07-19-2018, 08:21 PM
1994 30' Excella
Truckee
Options on a New Tow Vehicle
I'm close to buying a new RAM 2500 and came up with two questions. FYI this is for towing a '94 30' Classic
1) Axle ratio 3.73 vs. 4.10 (pros and cons)
2) Alternator 100 amp or 220 amp (pros and cons)
Thanks for your input.
07-19-2018, 08:46 PM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
I have a Ram diesel with the 3.73 rear gearing and it is way more than sufficient for all grades from my driveway to the Rockies. The engine is rated at 400 ft lbs of torque. Check your stats if equipped with the gas engine.
As for the alternator, my choice was between 180 and 220. The pricing was a $100 difference. I ended up with the 180 amp unit and it has been quite satisfactory.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
07-19-2018, 09:22 PM
1994 30' Excella
Truckee
Thanks, I meant to say 180 amps not 100. You answers were what I wanted to hear.
07-20-2018, 12:00 AM
2007 27' International CCD FB
San Diego
How much solo driving vs towing will you be doing?
The 4.10 will surely give some more grunt at the wheels. Rarely talked about, but it will also give the engine more leverage when engine braking down a hill.
07-20-2018, 04:36 AM
Dazed and Confused
Hillsburgh
, Ontario
Gas or diesel?
New 2018 or 2019 as they may have different transmissions with different ratios, (gas and diesel at least have different transmissions)
Optional tire size?
In future, in order to recieve the most accurate answers please specify as much information about your TV as possible.
Cheers
Sidekick Tony
07-20-2018, 04:51 AM
2014 25' Flying Cloud
New Ashford
, Massachusetts
Diesel option provides 3.42 ratio as standard. Never had an issue with power. Lower the ratio better the fuel mileage. We average 16.5mpg towing (65mph) 21-22 no problem without the trailer. It is my wife's daily driver. She gets about 16 around town.
We have a 2017 RAM 2500 Cummins, duel 220Amp alternators. I have added additional led lighting and an onboard compressor. We also use the onboard inverter (150w) to recharge items while driving down the road.
Joe D
07-20-2018, 07:21 AM
2016 28' International
Sioux Falls
, SD
We have a 2017 Ram 2500 w/ 3.42 rear end. Tows our 28’ effortlessly.
The gearing is perfect and keeps the fuel milage manageable at around 17 mpg average towing.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
07-20-2018, 07:39 AM
1994 30' Excella
Truckee
Looking at a 2018 gas 6.4L with 275/70-18 tires. Solo driving averages <40 miles/day mostly stop/go freeway. Towing the A/S about 5k/year
07-20-2018, 08:48 AM
2014 28' International
Blacksburg
, Virginia
Ram
Great choice I might add. I have the 4.10 gears, and 220 amp.
It will absolutely pull your house off its foundation with the 4.10s.
It is awesome here in Virginia, ( and NC & W.VA) where we have some pretty good sized hills. Nothing like the mountains you have in California.
The 4.10 lowers top speed. That's okay for me, I don't run 75-80, even when I don't have the AS. Roads are not that straight around here anyhow. If I want to go fast, I take the Lexus IS 350. ( Hmmmm maybe that could tow the AS? Rear wheel drive ) Ummm, Nah,,,,,
I tow at about 63 MPH, and that is 1900 RPM. From what I have read, supposedly it is a little high compared to what others have posted on the Dodge forum with 3.73.
Right about 60-63 miles per hour is a 'sweet spot' and the truck will run all day ( and night) pulling our 28' AS. No strain on any hill. No constantly shifting gears. I always disliked that 4 grand rpm thing in the gas engine truck I had before. Undue stress isn't good.
Now if I can keep my foot out of the throttle, and limit myself to 57mph, I have achieved 16 mpg, with AS on the twisties in W.VA.
You cant do 57mph on the interstate though. Slower is better with a 4.10, but you can't always do that.
4.10 is great here in the mountains of Virginia. I think if you drove a 4.10 you would say 'Holy Cow' on how easy it accelerates, even with your classic ! If you are running across the flat lands, go 3.73.
Great choice,
Have a good one!
Ra & Chelle
For my next trick, I will use my new AS & Dodge Ram CTD to make this pile of money disappear.
07-20-2018, 09:08 AM
2013 31' Classic
billings
, Montana
17 ram 4x4..6.7....3:42... 20-21 empty...14..pulling our 13 31’ Classic...does good...if a 392 hemi..go with 3:73
07-20-2018, 09:13 AM
2013 31' Classic
billings
, Montana
4:10 for farm trucks...3:73. If hemi.....3:54 if 6.7 cummins .....100 amp is minimum
07-20-2018, 09:28 AM
2017 28' International
Jim Falls
, Wisconsin
That's not very much towing in a year.
I would go with the 3.73 axle ratio for gas mileage.
As the alternator I don't see why you would need much more than standard.
I would also consider the Ford F250. If you check out the power capability of the Ford F250 and the Ram 2500 there is a real difference. The Ram 2500 gas does the gauntlet test in about 9 minutes. The F250 gas in 8 minutes.
If you were going with the diesel then the Ram 2500 is the most reliable with the cummins. It also gets better gas mileage than the F250 diesel.
I drove a Ram 2500 diesel because that's my next pickup when I retire. Nice truck. Wouldn't want it for a daily driver for what I do.
How much does your AS Classic weigh? Why not a beefed up F150 with Ecoboost? I get 22.5 to 23 mpg on daily driving as an appraiser. The ride is great. And I tow a 28' with no problem. But I can see if you have a payload issue for going with the 3/4 ton and your AS weighs over 9,000 lbs.
Big decision. Happy Camping.
07-20-2018, 09:37 AM
San Diego
Doesn't look like you'll be doing much driving under tow. I'd only opt for the 4.10 if you were laden or towing heavily majority of the time.
Thought there are other considerations if they apply.
1) What type of equipment and "stuff" if any are you going to fit to your truck? If mostly empty, go for the standard ratio.
2) Will you ever upsize your tires (i.e. larger diameter). May be a reason to go for those 4.10
3) While the 30' is big, they were far lighter in '94. Will you ever get a newer heavier trailer? Though at only 5k miles per year, still would get the 3.73.
Yes to the big alternator for capacity on future electronics and upgrades.
07-20-2018, 10:18 AM
2019 30' Classic
Canfield
, Ohio
Talking about alternators - I went through Ford's fleet program. Find a dealer that has someone that deals with company purchases. My fleet dealer had me buy the larger alternator as part of Ford's snow plowing package. The cost was $80 more.
That qualified me for a $1000 snow plow credit for up to anything I buy for the bed. It paid for half my cap and they took it off the price of the vehicle.
Just sayin, maybe Chrysler has a similar program.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
07-20-2018, 10:41 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The most the trailer is likely to pull is 30A before the fuse blows. Normally you will max out around 7 to 10A due to loss in the wiring. That's true of pretty much any truck.
The alternator output is rated at a fairly high RPM. At normal cruse you might only see 1/3 of the max rating. Yes they get smarter about this stuff as time goes on. You might have some sort of voodoo that helps that out a bit.
Bottom line - you aren't going to get a lot of use out of the bigger alternator.
07-20-2018, 10:48 AM
2016 27' Flying Cloud
Olympia
I'd like to make a pitch for RamBoxes --- very convenient, especially for towing.
Richard Wills, Olympia, WA --- WBCCI 8873, WL7Z
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
RIP "BigDog": M Harlequin Great Dane, 150 lb
"St. Rocco": M Black Great Dane, 150 lb
07-20-2018, 10:49 AM
2009 25' FB International
2018 27' Globetrotter
Tavares
Ditto on the RamBoxes!
07-20-2018, 11:31 AM
2019 25' International
Washington
, Washington, D.C.
I agree with Dacquenzer regarding at least looking at a “beefed up” F150. I went with gas-powered Lariat trim line for the options and rated towing capacity at 11,200 pounds. My payload is 1374 which has been plenty for me as a single person. Very comfortable, great gas mileage and love the 37 gal tank. Drive it with 25’ AS from DC to Salem and handled everything (including the dreadful twisty, steep switcbackey Route 36 in northern CA) with no strain, even aplomb! The 10 speed transmission is a godsend for mountain driving.
07-20-2018, 12:09 PM
2013 31' Classic
billings
, Montana
3.73. Ratio ..good all around...
07-20-2018, 02:35 PM
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
The F-150 feedback is encouraging. Ours is equipped
Like yours have not towed the 25 yet. I wanted the 250 diesel wife and salesman talked me into the max tow 150. If the ecoboost turns into a ecopuke in the hills it will get traded. So far I love the truck
