Old 06-19-2011, 08:55 PM   #15
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by thecatsandi View Post
No,
I have tow/haul that prevents overdrive and uses a lower gear for starting out.
The tow/haul setting on my GM van doesn't change the gearing. What it does do is change the shift points. For all intents it delays the upshifts to keep the engine at optimum revs to give you more power. Likewise the downshifts come sooner and at higher speeds, again to give you more power. For example the upshift to OD when I'm in tow/haul doesn't occur until I get over 50 mph.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-20-2011, 07:49 AM   #16
dznf0g's Avatar
Oswego , Illinois
Jack
This is true, but it does some other things, like raise the line pressure in the trans for more firm shifts and clutch apply pressures. I also boosts the alternator output for better trailer battery charge. In the newer trucks, it also provides for a different calibration for stability control as well as a hill start assist feature. They DO NOT change the gearing.
Question: Can you keep the refrigerator on while towing? Scott J-24 Refrigerators 59 11-25-2015 08:53 PM
Towing 2011 Classic 34 With Chev Duramax RV Doctor Tow Vehicles 13 04-17-2011 10:21 PM
Towing with a 1996 Roadmaster wagon Globie64 Tow Vehicles 7 03-30-2011 11:56 PM
Towing and oil analysis pappy19 Tow Vehicles 12 03-23-2011 08:57 PM
