Old 09-11-2017, 07:32 PM   #1
wave man's Avatar
2018 25' Flying Cloud
Houston , Tx
Ok, new question has come to mind... Tundra 5.7L owners this is for you
I've been really struggling to pick a TV because many say a half ton is more than sufficient for a 25FC (but that it gets iffy going past to 26, 27 etc) and that would be really great for my situation because I can't afford an expensive TV like a 3/4t, the 1/2t would be ideal for all the usual reasons people prefer them..
BUT the tongue weight of my incoming FC25 FB (starting at 837 and passing 1000 according to many) proves the "half ton will do it" truism false. I will be in my AS a lot, it will get heavy, and I want to put my kids in the truck sometimes... ..The usual payload quandry seen here many times
I hear it said (read) Tundras are seemingly really overbuilt and impressive in what they can effortlessly do because of it... I'd love to get one.
So I've been grappling with Payload issues in a potential TV (getting a FC25FB) and I'd like to put some questions to ya in a private setting so as to ask specific questions and get a candid exchange without re-hashing in a public forum again...
Could I ask for those of you out there working your Tundra 5.7L to send me a private message so I can run a couple things by ya? I'd love to follow up on this issue with those of you that are in the know...Thanks so much in advance, I've been reading till my brain hurts and need to cut to the chase
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
wave man is offline   Reply With Quote
Old 09-11-2017, 08:29 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
I would not recommend taking any vehicle over it's axle ratings regardless of how "stout" it seems to be built.
Part of the problem is that a modern truck can have some strange numbers on it. Headline numbers from the F-150 page (Chevy and Dodge have similar numbers I'm sure):
Payload 3,270 lb
Towing 12,200 lb (with WD hitch)
From a bit further down:
Max config GCWR (that I could find) 17,100 lb
Max tongue weight 1,220 lb
One *could* ask exactly what makes that a 150 or a half ton. One also wonders about the "max payload" version even having a passenger seat in it ..... The "camper" section shows a number of config's with 1500 to 2500 lb cargo ratings.
Digging up the axle numbers would take more key strokes than I'm up for at the moment.
Old 09-11-2017, 09:29 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
A properly equipped half-ton will tow a 25, 26, 27, and 28 well, you wouldn't notice the difference of 2 feet and 300 lb max load rating among them. If the truck is greatly over-sized, you will notice the difference from one well-sized to your needs.
Look at the "payload" number as a shopping reference, but it is the axle ratings and the load placed across them (as well as 200 lbs or so to the trailer axles) by a quality w.d. hitch and setup that will determine what the truck can carry and how well the vehicle tows. If you carry extra people you will need to manage the loads in the bed of 1/2 and many 3/4 ton trucks when putting the Airstream on the hitch receiver.
When you get loaded for travel, take a moment and run your loaded vehicle over a CAT so you know if your truck and trailer axle loads are within ratings. Then you'll have a reference for future loading and w.d. adjustment. If you have too much load, you will need to take inventory of "stuff' and leave some at home (probably best to keep the kids in place and lose some of the gear).
Tundras are over-built. Well, not everyone will agree with that if it suggests our others are under-built. Ford, GM, Ram, and Nissan also build highly capable trucks that may offer more towing options and make better use of fuel.
Doug and Cheryl
Old 09-12-2017, 06:23 AM   #4
wave man's Avatar
Houston , Tx
Thank you both, the axle ratings is the ray of hope that gets short shrift seems to me.. and it may make this actually doable. Less worry anyway ...
Old 09-12-2017, 06:44 AM   #5
2016 25' Flying Cloud
Holly Springs , Mississippi
...and don't forget that a half (maybe a bit more) of "tongue weight" gets sent somewhere else--to the front axle and the trailer axles--with a well executed weight distribution hitch. The only way to determine how much is at the public scales, which doesn't help you in deciding which TV to acquire. Just remember measured unattached tongue weight isn't too relevant.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 09-12-2017, 06:52 AM   #6
wave man's Avatar
Houston , Tx
Another factor I've lost track of, thank you Bob662
Old 09-12-2017, 07:21 AM   #7
Long Island , New York
Don't forget a margin of error for a safety factor, to accommodate all kinds of instant loads from road conditions, evasive maneuvers, and so forth.
Also this tough question -- when you are fully loaded with all your trailer and camping gear in the pickup, kids, full tanks, maybe some extra water and food in coolers . . .
. . . will you wish you had not compromised on the TV with a "I think I can just make the limits" kind of approach?
Or -- when you buy a tool, do you get the one that will "just barely do the job" or do you buy one that will easily handle the current job, and then some?
A 1/2 ton pickup will probably disappoint IMO.
Good luck,
Peter
Old 09-12-2017, 07:47 AM   #8
dkottum's Avatar
People will argue 'til hell freezes over about the best weight distribution hitch, but (almost) all will agree you cannot use a mid-size Airstream/half-ton tow vehicle combination without a capable w.d. hitch and high quality w.d. setup.
An example, our our FC 25 RB fully loaded (837 lb factory hitch weight, probably 1,000 lb loaded), with oversized AGM batteries in the box (extra 40 lbs), a ProPride hitch (180 lb) on the tongue adds 800 to 840 lbs to our trucks axles. When sizing w.d. hitch bars, the weight of gear behind the trucks axles must also be considered, along with trailer's loaded hitch weight.
The truck's wheelbase, any flexibility in the truck's frame and hitch receiver, and engine type (our cast iron diesel engine loads the front axle more than he aluminum gas engine option) also make a difference. We use 1400 lb w.d. bars to load our truck's front and rear axles to near 3600 lbs each, they are rated at 3900 lb each. Without a capable w.d. hitch our rear axle would be overloaded and the front axle too light for positive steering and braking when we need it most.
Doug and Cheryl
Old 09-12-2017, 09:11 AM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
PM me.
I will answer any questions.
I think the 30" actually has less tongue weight than a 25' or 27'.
I think I am the only Tundra 5.7 owner to speak up so far...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 09-12-2017, 09:15 AM   #10
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
I've seen more and more Tundra's pulling not just Airstreams but as tow vehicles in general. They seem quite capable.
kdickinson is offline   Reply With Quote
Old 09-12-2017, 09:17 AM   #11
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
Tundra owner here. PM me as well if you like.
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
Old 09-12-2017, 09:30 AM   #12
Rugger's Avatar
Box Elder , South Dakota
I have a 2013 Tundra with a 5.7 L and tow my 2008 International 28 CCD. We use an Equalizer WD hitch. This is our second Tundra towing our rig and have never felt under trucked. Listed hitch weight is 880, but probably closer to 1000. Feel free to PM me
Roger, Adam and our dog Shorts
2008 Intl 28 CCD
2013 Toyota Tundra
"You are only young once, but you can stay immature indefinitely' - Ogden Nash
Rugger is offline   Reply With Quote
Old 09-12-2017, 09:32 AM   #13
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
I pull a 23ft with a 2010 limited tundra with tow package ...love it and barley notice the trailer ... I have pulled from Canada to the Mexican border a few times now and am very happy .... except it sucks gas ... but what doesn't??
rucos is offline   Reply With Quote
Old 09-12-2017, 09:38 AM   #14
2003 22' International CCD
2004 28' Safari
Sahuarita , Arizona
Actual Numbers
Here are my actual numbers weighed on a CAT truck scale. Hope this helps.
Tundra and Airstream Weights
Certified Scale Weights
Tundra GCWR 15690 lbs
Tundra TWR 9400 lbs
Tundra Max Weight 7300
Airstream Max Weight - 7200
2016 Toyota Tundra Crewmax Empty Weights Full Fuel
Front Axle 3320 lbs
Rear Axle 2560 lbs
Empty Weight 5880 lbs Max Allowable Weight 7300 lbs
Truck Payload 1420 lbs Available
2016 Tundra and 2016 Airstream 25 Flying Cloud Empty Weights No Water/Waste
Blue Ox Weight Distributing Hitch showing 3 Chain Links and proper set-up
Truck Front Axle 3180 lbs Max 4000 lbs
Truck Rear Axle 3520 lbs Max 4150 lbs
Truck Payload 600 lbs Available
Trailer Axles Total 5120 lbs Max 7200 lbs
Total Gross Empty Weight 11820 lbs
Airstream Empty Weight 5940 lbs
Airstream Payload 1260 lbs Available
AzAirstream is offline   Reply With Quote
Would you guys mind checking my numbers? Xplore Towing, Tow Vehicles & Hitches 10 06-23-2017 07:04 AM
Open House!!! Come one come all!!! wheel interested Photography 248 08-21-2012 08:32 AM
My time has come CACTUS Our Community 11 12-21-2005 07:40 PM
chat, come one come all! john hd Off Topic Forum 13 01-25-2005 06:51 PM
