Old 03-28-2016, 07:13 AM   #15
dstalzer's Avatar
2005 25' Classic
Plastic Drain Valve
Originally Posted by 16595 View Post
In retrospect, the best thing I did was install a piece of tin in front of the freshwater tank drain valve.
Ours is plastic and the tin was bent, so it paid off.
We were also advised to cover the copper gas lines under the trailer.
Overall, we had no problems.
Dwight
Driving across the Top of The World Highway, a stone sheared off our fresh water drain valve. It is a good idea to protect it due to some stretches where road work and gravel cannot be avoided. I found a replacement valve in Whitehorse at Fireweed RV repair.
Dennis
dstalzer is offline   Reply With Quote
Old 03-28-2016, 12:08 PM   #16
interstateflyer's Avatar
2017 25' International
Los Osos , California
Trying to decide between 1/4 and 1/2 inch hardware cloth. Not sure whether or not 1/4 would cut down on cooling air flow.
I've already wrapped all of the water and gas pipes and electrical underneath the 23D with closed cell pipe insulation tubing. This should help with avoiding freezing in the winter and possibly make for better propane flow in cold weather.
Next will be to build shields on both drains on the water tank enclosure.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Help Deciding On 2016 RAM 2500 6.4 Hemi jonnie3 Tow Vehicles 90 04-08-2016 10:53 AM
2016 Ram 2500 Cummins 20" Tire Pressure Llando88 Tow Vehicles 15 12-01-2015 09:01 AM
RAM 2500 auto leveling rear suspension RivaHaven Towing, Tow Vehicles & Hitches 17 11-23-2015 10:50 PM
Ram 2500 Auto Level Rear Air Suspension NoNameinNM Tow Vehicles 22 10-27-2015 08:37 PM
protecting the radiator and other coolers PeterH-Airstreamer Airstream Motorhome Forums 18 04-28-2003 07:00 AM
