Originally Posted by Aage
That's certainly an amazing vehicle! The only comment I can make with my limited knowledge of the subject is that every time a vehicle with a high suspension is considered for duty as a TV, it is always pointed out that the suspension needs to be lowered to have good stability in towing.
That does sound/seem like a reasonable suggestion. However, assume that modification wouldn't be made, & for the most part (aside form an upgrade in hitch classification, a good hitch, wd, & sw bars) - The vehicle would be used for towing, as shown & described.
I'm curious what members think or the engine, suspension, etc - Is there enough power? Is the overdrive a 'good' thing? It's a 3/4 ton,... too stiff? How about the EMU suspension? The tires? What kind of coolant upgrades would be necessary?
The above, including the lift (HCoG) would not be change. So, as it is (w/the exception of hitch, sway & wd equipment) - How would it perform as a TV, for something like a new(er) 23FB FC, to be towed across all different terrain?
Cheers!
~CLK
