Old 12-21-2007, 10:26 PM   #1
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
The engine shown here started life in 1931 with 40HP It's now putting out over 120HP. FYI, you could build three small block Chevrolets for the same price as building a good Model A engine![/quote]
Hi, I would prefer to have the Model A 4 banger rather than belong to the infamous 700 club. [small block 350 / turbo 350]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 12-09-2007, 09:09 AM   #2
ibgl6's Avatar
Profile:  1973 27' Overlander
Southport (Panama City) , Florida
Send a message via AIM to ibgl6
I have replaced the muffler with a Flowmaster seems to help a little not to sure but sounds good the old muffler had a large hole in it so it had to be replaced no it only looks like a grocery getter haha...SAM
Your Friend Sam In (Southport) Panama City Florida Air#15607
Good Sam (LifeTime Member)
ibgl6 is offline   Reply With Quote
Old 12-09-2007, 09:27 AM   #3
RBolton's Avatar
Profile:  Belington , West Virginia
I agree with the "engine is a pump" analogy. With the use of airflow sensors, oxygen feedback systems and computer control in modern engines, the fuel/air mixture ratio remains pretty much constant. The optimum ratio for unleaded gasoline is 14.something to one. It would seem then that the more air that you "pump" through an engine the more fuel that will be mixed with it.
More air/less fuel does, I think, result in a lean condition. But, it’s not likely that today’s systems will allow an engine to run lean, or if it does, it will surely illuminate the malfunction indicator (check engine) lamp. Any gain in fuel mileage, if you are lucky enough to get it, is more than likely achieved by the freer flowing exhaust. That might explain why your fuel mileage fell off when you did away with the straight pipe exhaust.
RBolton is offline   Reply With Quote
Old 12-09-2007, 09:41 AM   #4
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
While I don't drive Detroit Iron, my Sprinter van with it's 2.7 liter 155 HP.....225Ft/Lb torque Mercedes diesel works very well, but was in need of a little 'boost' when I tow the 19CCD to Oregon.
I found a fellow who reprograms the ECU computer for just this purpose. Promised gains of 30 HP and 40Ft/Lb torque (measured by dyno) for the miserly sum of $350. All re-progamming is reversible with a money back warranty if you are not satisfied.
I took the plunge in September while in Oregon this summer. The power increase was immediately noticeable and if you keep your foot off the floor, the mileage went up 1-2 MPG. No black smoke either.
Towing up the big grades in the West was much more peasureable now, with the mileage about the same as before the mod.
I am happy!!!!!!
Lew Farber -Certified Master RV Tech (currently on Forums sabbatical)
WBCCI #1456/VAC (assoc) #1456 AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 12-09-2007, 10:35 AM   #5
Full-timer
Profile:  1971 27' Overlander
above Shavano (pop. 0) , Colorado
Unfortunately (or fortunately, depending on point of view) modern vehicles with computer moderated air/fuel/ignition/transmmission control afford little in the way of efficiency improvement via modification unless your needs are very unusual or you're willing to forego emissions and/or durability standards.
Many, if not most, modern vehicles run a wee tad rich much of the time as a means of self-preservation. On something like the new Hemi that's seriously tweaked by the manufacturer for power, it might well run significantly rich at full-throttle.
There are good reasons for that -- partly that the common buyer of such a powerhouse motor is not really looking for optimum fuel mileage, and partly that it's cheaper and easier to just throw more fuel in than to expect every owner of a new vehicle to assume responsibility for keeping the motor alive when, after all, it's under warranty. The manufacturer surely recognizes that, hype aside, most such vehicles spend 99.97% of their existence ferrying li'l Brittney to soccer practice rather than towing a trailer, and so optimize things toward that satisfaction parameter.
For one willing to tread their own path, it's possible to customize performance to specific needs at the expense of others. That any customizer could claim across-the-board improvements with no downside is pure marketing spin with fingers crossed and lawyers at the ready.
My tow vehicle is and old Jeep Wagoneer. Though it was built in the early eighties, it's a technological throwback to the fifties with a few decades of emissions requirements kludged on top. I was able to double its power while simultaneously neary doubling its fuel efficiency and making it far "cleaner" than before by employing technology not available when the silly old thing was designed -- basically just brought it up to late 20th-century spec. But the days of being able to easily realize such gains are long gone, and good riddance!
Even with the huge improvement I've accomplished on this old rig, payback in purely monetary terms stretches beyond my lifetime (unless gas hits $15/gallon soon or I start a serious life-extending exercise program, both of which seem unlikely).
I don't want to discourage anyone from experimenting in search of their imagined optimal; but doing so with high hopes on any reasonably modern vehicle seems to me akin to pole-vaulting over mouse turds.
"Don't confuse symmetry with balance". Tom Robbins
Foureagles is offline   Reply With Quote
Old 12-17-2007, 01:14 PM   #6
mrmossyone's Avatar
Profile:  1975 Argosy 24
Collierville , Tennessee
Well I have received all products and I have finished installing them. I can say for sure that it definitely has more power, it will now smoke both tires and fishtail sideways when you put the pedal to the metal whereas before it would hardly spin the tire once before catching traction and launching. However this is not my main goal as the Hemi already had more power than I needed. My hope is that with all modifications the accumlative effect will be 3mpg increase( according to all literature I would get 6-7 mile increase so I'm hoping for a little less than half that). Only time will tell. I know it sounds great, not to loud but still very deep and throaty, so much so that I will have to discipline myself not to romp on the gas quite often. I will keep everyone posted as to my mpg increase or lack thereof.
Different strokes for different folks!
I never learned from a man who agreed with me.
Heinlein
mrmossyone is offline   Reply With Quote
Old 12-17-2007, 07:00 PM   #7
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
A big factor in mileage is the effort required to push the air out of the way. It is proportional to the sqaure of the speed and is also affected by the amount of surface area and aerodynamic shape. The easiest to modify is speed. Go from 30 to 60 and the effort required is quadrupled.
Moderate speeds have other safety and economic advantages as well.
I remember what my Uncle once said when I asked him why he was driving so fast. He said: "I'm nearly out of gas and I want to get to a station before I run out." He was a steam locomotive engineer so he might be excused.
"Not all who are laudering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is online now   Reply With Quote
Old 12-20-2007, 01:22 AM   #8
mrmossyone's Avatar
Well, I unforunately have had to add some more expense to my TV mod's. Whilst I was cutting the old exhaust out with and angle grinder w/cutting wheel I threw some rusted metal under my safety glasses and embedded it into my eye. It was hot so evidently it sunk right into my eye. The opthamologist first attempted to remove with sharp scraping tool, no go. Next he tried some fancy tweezers, no go. Next he says, "I'm going to have to drill it out", wooohhh. One of the more strange sensations I've ever felt, he numbed my eye before the drilling so it didn't really hurt to much but I could still feel the drill going into my eye, weird. Then he tells me " I know it doesn't hurt now but when the numbing drug wears off it will", great. He was right but now I feel better and apparently will not lose any sight because of the mishap. So after co-pays and meds I have to add a couple hundred dollars to the modification expense. From now on I will be wearing safety GOGGLES to do any type of power tool work and I advise y'all to do the same. I wish you all a good night but since no pain med's were prescribed I'm still awake and yapping at y'all. Later.
Heinlein
Old 12-20-2007, 03:22 PM   #9
CLOUDSPLITTER
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 52
Thumbs down Rats...
OUCH...been there,done that!!
Safety glasses on my head whenever there's a tool in my hand.
Hope all's well..
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 12-20-2007, 08:28 PM   #10
Profile:  2006 23' Safari SE
Brea , California
mrmossyone;
The old shrapnel in the eye trick.... I had a friend that carried a piece in his eye since WWII. He was in this tank (he was rather drafted into the Russian army) and some one blew the tank up........ oh well a story for an other time. Anyway to make a long story short, after having this in his eye for 50 years they got it our with a magnet.
Other subject.... I think the best way to get better economy it to drive slower..... not a pleasent thought for some ... but it has physics backing it up.
Glenn G is offline   Reply With Quote
Old 12-20-2007, 08:30 PM   #11
Brea , California
Incidently ...I hope also that your doing better.
Old 12-20-2007, 08:37 PM   #12
Profile:  1968 24' Tradewind
Mansfield , Georgia
I have a Ford 2006 Ford F-250 with trubos and a 100,000 Diesel powerplant / drivetrain warranty. Do after market mods to these systems suggested here void the mfg. warranty? The lit I read seems to say it does.
KeithC is offline   Reply With Quote
Old 12-21-2007, 01:27 AM   #13
mrmossyone's Avatar
All of these mods are fairly easy to reverse if you keep all stock components. I can't remember now which do and which don't, I think one might if they knew you'd had it on. The tuner can set the computer back to stock settings easily, the breather and throttle body spacer would take about 45 minutes to change back and the exhaust is clamped on w/o welds so can also be changed back easily. It's really to early to tell but even with me romping on the go pedal a good bit during this first post-mod tank of gas I have increased intown mpg by 1.3. I will know more after a few tank fulls and w/ me driving normally (which is much more conservative and easy on the gas pedal). I am very eager to see what I get pulling the trailor down to Destin for the can-opener.
Heinlein
Old 12-21-2007, 01:27 AM   #14
mrmossyone's Avatar
Thanks for concern guys, i'm feeling much better today. Later.
Heinlein
Optimum gas mileage John Tow Vehicles 31 11-21-2007 11:17 AM
Fridge power - gas/electric??? Tin Lizzy Refrigerators 7 05-10-2006 10:04 AM
Tow vehicle Gas Mileage ??????? searcher Tow Vehicles 79 04-02-2006 12:24 PM
What's your Gas (or Diesel) Mileage? 85MH325 Tow Vehicles 29 04-04-2004 07:40 AM
looking for F250 gas mileage examples blamejane Our Community 12 04-19-2003 10:18 PM
