Old 01-30-2018, 08:45 PM   #589
2014 27' FB Eddie Bauer
Orleans , Ontario
Originally Posted by waninae39 View Post
i have no problem pulling this trailer
fully loaded , my gas mileage goes down by 35%
Our last trip (albeit pretty flat and doing no more than 60mph) we managed about 16 mpg with our TDI
Shawn & Kara
Hamish is offline   Reply With Quote
Old 02-11-2018, 04:00 PM   #590
Glencoe , Illinois
Air suspension or no?
I’ve read the threads and several are years old and everyone’s use case is different.
We just bought a 30’ safari. 6500# dry.
Will buy an ‘11 or ‘12 CS. Should I get one with air suspension or not?
PS will take to Can Am for hitch reinforcement, brake controller, eaz lift elite and sway control.
ChiAir is offline   Reply With Quote
Old 02-12-2018, 05:05 AM   #591
2017 27' Flying Cloud
Pittsburgh , Pennsylvania
I was afraid the compressor would run all the time so I bought the normal suspension. It works fine but I’m wondering the same thing.
foster2 is offline   Reply With Quote
Old 02-12-2018, 06:56 AM   #592
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario
Send a message via AIM to TRIPPPIN Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
I have a 2014 ML diesel with the air ride and it works well. Towing my 25 fb I use sport mode which has increased dampenING over the comfort mode. The air ride keeps the vehicle level under load which helps with load distribution on the TV. I had my setup and hitch reinforcement done by Canam. They set it up in sport mode which maintains a constant height. I don't notice the compressor working ever and would not worry about it.
TRIPPPIN is offline   Reply With Quote
Old 02-12-2018, 11:10 AM   #593
bono's Avatar
Mountain View , California
If I understand weight distribution correctly, air suspension does not transfer any load (or any significant load). I would appreciate, if somebody correct me, if this is not correct.
BMW X5
SOB 33 ft trailer
Propride 1400
bono is offline   Reply With Quote
Old 02-12-2018, 08:04 PM   #594
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
You are correct. Air suspension does not transfer load from one axle to another on the TV.
wulfraat is offline   Reply With Quote
Old 02-13-2018, 07:21 AM   #595
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Ditto, hence the fallacy of installing rear air bags to pick up a squashed rear end to level, and assuming all is well.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 02-13-2018, 07:25 AM   #596
dasams's Avatar
Marin , California
I agree as I've adjusted my WD hitch many times trying to move weight forward with limited success. Having said that, I've been very happy with the tow performance of my Cayenne S.
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 02-13-2018, 12:02 PM   #597
bono's Avatar
Which hitch you are using? With ProPride I do not have problems transferring weight to the front axle up to the axle limit.
BMW X5
SOB 33 ft trailer
Propride 1400
Old 02-13-2018, 01:54 PM   #598
dasams's Avatar
Marin , California
Just to confirm, your X5 has air suspension, right? I used a Husky Center Line WD hitch with my 25 FC and am currently using an Equalizer with our 27 FC.
2018 FC 27 FB
2017 FC 25 RB Gone
Old 02-13-2018, 03:29 PM   #599
bono's Avatar
No, I do not have air suspension, just standard coil springs.
BMW X5
SOB 33 ft trailer
Propride 1400
Old 03-12-2018, 03:41 PM   #600
Centerville , Ohio
VW Touareg TDI Post Recall Update Towing
Has anyone towed with a VW, Audi or Porsche TDI after having the Recall Update performed?
I have a 2013 TReg TDI. I had not towed prior to the Recall Update. Last weekend I pulled a 3,600 lb trailer for roughly 20 miles on mostly flat Interstate (I-75) near Dayton, OH. I set the cruise at 64 MPH. The tranny was constantly shifting and running at 1,800 (probably 8th), then 2,000, 2,500 and even 3,000 RPM.
I haven't read where anyone experienced this in a pre-Recall TDI. I have about 2,000 miles on my pos-Recall TDI. The low gear shifting is entirely different when the engine is cold. It extends the upshift in at least the first 3 gears to 2,000 - 2,500 RPM. Do you think the shift changes are effecting towing.
I hope at least one of you has towed with an Updated vehicle.
Thx
TBDub is offline   Reply With Quote
Old 03-12-2018, 11:02 PM   #601
worried...happy...wo...ha
Knuff's Avatar
2015 25' FB International
Menlo Park , California
Yes, we have towed about 2k miles since the “upgrade”. The feel in general is somewhat negligible but fuel consumption is up by about 2 miles less per gallon. The only noticeable issue is the lack of controlled downhill low gear shifting, but I initially dealt with this using manual shifting. Got used to the new settings though and I am now using a situation awareness based strategy when driving downhill. Manual when I really need to keep the speed in check (not touching brakes), or otherwise I let “it go” if there is no traffic and the road is straight- the Pepper’s brakes are exceptional so this is no issue. So overall, I am still not happy about losing the downhill functionality and the gas mileage but thank you for the 10k in the bank....
Knuff is offline   Reply With Quote
Old 03-15-2018, 12:45 PM   #602
2011 20' Flying Cloud
Orlando , Florida
thanks Knuff. I see you are running with a later year Cayenne and were afforded the fix and $10k payment. Am waiting a while longer to learn others experience with their VW Touaregs before deciding how to proceed with a fix for my 2016. Was your $10k compensation standard payment for Generation Two year 2013 and after vehicles? I see the settlement protocol for 2013 model year and later is different than prior model years.
2011Cloud is offline   Reply With Quote
Input on Porsche Cayenne as TV (& 928??) Tom_T Tow Vehicles 154 07-08-2016 11:47 AM
Porsche Cayenne Diesel pman Towing, Tow Vehicles & Hitches 20 02-03-2015 04:38 PM
Porsche Cayenne V6 or s socool69 Tow Vehicles 27 01-21-2015 05:28 AM
Porsche Cayenne with Airstream & SOB cameront120 Tow Vehicles 7 06-23-2008 12:29 PM
