Old 08-19-2011, 03:01 AM   #15
sandlapper's Avatar
1993 34' Excella
York , South Carolina
IMO, wheel base is a major component to safe towing with peace of mind. Some tow with short WB set up very carefully but it is not optimum. A 1500 Silverado, ideally long bed, with the 6.0 engine & 3:73 rear end & the other towing options should be a good TV.
Chevy trucks are sprung soft for a good ride. This is good for the AS also but you will need some weight distribution. Spring bars are part of the WD system. Depending on their size, some "spring" more than others. Their job is to take weight off the rear of the TV, distribute it to the trailer & the front of the TV, and still flex. The thicker the bar, the less the flex. Less flex makes is hard on the AS, it likes a soft ride. I'm no expert but would think you would need maybe 800# bars with a 1500 TV.
Safe & happy travels. John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Opinions requested: '60 Tradewind saranesler Trailer Values 7 09-11-2013 08:47 AM
Vent cover opinions. ROBERTSUNRUS Roof Vents, Skylights & Fans 17 09-11-2011 01:07 PM
2nd Opinion(s) on '73 Safari my3sonsdad Trailer Values 16 07-22-2011 07:31 AM
Opinions Wanted - 1958 Serial Number Plate mello mike Exterior Restoration Forum 9 05-02-2011 09:57 AM
Wanting opinions on first purchase. tmuffie Airstream Trailer Forums 15 04-30-2011 10:34 AM
