12-10-2017, 06:29 PM
2018 27' Globetrotter
Chandler
Please help: 2018 Globetrotter => 2018 F-150 Lariat SuperCrew Confirmation
Hi,
First post - seeking your help in confirming our proposed 2018 Globetrotter tow vehicle. We bought the trailer yesterday, and will be buying a tow vehicle this week.
According to the Airstream website, the Globetrotter's hitch weight is 820# and GVWR is 7530#. (We don't yet have an actual weight, but trailer does have second A/C and solar electric.)
I couldn't find the ProPride 3P hitch weight on their website, but other posts suggests that it weights in at about 150#.
Today, I found a 2018 Lariat Supercrew (145" wheelbase) 3.5l EB, 3.55 axle, with Max Trailer Tow Package. The yellow door tag says "The combined weight of occupants and cargo should never exceed 1649#".
Assuming my wife and I are the occupants (< 400#), it seems to me that the cargo capacity will be 279# (= 1649# - 820# - 400# - 150#).
Did I get that right? We've purchased the Globetrotter, and are searching for a tow vehicle which can pull the trailer and will be a daily driver.
Thanks... Duncan
12-10-2017, 07:40 PM
2009 25' FB International
Tavares
Welcome to the forum. It's good to have you on board!
I will let those who have a ProPride hitch and/or a F-150 (I have neither) answer your questions but I do know that such a hitch will transfer some of the weight to the axles of the trailer giving you more than your 279# payload capacity.
BTW congrats on your Globetrotter! Enjoy!
12-10-2017, 07:42 PM
1995 25' Excella
xxxxx
, xxxxxx
Airstreams TW number is for an unloaded trailer with empty tanks.
I carry far more than 279 lbs of gear in my truck on any camping trip no matter how short or close to home.
12-10-2017, 07:58 PM
2002 30' Classic S/O
Fleming Island
The Airstream published tongue weight is not necessarily realistic. For stability, 10%-15% of trailer gross weight is suggested. I use 12.5% as a ballpark which suggests that you should plan on about 940# of tongue weight, some of which, as Hans627 suggested, will be transferred to the trailer by a good WD hitch.
When I had an F-150 (a 2006), maximum tongue weight and maximum trailer weight were mutually exclusive. Determine if that is true for you, and if so, take your F-150's maximum trailer capacity, subtract the 1649# payload assuming you will max that out with passengers, tongue weight and cargo and see how that compares to your 7530# trailer GVWR. If that works out you will probably be OK (my opinion is worth what you paid for it). The proof of the pudding is to get weighed and compare the numbers to your axle ratings.
Al
You cannot reason someone out of a position they have not been reasoned into"
12-10-2017, 09:01 PM
2002 25' Safari
Dewey
The published numbers are starting points and then you start adding on the extras. Water, propane and stuff in the trailer add to the hitch weight and fuel in the TV is considered cargo weight in most cases. The hitch will move some of the weight back to the trailer wheels, but how much?
Lots of info to digest...
Congrats on the GT
Richard
12-10-2017, 10:50 PM
Vancouver
, British Columbia
Originally Posted by ddrg
Hi,
Thanks... Duncan
Good enough to start.
The tongue weight may be heavier, some weight will be transferred back tot he trailer.
The real question in my mind is how you will travel. My wife and I travel with us in the vehicle, and not much else. Two light bikes, a camera, a tablet, and jackets. Others carry BBQ and tank, camp griddles, camp furniture, one (or two) portable generators, additional fuel, firewood, screen rooms, boats and motors, ...you get the idea. If you are travelling relatively light, you are in the range. If you plan to fill the pick up bed with equipment, you need to think about your total payload.
Nice trailer. Congratulations.
12-10-2017, 10:57 PM
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Having a similar configuration, with an International Signature 27FB and a RAM 1500 with a towing package, I will tell you that Airstream underestimates actual towing tongue weight, and most dealers have no clue about towing capacity vs. load capacity.
Just so were clear, our truck has had no difficulty whatsoever towing Rocinante over the Rockies and back again. Nothing terrible is likely to happen if you pick the truck you mention above. However, you may be frustrated, as we were, when you realize just how close you are to maximum load capacity even with an empty truck bed.
So, because of tongue weight and load capacity, I suggest you consider a 3/4 ton truck. That doesnt mean it has to be diesel, as engine capability has never been an issue with our RAM.
A 3/4 ton will have load capacity to spare, while our RAM 1500 is right at the limit of its load capacity.
Congratulations on your purchase, and may you have many happy camping and towing experiences, regardless of your choice of tow vehicle!
12-11-2017, 12:28 AM
Vintage Kin
Fort Worth
The weight distribution hitch will re-position the tongue weight from the single point of the hitch ball to the three points of the tow vehicle axles and the trailer axles.
Hitch the trailer and the front end gets light in comparison to its unhitched value. A 1,000-lb TW winds up as approximately 390-lbs to each TV axles. Payload, by contrast, pretty much all sits on the rear axle.
There isnt an Airstream cant be hauled with a half ton. The divisor is how much junk one carries in the TV.
The vapors and fainting spells around here about exceeding an abstract limit (payload, etc), not concrete limit (axle/wheel/tire) are tiresome. And without merit
An Expedition would be a better choice due to a more stable design (fully independent suspension).
Worrying over weight is like worrying over paint color. Its not central to what produces the best towing combinations. Its a problem solved with the quality of the hitch lash up.
Short answer: Yes.
The more important question has to do with whether it is best suitable for solo duty. An empty farm/ranch vehicle isnt anyones idea of a good bet for family transportation on a wet road. Congenital instability.
Ad copy sells pickups. Forms unwarranted basic assumptions.
12-11-2017, 03:56 AM
2019 30' International
Pennsylvania
, Pennsylvania
I have towed with a '15 F150 XLT 4x4 crew cab 3.5 ecoboost, pulling a '16 flying cloud. I have also towed the same flying cloud with my '17 F250 XLT 4x4 crew cab 6.2.
I'll never go back to an F150.
Did the F150 pull it? Yes
Does the F250 pull it? Yes
However, there is, in my experience, absolutely no comparison between the two in terms of comfort level going down the road....not even close.
F250/F350 for the win
Go BIG or go home.
12-11-2017, 04:20 AM
2019 27' Tommy Bahama
London
, Ontario
Hi Drv
During our handling testing on the racetrack we find the opposite of the above comment.
In a way there are two types of handling. One is straight line on the highway, awareness of the Airstream so to speak. The other is accident avoidance capability curvy roads etc. The F250 has a great deal of mass and vague steering so you dont feel the trailer going straight down the highway. However there is not much depth to the handling, try to get one to change direction in a hurry and it can become a real handful. Then all that mass carried high in the air and the vagueness of the steering become the challenge.
With two changes, shocks & tires an F150 can have better straight line handling than a 250 and more evasive capability. Dramatically more in all those solo miles without The Airstream.
Few of our customers bother with the tires and shocks since if the 150 is connected properly you get good straight line stability anyway. It is just very few are connected properly.
On the 150 make sure you get the 20 wheels, unless you get the heavy payload pkg which comes with LT tires.
If the tow vehicle is also a daily driver there are plenty of non pickup options as well.
What do you drive now?
Andrew Thomson London, Ontario
"One test is worth a thousand expert opinions." Tex Johnston, Boeing 707 test pilot
12-11-2017, 04:32 AM
2017 27' Flying Cloud
Fort Worth
^^^^^^^^What he said!^^^^^^^^
I'm the guy (or should I say my wife is the gal) that he describes in the last part of his paragraph. Just bought an F-250 after selling my Tundra. The Tundra was a dream and pulled just fine, but no room for the kitchen sink!
12-11-2017, 04:40 AM
ShinyPete
2014 27' Flying Cloud
Bushnell
Ddrg-
I am firmly in the camp mentioned above that any Airstream made can be towed by most) 1/2 tons. However, there were/are some 1/2 tons made that are simply not suitable-v6 work trucks with 3.11 gears, etc. that barely tow a lawn mower trailer, etc. If the Lariat you're looking at truly has MaxTow, it may even have a 6.5' bed over the 5.5 (longer wheelbase-more stability), and probably has an 8 or 10 speed trans where our '15 only has a 6 speed.
Our experience towing our Pete, a 27fb twin (same floorplan and likely weights as your new GT) with a 2015 F150 XLT Crew 4wd MaxTow has been great. We have 1907 lbs of payload, as the XLT is less loaded up with options vs the Lariat, and 18" wheels with XL rated tires. We also use a ProPride that we scored used, and the rig feels welded together in all towing conditions. As in, it feels like we are driving a longer truck. We get no tail wag from passing trucks on interstates or on 2 lanes going the other way. Great weight distribution, level rig, and enough capacity to haul the 2 grans with us when they go and a lot of gear in the bed.
The key (as already mentioned) is a great hitch setup. Take your time, do it right, play with the settings, run the tires at max psi when towing, etc. Lots of great reading on here to study while you prepare.
Hope this helps.
12-11-2017, 05:07 AM
Apollo Beach
My "opinion" is if you are adding up payload, you don't have enough! I'm adding up my payload every time I hook up my 25' Airstream and its not fun. My truck's payload is 1400#. I can't even carry any tools in my truck when my Airstream is attached or I will exceed my trucks GVWR. When my grandkids want to come along, I start by removing the generator and spare propane tank from the truck to save 150#, I change my propane tanks to 20# tanks to save 50#, I remove my front stabilizer jacks from the Airstream to save 30#. I removed the rear headrests and floor mats to save another 10#. That's 240#, are we there yet? Do I need to remove the spare tires at 55# each? Do I need to only fill the truck's fuel tank half way and stop twice as often?
You do not want to be in my position of removing items from your rig so you can bring a friend along. My next truck will have a MINIMUM of 2000# of payload so I can stop tearing my rig apart to stay below GVWR.
Is my concern about payload excessive? My truck's DOT sticker clearly states maximum GVWR, FAWR and RAWR and the sticker does not say choose "two". I choose to stay within all "three" DOT weight ratings on my truck and will remove whatever is needed to be under that weight.
If you want a truck that is short on payload, you can buy mine so I can go buy one with more than enough payload.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
12-11-2017, 10:54 AM
2013 30' Classic
Greenwood
, Mississippi
I think it will all work out great.
I tow a Classic 30 with a Tundra that has 1,455# payload and an Equal-i-zer hitch.
You have a lighter trailer and more payload.
As was stated earlier, some weight will be transferred to the trailer's axles, but you are in the ballpark.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
12-11-2017, 11:50 AM
1976 31' Excella 500
Chappell Hill
I'd think hard about a half ton pickup with a 28' . 3/4 ton minimum would be my advice just for peace of mind.
12-11-2017, 11:51 AM
Pennsylvania
, Pennsylvania
For the OP, buy once, cry once. I towed our FC25A with a 2015 F150, and now tow with a 2017 F250. Heavier truck, heavier suspension, bigger brakes, no funny feel to the steering, actually quite responsive hitched or unhitched, and best of all.....
12-11-2017, 01:05 PM
2016 30' Flying Cloud
Lake Oswego
, Oregon
We tow a 30' FC with a F150 and a Blue Ox w/d hitch with no issues. The Lariat is available with both the max tow package and the max payload package. With both packages I think you could tow and carry just about anything you need.
12-11-2017, 01:45 PM
Lake Oswego
, Oregon
Andrew, for an F150 what shocks and tires would you recommend. Thanks Gary
12-11-2017, 06:08 PM
SophieHaus
2018 25' Flying Cloud
2007 25' International CCD FB
Grand Junction
I just purchased a 2018 25 foot flying cloud with extra awning packing and solar panels. The coach has a GVW of 7300 pounds. This is the weight that the coach can handle before the axles brake. The tongue weight is 832 pounds and I believe that includes full propane tanks. I've heard that the average person will tow this coach at about 6300 pounds. My F150 has a GVW of 7000 pounds and that includes a full tank of gas and 150 pounds for the driver. It is a 2015 Lariat FX4 with the 5.0 V8, six speed automatic transmission and a 3.31 rear end. I just towed my Airstream 2500 miles across the country and the truck towed it beautifully. The equalizer hitch with 4-point sway control was awesome. Winds were fierce, semis were plentiful and I did a lot of passing. I had plenty of power and complete handling control. Your Globetrotter is only a few hundred pounds heavier. So you have my opinion and experiences.
12-11-2017, 07:07 PM
Vancouver
, British Columbia
DOT regulations apply to commercial carriers. Does that include you?
Your door jamb sticker is a FMVSS sticker.
If you are going to follow the commercial regulations, fine, but why stop at GVWR? Carry copies of driving test results and driver training records, keep a detailed driver’s log, maybe get a commercial license, get a DOT number for the side of the truck, get placards for any hazardous materials you are carrying, etc.
If that all sounds like too much for a recreational vehicle and non-commercial driver, then maybe rethink your focus on GVWR as the holy grail, while still respecting axle and tire limits. Those are real. Removing floor mats to bring your TV weight down sounds just a little extreme.
