Greetings pjmltravel!
Welcome to the Forums and the world of Vintage Airstream ownership!
Originally Posted by pjmltravel
Hello Airstream community!
We are brand new to travel trailers in general and are buying a 31" Sovereign with some original interior and will be finishing it off with an eye to keep the weight down. ( As longtime tent campers, we are not used to a lot.)
Depending upon its year of manufacture, your
Sovereign will likely exceed the factory trailer tow rating of your Custom Cruiser empty. My '64 Overlander has an empty weight of 4,440 pounds which is only 60 pounds below the trailer tow rating of my '85 Oldsmobile Delta 88 Royale Brougham Luxury Sedan with factory tow package including the 307 Oldsmobile V8 and 3.23 differential ratio.
As for the tow vehicle - Money is very tight and I already have an Olds 1990 Custom Cruiser station wagon with V8 307CID engine. Research shows it has a turbo hydramatic 200-4R automatic transmission with 0:67"1 overdrive ratio and lock-up torque convertor with swirl port heads on the ? cylinders for increased low end torque.
I don't have the factory material for your 1990 Custom Cruiser, but it is on a similar body platform to my '85 Oldsmobile Delta 88 Royale Brougham Luxury Sedan. In standard trim, Oldsmobile rated the plaform for 3,000 pounds without the factory trailer tow package. The factory trailer tow package increased the trailer tow rating to 5,000 pounds. With the general tendency of wagons to weigh some 10-to-15% more than a sedan, your wagon may not have even had a 5,000 pound trailer tow rating partciularly with the 307 V8 rather than the optional 350 V8. The big difference between the standard and the tow equipped car in this series was the differential - - 2.70 was standard -- and -- either a 3.07 or a 3.23 could be ordered with the trailer tow package. With the 3.23 and 307 V8, my '85 Delta 88 Royale Brougham Luxury Sedan is rated for a maximum of 5,000 pounds. My experience indicates that the car is happiest with my Minuet 6.0 Metre at 3,200 pounds loaded for a vacation.
I love this car and sure don't want to mess it up. It has no hitch and I wonder about the other aspects of a tow package. Have never pulled a trailer or used one. Will look for a used Surburban if Olds wagon is not adequate.
Under the very best of conditions, the 307 V8 would have a huge struggle with your Sovereign even if it has the 3.23 differential. Encounter any grade and the motor will struggle mightly which may result in transmission overheating as well. In addition, if your 307 V8 has the factory aluminum intake manifold the constant exposure to high temperatures would also likely hasten the failure of the intake manifold gaskets in the area of the coolant crossover passage resulting in the antifreeze mixture being drawn into the combustion chambers.
Basically, the trailer tow package on the Custom Cruiser included trailer light wiring to the rear bumper, heavy duty radiator with extra-capacity transmssion fluid cooler, and required at least a 3.07 differential (probably 3,000 pound trailer tow rating) with the 3.23 (probably 5,000 pound trailer tow rating) preferred for the highest trailer tow capacity. The trailer tow package was available with or without the optional receiver hitch.
I love towing my Vintage Airstreams with a Vintage automobile, particularly my Oldsmobile, but the Sovereign is much more weight than I would suggest considering towing behind an Oldsmobile equipped with the 307 V8. When your Sovereign was new, a likely tow vehicle would have been an Oldsmobile Custom Cruiser (98 Series) with the 455 cubic inch V8.
Good luck with your investigation and research!
Kevin
