Old 05-18-2015, 12:38 AM   #29
TCwheels's Avatar
2011 20' Flying Cloud
Traverse City , Michigan
Porsche Cayenne, VW Touareg, Audi Q7 owners
I looked very seriously at the turbo diesel BMW x5 to tow our 20. But as funny as it sounds, I knew my DW would not be able to figure out how to drive the darn thing! All the driver interfaces are very complex - which, of course, makes them fun for ME - so for the sake of harmony I stayed with our Lexus.
WBCCI #7246 Michigan Unit,Texas Hill Country Unit (associate member), AIR #91367
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 05-18-2015, 02:24 AM   #30
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
Originally Posted by kevinkatz View Post
i love this thread because it just shows that you dont need a 3/4 ton truck to tow safely and enjoy it in style. and more than that, when you arent towing, you have a great vehicle. since i drive a porsche cayman s i had considered these options but landed up going with a bmw x5 diesel which is a similar genre of vehicle. it is great and appears to have similar results to those posted above. my concern was that if i was in the middle of nowhere the porsche dealer was probably going to be further away than the bmw dealer. may or may not be true. soon will be looking for another daily driver and may very well look at the porsche again.
The X5D is the daily driver, parked next to our LandYacht moho. however, my wife is not comfortable driving the moho, especially with the toad behind it so we are thinking about a 25 or 27' if the X5 will tow it. I'm guessing CanAm is a good place to start and will also talk with a NorCal guy (Vinnie's Airstream Repair) since Vinnie used to work at an MBZ dealership.
A recent discussion about a Cayenne alternative suggested we should not test drive the Cayenne or we would be spoiled! however my full warranty to 100K miles is a major consideration.
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 05-18-2015, 11:47 AM   #31
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
LolaT
You will be fine with the Nokian winter tires. Just check the load rating to make sure from a fully loaded perspective (towing), you will not overload the tires (unlikely). TireRack.com, if they sell them, will have the info or you will find it on the sidewalk. I run with Pirelli Ice and Snow (winter) tires all year round. I was not planning on this but they drive so well for a winter tire that I have no issue leaving them on all year. They will probably wear faster due to the low temp compound but other than that I don't expect any issues.
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 05-18-2015, 09:01 PM   #32
Ohiobrits's Avatar
Howard , Ohio
X5
TerraYacht, lots of folks on here towing with X5's and more recently with the diesel. I very seriously considered the X5 35d prior to settling on the Cayenne. A few observations from my research: -
- Payload will likely be your main consideration, take a look at the tire and load label on the frame where the drivers side door opens. You should have payload and axle loads there. Your AS tongue weight (minus maybe 100lbs or so that will transfer back to the AS with WD applied) will come out of that payload allowance. What is left will need to be enough for you and anything else you want to carry in the TV.
- The US version is rated to tow 6600lbs - from what I found out, because the receiver offered in the US (dealer install) is only rated at 6600lbs.
- The Euro version (built at the same factory in the US) is rated to tow 3500kg / 7700lbs - go figure.
- I read one account of bending of the commonly fitted aftermarket Invisihitch receiver when using WD. This was from a X5d owner over on Bimmerpost.
- The same owner also had the Dynamic Handling package which includes electronically adjusted dampers and sway bars. He indicated towing was a white knuckle ride with this suspension setup. He assumed there was some issue with the suspension software not understanding what was happening with WD applied. This was an assumption on his part but possibly a good one. It could have been a number of other things also such as too much weight transfer to the front with WD applied. I know from first hand experience - that does not feel good....at all.... He now tows with no WD applied due to his relatively light (500lb) SOB tongue weight.
The X5 I had picked out had the dynamic handling package since I found the regular steel sprung X5 a little soft for my tastes. In the end, the combination of factors above persuaded me to go with the Cayenne with good old fashioned steel springs. No regrets there
As you note - Can-Am would be the best resource to get advice on the X5. They may have experience with the various high tech suspension setups and how they work when towing. They will without doubt be able to get you set up safely with the X5 and a 25 or 27 footer.
There is a recent post from an X5 owner here for reference. He really liked his setup. I think he had basic steel spring suspension - if that matters.
If you decide to tow with your X5, go ahead and start an X5 thread with your findings....Good luck!
Old 05-19-2015, 12:49 PM   #33
worried...happy...wo...ha
Knuff's Avatar
2015 25' FB International
Menlo Park , California
Thank you all for the very interesting and helpful information. I think that it might be a good idea (and even only for our own piece of mind) to explore a hitch reinforcement on our Cayenne. Does anyone have experience with a local shop able to do the modifications?
Knuff is offline   Reply With Quote
Old 05-19-2015, 02:19 PM   #34
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
I have a 2011 Q7 3.0 TDI with the reinforcement described as futureproofing for 2' itis. I'm confident this could pull anything AS makes.
Q7 has a longer wheelbase and is rated at 6600lbs vs 7700 on the Toureg/Cayenne
If you're pulling more than the 22ft sport, I'd recommend the reinforcement to go with your WDH.
at 16FT
Pros:
4WD gets you out of muddy spots without chains
Engine loafs at highway speeds, for long distances and hills
Barely know the trailer is there.
"up to" 18MPG towing
More room for crap and passengers
- tow bigger trailers in the future
Cons:
- Tow Vehicle is longer than trailer
- Center of Grav. is definitely higher leading to slight lean on the twisties,
- Car is somewhat more pleasant for about town driving.
- Barely know the trailer is there.
timhortons is offline   Reply With Quote
Old 05-19-2015, 08:18 PM   #35
1972 23' Safari
Norwalk , Connecticut
Another happy camper with an X5 diesel. More than enough power to pull our 23'. And to answer another question in the thread, I have the Nokian WR G2 tires as well. Great tires!
Widget is offline   Reply With Quote
Old 05-19-2015, 11:45 PM   #36
TerraYacht's Avatar
Ohiobrits: Thanks for the detailed response. My 2012 has a "factory" hitch that was installed at the distribution center in Southern CA, and I have the air suspension but not the dynamic handling.
When I return from vacation (could not take the moho or X5 to Hawaii) I will check the stickers and then contact my dealer's "BMW Genius," a new position for techie questions and help, to find out why the difference in load ratings: different hitch design or different lawyers?
Cliff & Andrea,
Old 05-21-2015, 01:44 PM   #37
2015 25' FB Flying Cloud
Sandy , Utah
I just purchased a 25FB and have a 2015 Audi Q7 TDI. I work for Audi so I know that it is built on the same platform and has the same basic engine as your Cayenne. I talked with John at Can-Am and they had not done any work on an Audi that they had pictures of. I am 3000 miles from there anyway. I have an excellent fabricator in our shop but need photos showing where the hitch reinforcement mounts forward of the spare tire well. Do you have any photos of your installation? I would really appreciate it. I pick up the 25 in two weeks and need to get this done.
rocco52 is offline   Reply With Quote
Old 05-21-2015, 05:40 PM   #38
Ohiobrits's Avatar
Howard , Ohio
rocco52, check out this thread, post 4, 3rd photo is of a Q7 I believe. The other photos show the receiver end reinforcements. The attachment point is the same for Touareg/Cayenne/Q7, just further forward for the Q7 due to the extra wheelbase.
Old 05-22-2015, 07:29 AM   #39
Pivot429's Avatar
2014 25' FB International
Dayton , Ohio
Yup, Ohiobrits is correct. Third photo is my 2011 Q7 TDI. Can-Am did the work. I did not have the tow package so they installed the rear bumper, hitch receiver and reinforcing strut from the receiver to the plate welded where you see it at the rear axle.
Pivot429 is offline   Reply With Quote
Old 05-22-2015, 08:07 AM   #40
Sandy , Utah
Thanks for the info and photos! This will give our shop foreman everything he needs to know. He loves doing "out of the ordinary" things.
Old 05-22-2015, 09:16 AM   #41
Pivot429's Avatar
Dayton , Ohio
No problem. I can snap a few more if you need any additional information. Btw, I am towing a 25 ft International with E-Z Lift 1,000 lb bars and Husky sway control. Couldn't be more happy with the set up. The 3.0 TDI 8 speed is so smooth and powerful. I get 15-16 mpg towing.
Old 05-22-2015, 11:38 AM   #42
Ohiobrits's Avatar
Howard , Ohio
rocco52, you mentioned on another thread you will look to redistribute weight to reduce tongue weight. I have a thread on "FB Move Batteries to rear" which you should be able to locate which details my mod to do just that for my 27FB. There are some actual weights in the thread that I measured for various modification scenarios. You may find it useful. As folks noted on your other thread, don't reduce tongue weight too much or you will have sway issues.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Input on Porsche Cayenne as TV (& 928??) Tom_T Tow Vehicles 154 07-08-2016 12:47 PM
Porsche Cayenne Diesel pman Towing, Tow Vehicles & Hitches 20 02-03-2015 05:38 PM
Porsche Cayenne V6 or s socool69 Tow Vehicles 27 01-21-2015 06:28 AM
Porsche Cayenne with Airstream & SOB cameront120 Tow Vehicles 7 06-23-2008 01:29 PM
