didn't love the car around it.
Test drive one today and feel the smooth power of the diesel.
The Duramax/Allison is probably the quietest most reliable diesel/tranny combo on the market right now.
Cummins are fairly noisy and the Ford/Navistar Powerstrokes are coming off a few years of reliability issues. Watch out for used Powerstrokes.
yakman
09-02-2008, 09:27 PM
1999 27' Safari
Kent
The older 7.3 liter say 1997 or so was a great engine its to bad they layed it to rest
09-23-2008, 07:13 AM
1976 27' Overlander
2006 28' Safari S/O
Lovettsville
duramax/allision conversion
09-02-2008 07:47 PMtlavergneI agree about wishing they put the Duramax/Allison in Suburbans. That would be a sweet combo
We are pulling our '06 28' SO with a 1999 2500 Burb. It only has a sb in it and was OK with the '76, but with the additional weight of the SO, it is a bit power deprived. I am considering pulling it out and putting in a durmax/allision because we like the burb and don't really want to go to a pickup (2 dogs, etc.)
Does anyone have any experience or guidance on this conversion?
I have searched threads, but didn't find anything on this.
Victor
09-23-2008, 08:08 AM
1986 25' Sovereign
Allegan
, Michigan
Downshifting on hills
Just returned from a 3,000 mile trip to Maine and thought that I'd add my experience. My TV is a 2003 K2500HD with 6.6 diesel and 5 speed automatic. Total weight is around 13,500. If conditions permit, I can pull most hills at 60 mph , 1800 rpm locked up in 5th gear. However, on winding roads it will downshift at lower speeds even though I think that the engine has enough torque to handle the load.
My engine has peak torque at 1800 rpm, 520 ft lbs according to Gm. The newer engines from all manufacturers are more powerful, which is good. But, IMO, having peak torque at lower RPM is more important. ( I think that GM is about 650 ft lbs at 1600 and Dodge is more even lower; not sure about Ford but expect it is in the same ballpark.) The reason this is important is that when you are going up a hill the engine has more torque available as you slow down slightly. A typical gasoline engine has peak torque (and power) at much higher RPM which means a downshift to 2nd or 3rd gear and much more noise. But the big block gasoline engine will do the job.
Bottom line, I get about 15 or 16 mpg on flat to moderate hilly expressway at 58 mph, 14 or so on backroads in hilly Vermont. Hope this helps.
Whit Nash
09-23-2008, 08:11 AM
1971 25' Caravanner
scappoose
A "diesel suburban" search on Yahoo, turned up a few places that do that conversion. Their is an outfit in Co., that does this as a matter of course,with new/newer subs.
09-23-2008, 08:26 AM
1968 28' Ambassador
Cedaredge
Diesel vs. Gas... Diesel have more torque for the moment, but Gas engines are catching up, Thats what give them the power advantage.....The price of Diesel doesn't seem to be going down, and gas is, there goes your fuel advantage... I get 20 mpg on the highway with my new Sequoia 17-19 stop and go.... 10-12 towing... at 70-75 mph... I have 401 ft lbs and 382 bhp.
If I was just going to buy a TV I would get a diesel truck but we have a family and need more room and comfort... I have an old truck but not enough room for 2 kids and adults to ride with car seats...
I think it depends what you are going to use your TV for overall... If just towing then I think a diesle truck makes sense but if you are using it for other stuff you make have to compromise... It also makes a dif. how heavy your trail is!!!!!!!!! mines about probally 5500 full or a little more... I have enough power to go faster up any hill than I would feel safe...
If you have driven Vail pass in Colorado tops out just over 10,000 ft.... I can do 70 mph no problem...
Jason
May you have at least one sunny day, and a soft chair to sit in..
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
09-23-2008, 08:49 AM
1976 27' Overlander
2006 28' Safari S/O
Lovettsville
durmax/allison into burb
Thanks rangebowdrie....I'll check into it.
