Old 11-16-2006, 01:43 PM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
PCM programming or chip for more HP and MPG
Anyone have their TV pcm or computer programmed for more mpg and or HP and Torque?
What brands
what are your results?
'77 Sovereign Intl 31' CB
Old 11-16-2006, 02:43 PM   #2
dbradhstream's Avatar
2006 28' Safari SE
Winter Park , Florida
I've got an '04 Chev Avalanche with the 5.3L engine and have done a number of things to it because my AS is right at the limit of what the Avvy is rated to tow ... I'm trying to buy some time until I can buy one of the new diesel TVs that are supposed to be a year or two away. Anyway, I've installed:
1) tranny oil cooler;
2) Diablo predator programmer;
3) Corsa cat-back stainless steel exhaust;
4) Brute force air induction kit.
If there is a mileage benefit, it is negligible. It definitely sounds better (i.e. "badder") without being too loud b/c I chose the Corsa "touring" exhaust which is quieter than other exhaust systems. It definitely has more power in the mid- to upper-RPM ranges. When I hit about 2500 RPM it really takes off. However, at lower RPMs and towing I haven't noticed a great difference, so I don't think the torque benefit is significant. Bottom line I would say (i) horsepower/fun factor - UP; (ii) torque - Not much change; (iii) gas mileage - Not much change.
'06 28' Safari SE / '08 Chev 2500HD Duramax
'64 Me / '60's-ish wife / '90's kids / '06 Black Lab / '02 Poodle / oh, and a horse, too.
GO GATORS!!
dbradhstream is offline   Reply With Quote
Old 11-16-2006, 05:05 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I did. I used:
www.pcmforless.com
Pretty satisfied. Noticeable difference and my 96 Chevy sedan didn't have tow/haul, so they locked to torque converter sooner, so I could tow in OD. Put many thousands of miles on it with that config and it worked well.
More Power Needed scotta Airstream Motorhome Forums 48 04-30-2003 08:47 PM
