Old 06-02-2007, 10:48 AM   #85
yukionna
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Originally Posted by Tom Nugler
Pulled up the Alldata info on your truck. Shows 6 different EBCMs depending on your equiptment level with prices from $250.00 to $788.00. Labor is 1.3 hours for all.
I would like to think that they quoted the higher price not knowing which module you needed but the 4 hours is IMHO just plain wrong.
Even if I was having a bad week and needed to pad times I wouldn't have gone over 2.
Service writers are usually paid on commission so often push the envelope as hard as they can. This time it looks like he lost the whole job.
Thanks for doing that. Your part prices are in line with my research on that part. And, your labor price makes more sense but still seems a bit high (as I indicated it only took hubby 15 minutes to replace the part).
With regards to your comment about the quote being higher due to not knowing the whole situation, I find it hard to believe that a GM dealership would not know which part my truck needed. When we decided to tackle the project ourselves, I refused to even purchase the part from the dealership that quoted me the $850 price. I went to another GM dealer to buy the module and they quickly figured out which part I needed by asking me two questions: what is my VIN and did I have the 2" rise. If we didn't have the 2" rise in the truck, the part would have cost us $250. Of course now, the original dealership will now NEVER get my business again.
WBCCI Region One
"Repression provides a temporary solution." ~ Paul Williams
yukionna is offline   Reply With Quote
Old 01-16-2008, 10:39 AM   #86
Buttercup
VAC Membership Chair
Buttercup's Avatar
Profile:  1977 27' Overlander
1954 26' Romany Cruiser
VC Highlands , Nevada
So I just came across this handy little device. It plugs into the ODB-II port and will record 300 hours of data. When needed, plug into your computer and download the data.
PROVANTAGE: Davis Instruments 8226 CarChip Pro
Don't let the IBT Scuttle the WBCCI - Just Vote NO! Save Wally!
Buttercup Web site Looking for a unit? Check out the SaveWally Unit Guide.
2008 Mouse count =
WBCCI # 17330, VAC Membership Chair, CAC Member
Buttercup is offline   Reply With Quote
Old 01-16-2008, 12:12 PM   #87
Tom Nugler
Tom Nugler's Avatar
Profile:  1967 20' Globetrotter
McHenry County , Illinois
Nifty little device. Price is right too. I can think of a couple of professional and personal uses for this.
Tom
Airstream Forums Member # 2806
WBCCI # 6411
Not All Who Wander Are Lost.
Tom Nugler is offline   Reply With Quote
Old 01-16-2008, 01:10 PM   #88
Buttercup
Buttercup's Avatar
Yea, found it for as low as $99. Still looking...
2008 Mouse count =
Old 01-19-2008, 12:33 PM   #89
yukionna
yukionna's Avatar
Images: 18
We use ours all the time now. We are constantly getting the error about gasoline fumes (right after fueling) so it comes in handy to reset those codes. I found the "gas fumes" codes don't reset themselves, unfortunately. It costs about $50 a shot for a garage to reset the codes so it paid for itself immediately.
Also, in MA, vehicles won't pass inspection if there is a code. It comes in handy to test the vehicle prior to inspection to give us time to repair the issue, if any.
WBCCI Region One
Old 01-19-2008, 02:22 PM   #90
Buttercup
Buttercup's Avatar
Are you saying that the CarChip Pro can also be used to reset the Check engine light? Or are you using something else? I have been usinging my OBD-II interface box I got from scantools.net and my $10 Palm Pilot to do that and record data.
But if the CarChipp does this as well, it might be the better option....
2008 Mouse count =
Old 01-19-2008, 08:19 PM   #91
Tom Nugler
Tom Nugler's Avatar
We are constantly getting the error about gasoline fumes (right after fueling) .... Also, in MA, vehicles won't pass inspection if there is a code.
What code are you pulling up? P440-P455? These evap emissions leaks are often caused by faulty gas caps. Pretty common in cold weather as the seals are stiffer.
One other thing to point out is that just clearing the codes and resetting the light won't reset the readiness monitors. The emission test checks for 3 major items. MIL on, fuel cap seal and the readiness code. This code indicates that the system has run, and passed, all the necessary tests. No code and you fail the test.
Always the bearer of good news,
Tom
WBCCI # 6411
Ridgeland Miss camping recommendations? 10acKen On The Road... 2 05-10-2007 06:50 PM
Campground recommendations -Memphis, Nashville luckydc On The Road... 4 07-10-2006 01:44 PM
Drain Fitting conversion? Recommendations? Jabba Waste Systems, Tanks & Totes 3 07-11-2003 05:30 PM
shop recommendations in K.C. kc airstreamer The Vendor's Forum 0 05-18-2003 12:34 AM
de-humidifier recommendations dpope 2003 Safari 3 04-07-2003 03:08 PM
