Old 03-26-2016, 01:29 PM   #1
interstateflyer's Avatar
2017 25' International
Los Osos , California
Protecting 2016 RAM 2500 Auto Transmission Radiator from Rock Damage
I'd like to find a way to protect my 2016 RAM 2500's automatic transmission cooler radiator from flying rocks and other gravel/dirt road hazards. I'll be traveling in the Yukon/Alaska this summer, with 2 way traffic on gravel roads.
I'd rather not build or install a structure over the front of the truck. I'm looking for something only for the two exposed areas in front of the radiator that could stops rocks but wouldn't cut down on cooling.
Has anyone dealt with this and found a practical solution?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 03-26-2016, 02:06 PM   #2
Llando88's Avatar
2016 30' Flying Cloud
I would be tempted to go to Lowe's and buy a roll of 1/4" hardware cloth (aka chicken wire), a length of steel wire and a pair of tin snips.
You could probably fashion a screen of the desired shape, cut it to fit, then attach it to the frame / tow bolts / grille in a few suitable places.
I'd pick 1/4", but probably depends on the size rock you expect to encounter. We had some roads in Utah last year under construction we had to drive through for several miles in our SOB Class B. Not fun.
Good luck on the trip. Nice truck.
Rich
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 03-26-2016, 02:07 PM   #3
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
¼" wire mesh from a hardware store like chicken wire can be bent to fill the space and allow air flow. Having said that, if one drives thru blowing debris like tumbleweeds, you will have to clean that chaff out of the wire mesh.
I saw these customs screes on some hotrods and they were extremely well made. However, they are expensive.
http://wardlowbras.net
They can be removable as well.
Old 03-26-2016, 02:31 PM   #4
SMLJeep's Avatar
2017 27' Flying Cloud
Moneta , Virginia
I'd suggest a Bull Bar.
https://www.realtruck.com/dee-zee-bu...16Y2713MA.html
SMLJeep is offline   Reply With Quote
Old 03-26-2016, 03:14 PM   #5
I'm tempted to go with the 1/4 inch wire mesh idea. Sounds like a relatively simple solution.
I had considered a bull bar but I'm not sure that they offer much protection for the RAM 2500's radiators against flying rocks. Seem like they might deflect small animals well. I've heard from some off-road guys that most bull bars are weaker than they look and not to count on them to protect from solid objects.
Old 03-26-2016, 03:35 PM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Yup, hardware cloth. When I drove the AK Highway in 1971, it was all gravel and there was much more tractor-trailer traffic, due to the pipeline construction. I built a hardware cloth frame to cover the windshield and headlights of my Land Rover. Never had a problem - once I got used to looking through the screen! A friend traveling with me in another vehicle had a stone break his windshield the first day.
But it's different now. It's all paved except for construction areas and there is much less tractor trailer traffic. But that's still worth taking some precautions.
2012 Dodge Durango Hemi/AWD
Old 03-26-2016, 08:47 PM   #7
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
See GENOS GARAGE condenser guard
Old 03-26-2016, 09:11 PM   #8
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
You should put a winch in there ;P
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 03-26-2016, 10:41 PM   #9
I saw yours. Looks like it takes up much of that space.
Did you have to get the two alternator or snow plow option in order to have the winch?
Old 03-26-2016, 10:45 PM   #10
Did you install the ac condenser guard in you truck. Looks like a project.
I'm also a little confused. The large vertical radiator just being the grill is the AC condenser. I assume that the smaller one mounted at a slight angle just below it is the Auto Transmission cooler radiator. It is exposed and un-guarded in the bottom opening. Do you happen to know if that actually is the AT cooler?
Old 03-27-2016, 05:49 AM   #11
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I haven't measured, but I think you could use one of the aluminum mesh lower screen door guards, like are on the screen door of your Airstream. It has large enough gaps to allow plenty of air flow, but is strong enough to deflect most rocks. The "good" news is, you can test-fit it by simply unscrewing the one you have, and see if it will work. If it does, get another one, if not, put the one you have back on the door.
Old 03-27-2016, 07:48 AM   #12
Llando88's Avatar
I had a look at mine just now (2016 Ram 2500). It does look a bit unprotected there. Based on the opening size, and the number of places for a tie down, the hardware cloth held with a bunch of zip ties might also make sense (and would not rust, either.). Be pretty easy to remove after the trip, too.
FWIW I searched over at the ramforum.com and did not immediately find any solutions there, either.
Rich
Old 03-27-2016, 10:52 AM   #13
2016 28' Pendleton
Spokane , Washington
I have driven the AlCan highway twice & agree with a screen across the front. I used a fabric mesh screen with bungee cords attached to the fender wells and it worked without fail.
groverpeters is offline   Reply With Quote
Old 03-27-2016, 01:23 PM   #14
2005 31' Classic
Gretna , Nebraska
In retrospect, the best thing I did was install a piece of tin in front of the freshwater tank drain valve.
Ours is plastic and the tin was bent, so it paid off.
We were also advised to cover the copper gas lines under the trailer.
Overall, we had no problems.
Dwight
16595 is offline   Reply With Quote
Help Deciding On 2016 RAM 2500 6.4 Hemi jonnie3 Tow Vehicles 90 04-08-2016 10:53 AM
2016 Ram 2500 Cummins 20" Tire Pressure Llando88 Tow Vehicles 15 12-01-2015 09:01 AM
RAM 2500 auto leveling rear suspension RivaHaven Towing, Tow Vehicles & Hitches 17 11-23-2015 10:50 PM
Ram 2500 Auto Level Rear Air Suspension NoNameinNM Tow Vehicles 22 10-27-2015 08:37 PM
protecting the radiator and other coolers PeterH-Airstreamer Airstream Motorhome Forums 18 04-28-2003 07:00 AM
