Old 07-12-2010, 08:36 PM   #1
Rivet Dude
1972 21' Globetrotter
1987 34' Excella
yep, still on the road , On The Road
Question Over kill, or just over the top!
Greetings:
So, I have the new, to me, 72 globetrotter. 21 feet of vintage, in amazingly good shape.
My TV. 2002 dodge ram 2500, 6 cylinder diesel, 5 spd. auto.
Overkill, or just over the top?
Will I shake the trailer apart?
Will my rivets come asunder?
PO gave me reese hitch w/all the trimings. Seems safe enough, just do not want to damage anything.
Would a hundred gallons of water in the back of the truck smooth things a bit.
Thanks for any suggestions.
Airjeff
airjeff is offline   Reply With Quote
Old 07-12-2010, 09:27 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
If you use the Reese, make sure you have #600 spring bars rather than the beefier ones cars need....
You should be just fine w/ that tow vehicle - the 3/4 ton pickups ride pretty reasonably with the 400 lbs or so of tongue weight.
We pull our 71 25' Tradewind with a 1996 4x4 F250 diesel crewcab - no issues so far, and the ride is quite reasonable.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 07-12-2010, 10:07 PM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
We tow a short, light weight trailer with a 3/4 ton truck. There is no need weight distribution or sway control IMO with your trailer/truck combo. As an observation, when we travel with water tanks full (trailer) stuff seems jiggled around less.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 07-12-2010, 10:11 PM   #4
Janet H's Avatar
1964 26' Overlander
OlyPen , Washington
Images: 90
BTW - congrats on your new toy
Old 07-12-2010, 11:44 PM   #5
1978 31' Excella 500
Goose Creek , South Carolina
TV is a bit over the top but then again, I pull my 31' with a 04 4x4 Quad Cab Dually with the Cummins diesel. In my case I have pulled thousands of miles without WD or sway control, since I felt that the stiff springs with dually tires would be to harsh on the AS, but made sure that the brakes are working. I pull my work trailers without WD and sway and they weigh twice as much as the AS. IMO a full fresh water tank helps to keep the center of gavity low and over the axels.
Holzarbeiter is offline   Reply With Quote
Old 07-21-2010, 12:11 AM   #6
Crazy Montanan in Texas
MrBeast's Avatar
Houston , Texas
the WD hitch is not nessacary for your combo and me personally, I wouldnt run it.
with my 85 CC dually chevy I never ran a wd hitch pulling a 25' white box that was way heavier than an AS and loaded down signifigantly too, never had an issue 1. And there were a couple of times passing I hit 90 mph.
Try towing a few times with out the bars and see how you like it.
"When the people fear the government, there is Tyranny; when the government fears the people, there is Liberty." - Thomas Jefferson
MrBeast is offline   Reply With Quote
Old 07-21-2010, 05:29 PM   #7
Rivet Dude
1987 34' Excella
First Short Road Trip
So I pulled the trailer on the freeway for the first time. Oh my. My neck still hurts from the front/back rocking of the truck. A full eight miles. To get the trailer home, I used the full hitch set up, back to the parking spot, used no sway or load levelers. Equally as bad. I really do not think it is safe. I am thinking shocks, and will have the mounts checked at the same time. Any ideas or suggestions would be appreciated. Of note, the truck/trailer do not ride level, slightly raised at the hitch.
Old 07-21-2010, 06:15 PM   #8
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I tow with a dodge the same as yours. I reccommend that you do use weight distribution, the 600 lb bar suggestion is good. The WD will do a lot to stop forward and back pitching on bad freeway expansion joints and make things all round more comfortable.
Ideally the trailer should be set up level, even with the single axle. If you ever sleep in a res tarea or truck stop you will be more comfortable and your refrigerator will thank you also.
The Globe trotter tongue weight could actually go as high as 700 or more pounds with full propane etc. I have a 70 Globetrotter and the tongue is amazingly heavy for a trailer of this size.
Since the single axle tends to bounce more it is better to stow anything you might carry on the floor toward the front
The truck will NOT beat the trailer to death. Have towed many miles with smaller trailers. The diesel will last forever, well almost . with proper care. Currently at 553,000 on mine
I do have a fair amount of weight in my truck, extra 50 gallons of fuel plus lots of tools .
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-22-2010, 12:43 AM   #9
MrBeast's Avatar
Houston , Texas
How much pressure are you running in your tires?
I am pretty suprized you had so much of an issue, I am wondering if the reason I dont with mine is that because it is a dually?
Old 07-22-2010, 01:47 PM   #10
Rivet Dude
1987 34' Excella
Tire pressure, no way. I just had the front end aligned. They surely checked the pressure then, right? So, I did this morning. 45 lbs, front/rear. Half mile later, had it up to 75, recommended on the sidewall. The trailer I checked before I towed, she was right on.
Old 07-22-2010, 08:43 PM   #11
MrBeast's Avatar
Houston , Texas
Funny how low tire pressure can make a rig all kinds of squirrly aint it!
Old 07-22-2010, 09:57 PM   #12
richinny's Avatar
2011 34' Classic
the sidewall psi is a rating, not a recommendation. the recommendation is usually on the truck door post and is based to axle load.
Ricky
Old 07-22-2010, 10:13 PM   #13
richinny's Avatar
2011 34' Classic
on searching through google there might have been a dealer bulletin on tire pressures. i'd call a dealer for a printed recommendation and check for recalls.
Ricky
Top 20 Contributors, Top 10 Forums/Threads & New Stats Info.... Andy R Our Community 7 04-01-2008 10:19 PM
Rant! Over kill Ultradog Off Topic Forum 37 04-29-2007 11:04 AM
Kill File? guy99 Forum Admin, News and Member Account Info 14 04-11-2007 06:54 PM
Something new to kill your time. cosmotini Our Community 1 08-04-2006 06:00 PM
Kill A WATT™ 53flyingcloud Our Community 6 06-20-2003 01:08 PM
