Old 02-25-2016, 07:00 PM   #141
1999 34' Excella
Cinnaminson , New Jersey
Curious, what were your actual weights compared to mfg listed curb weights?
excellaf350 is offline   Reply With Quote
Old 02-25-2016, 07:47 PM   #142
dznf0g's Avatar
Oswego , Illinois
Curb weight = 5409 (includes 150 pound driver
Scaled weight after installing spray in bed liner. Stainless assist steps, mud flaps, and soft tonneau = 5720 pounds. I weigh 180 so accessories weigh 281 pounds.
Edit: there were a few other items included in that 281. A road emergency kit, air compressor, and thule roof rack feet and bars.
-Rich-
Old 02-25-2016, 08:56 PM   #143
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
I've got mine!
Nissan Titan XD SL
Towing capacity: 11,638.2 lb.
Max Tongue weight 1,163.8 lb.
Max payload: 1,588 lb
I've been towing our 2013 27 Classic with a 2006 Dodge Durango -- it had a towing capacity of 8950 lb. and a payload of 1600 lb.
Our previous trailer was a 2007 Safari and the Durango did the trick, but struggled a bit with the 27 Classic. The Durango with its 5.7 Hemi gave us 88,000 mostly trouble free miles with the exception of a couple of computer problems, with the last issue being an intermittent dead electronics, wouldn't start.
Looking forward to the new Nissan -- drove a bunch of trucks, the XD is a perfect fit for us.
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 02-26-2016, 07:41 AM   #144
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The empty truck curb weight numbers are often based upon a nearly non-existent driver today, one weighing ONLY 150 pounds.
Old 02-26-2016, 08:15 AM   #145
dznf0g's Avatar
Oswego , Illinois
No kidding! I had heard several years ago that the standard was going to change to 175....but it never happened. Even that is probably below the average today.
-Rich-
Old 02-26-2016, 08:16 AM   #146
dznf0g's Avatar
Oswego , Illinois
Originally Posted by tkowalyk View Post
I've got mine!
Nissan Titan XD SL
Do you have GVWR and Curb weight?
-Rich-
Old 02-26-2016, 11:27 AM   #147
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
200 lbs is much more likely the average as I look around the world I live in. I'm tipping the scale at 220..... would like to get back to 200.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 02-26-2016, 01:17 PM   #148
tkowalyk's Avatar
2013 27' FB Classic
Images: 11
Curb weight is 7,402 lb. (heavy) and the the GVWR is 8,990 lb.
Tom & Lori
Old 02-26-2016, 04:49 PM   #149
1999 34' Excella
Having a heavy truck isn't always a bad thing. All that mass up front on the TV can help control the trailer. Ever try towing 10,000 with a 5,000 lb truck? the trailer tends to have more of that control than the tow vehicle which is never a good thing. It would be nice to see the curb weights a little lower though.
Any idea what the GCWR is? probably in the owners manual...
Old 02-26-2016, 05:18 PM   #150
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Originally Posted by excellaf350 View Post
Having a heavy truck isn't always a bad thing. All that mass up front on the TV can help control the trailer. Ever try towing 10,000 with a 5,000 lb truck? the trailer tends to have more of that control than the tow vehicle which is never a good thing. . .
Not true. It is the stability of the truck that controls the trailer, and that is where to put your money. It is excess truck weight that can be hard to control when things go wrong.
There's a lot more to the answer but too far off topic.
Doug and Cheryl
Old 02-26-2016, 05:23 PM   #151
dznf0g's Avatar
Oswego , Illinois
Originally Posted by dkottum View Post
not true. It is the stability of the truck that controls the trailer, and that is where to put your money. It is excess truck weight that can be hard to control when things go wrong.
x2^
-Rich-
Old 02-26-2016, 05:38 PM   #152
N/A , N/A
Everything else being equal, the extra weight of the TV (relative to the trailer) helps with overall stability. In another thread, someone posted a technical publication with this conclusion.
rostam is offline   Reply With Quote
Old 02-26-2016, 06:30 PM   #153
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
https://simple.wikipedia.org/wiki/Co...nt_of_friction
When this is overcome, loss of control is more likely to happen.
Lance
Top is offline   Reply With Quote
Old 02-27-2016, 08:23 AM   #154
1999 34' Excella
I'm just saying having a larger (HEAVIER) truck isn't gonna hurt. Sure there are a lot of other things to consider. But in more of a general terms, I would rather have a 10,000 lb TV than a 5,000 lb TV with a big heavy trailer... that's all.
the Titan does seem heavy at 7000+lbs, but its got a lot to offer. Larger fully boxed frame, bigger brakes ect... all that stuff adds weight. Its certainly heavier than an F150 or a chevy 1500, but its to be expected I think, since they are claiming/marketing it as beefier truck.
Nissan Titan n2916s Tow Vehicles 135 12-18-2016 09:51 PM
2015 Nissan With A Cummins pappy19 Tow Vehicles 63 01-29-2015 06:51 PM
To Cummins or Not to Cummins?? Help!! On the brink! big_john Tow Vehicles 33 03-23-2010 08:20 PM
Nissan Armada owners AirHog Tow Vehicles 37 12-23-2008 01:34 PM
Nissan Xterra Lexxy Tow Vehicles 17 10-03-2002 06:36 AM
