Old 05-17-2004, 03:57 AM   #85
Davydd's Avatar
Tonka Bay
Images: 13
Went from Trailblazer to Titan
Originally Posted by danesh
Davydd:
Your posts show that you have a 2004 titan, though you write like you are looking to buy an avelanch, is there something wrong with your titan? We are trying to buy a new vehicle to pull our 27 sovereign with 6800lbs GVWR. I cannot see why there is so much talk about 1/2 vs 3/4 ton towing vehicles. We pulled an almost 3500lbs 22' trailer with our 2000 Honda odyssey few years ago for more than 3000 miles, with no problem. It had a towing capacity of 3500lbs. We could go 80 with no wind effect in level interstates. Ussually, the manufacturers calculate a 10-20% safety factor in their specifications. So titan's 9400 ils towing capacity should be more than enough for a 7000lb AS. Unless somebody here has had an actual problem with these figures, it appears that we are mostly guessing.
Cheers to all.
Danesh,
I was looking to upgrade my towing capacity that I had with a Chevy Trailblazer (6200 lbs) to an Avalanche. After I saw, and drove a Titan I changed my mind and went with it.
Speaking of what you can tow, I just got back from England and Wales. Caravans (trailers) seem very popular there. The shocking thing is they pull them with compact cars. We were stopped on the motorway (their version of Interstate) because of an accident. When we finally cleared we saw that it was a trailer and VW Passat that evidently got of of control and collided with another car. We rented a Kia Sorento midsize SUV and felt we were one of the largest passenger vehicles on the road.
Davydd
2015 Sprinter Class B Camper Van
(Former 1971 vintage Airstream Owner)
Davydd is offline   Reply With Quote
Old 01-08-2005, 10:16 PM   #86
danesh's Avatar
Nissan Titan and Towing
Hello Everybody:
We just got back from a 2000 miles camping trip with our 27' 6800lbs Airstream. It was our first time towing with our new Nissan Titan. Before we towed the AS with a Ford Expedition, 5.4 litter Eddie Bawer 4x4 with towing package. Our titan is a 4x4 and has a towing package too. The difference was unbelievable. We did not feel we are pulling the AS while going up the hills. The towing mode works great. I did not use the cruise control to avoid sudden gear shifts. For those of you who are thinking to get a towing vehicle for your AS, we recommend a Titan. FYI, the gas millage was around 9-10 MPG. We also used a Hensley Hitch for the first time. And what they say about it is true. No sway at all. Just thought some of you may be interested to know about our experience.
Cheers
85 sovereign
danesh is offline   Reply With Quote
Old 01-09-2005, 06:16 AM   #87
Obviously you're quite happy with your truck, but lets be a little realistic. 6800 pounds and couldn't tell you were towing....uphill.
Even my 7.3l TD would surely remind me of a 6800 pound trailer when towing through the hills. I'm beginning to wonder about the Titan altgether. It seems recently there has been a real offensive to prove it is atleast equal to a 3/4 ton truck, now it seems the magical little Nissan is now superior to a 3/4.
Not trying to discount your experience, but let's be realistic here, a lot of people look to online forums such as this for real world information.
Camp-Dog is offline   Reply With Quote
Old 01-09-2005, 08:18 AM   #88
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Well the 7.3L was a Ford right?
The Titan and Armada seem to have a cult like following and that's great....and IMHO if you are under the 6k range, it might not be a bad idea. It's my opinion after driving a buddies while towing my 3500lb boat at grade, that it was back there and it was clearly back there. I will say that I couldn't picture hooking up my 6300lb Airstream to it (Titan), particularly if I was going to the Rockies. The Titan does have the wheel base for 25' or longer, however the Armada (which is another truck talked about around here and seems to share several aspects of the Titan) does not have the wheelbase to go far beyond say 22' if you go by the numbers let alone the towing claims made since the weights usually imply a longer trailer. The fact that the Armada claims a 9k tow rating I feel is not only reckless, but possilbly dangerous given it's wheelbase (let alone the rest of the specs that the Titan shares with it).
The thing that I find interesting is that with the big tow package they are able to magically take the truck from:
Maximum towing capacity (lbs.)
Standard
6,500
7,400
7,200
To:
With Big Tow Package
N/A
9,500
9,200
That is a big 3k difference for just adding this:
Big Tow Package (SE and LE Only)
Class IV receiver hitch
Additional 7-pin wiring harness plug
Trailer brake controller pre-wiring under instrument panel
Heavy-duty battery (710 CCA)
Lower final gear ratio (3.36:1); similar to 4.10:1 on a 4-speed automatic
Extendable tow mirrors
Transmission temperature gauge
Increased tow capacity
...and with the standared disclaimer that all need to understand regardless of what truck you buy:
Towing performance and speed are affected by vehicle payload, tow weight, road grades and weather conditions, including high temperatures. See owner's manual at dealership before purchase for details.
In the end it's it not a bad truck (either of them). They have merit and clearly deserve some respect, however, regardless, it's a 1/2 truck trying to act like a 3/4 ton and for those of you who have come from a standard (non HD) 1/2 and went to a real 3/4 ton, well you know what I'm talking about. It's a lesson that cost me thousands of $$ to learn. For those who haven't and are content, good for you....but please just keep in mind that anything can tow something, the real questions are should it, not can it.
Old 01-09-2005, 08:49 AM   #89
Aluminut
2004 25' Safari
. , Illinois
BTW, just as a reference, here is the Tahoe and Silverado base towing for 1/2 tons with similar sized engines. I think you'll understand my concern a bit more clearly about getting a 3k tow rating increase by just mainly changing the gearing. Maybe GM is just a bit conservitive, perhaps Nissan is a bit too optimisitc, I don't know, but here are GMs numbers just the same to take a peek at.
Trailering
Vortec 4800 V8 (Automatic)
Vortec 5300 V8 (Automatic)
MODEL
Max. Trailer Weight (lbs.)1
Required Axle Ratio
Required Axle Ratio
Tahoe (2WD)
5700
3.23
6700
3.23
6700
3.73
7700
3.73
Tahoe (4x4)
6500
3.42
7500
3.42
7500
4.10
7800
4.10
1500 WITH VORTEC 5300 V8 ENGINE WITH AUTOMATIC TRANSMISSION
Model
Box Length (ft.)
Required Axle Ratio
GCWR2 (lbs.)
1500 2WD
Regular Cab
6.5/8
7300/7200
8300/8200
3.23
3.73
12,000
13,000
Extended Cab
6.5/8
7000/6800
8000/7800
3.23
3.73
12,000
13,000
Crew Cab
5.7
6700
7700
3.23
3.73
12,000
13,000
1500 4x4
Regular Cab
6.5/8
8000/7900
9000/8900
3.42
4.10
13,000
14,000
Extended Cab
6.5/8
77003/7600
87003/8600
3.42
4.10
13,000
14,000
Crew Cab
5.7
7400
8400
3.42
4.10
13,000
14,000
Old 01-09-2005, 10:51 AM   #90
Davydd's Avatar
Tonka Bay
Images: 13
A Cult?
It seems a lot of retort comments about the Titan seem a bit defensive in questioning its capabilities and questioning Danesh's open credibility by Camp-Dog in the previous message was a bit undeserved. You would almost think the Nissan Titan was a threat to mom, apple pie and the American way. It probably is the purest American truck (designed in San Diego by Americans, engine manufactured in Tennessee and truck assembled in Mississippi). It does not come from Japan, Mexico or Canada.
In 2004, TruckWorld and Trailer Boat magazines, and others, did extensive testing and the Titan bested all the 1/2 tons. Even MotorTrend's review for Truck of the Year read like the Titan was heads above the others but then mysteriously awarded the Ford F150. I can find no head to head reviews refuting Titan claims. I drive a Titan and had a Chevy Silverado. I speak from direct hands on experience. I'm convinced Titan is the better truck and my pedigree is 12 previous Chevy trucks and a stint working in the Chevy Truck Manufacturing Plant in Indianapolis.
If it be a cult, Silvertwinkie, that's OK, I'm used to it. Your exhaustive retort and analysis looks to me like the stuff a Wintel PC user comes up with against a Macintosh. I know you wouldn't want to be associated with that.
Davydd
Old 01-09-2005, 11:27 AM   #91
Aluminut
2004 25' Safari
. , Illinois
Bite your tounge.
I'm not in total disagreement about the Nissan offerings. As I've said in other threads (unlike some people in OS camp flame wars) it's not a bad truck and a great first shot at the full size market. I also think that there are some REALLY GREAT PCs out there (non Macs), but they are running Linux due to the limitiations and problems associated with Windows.
I guess what I am getting at is more of a bigger picture, not that of simply the Armada or Titan, but of 1/2 tons in general, with 4.xL or 5.xL engines geared to make up for shortcomings and given a large tow rating. In towing moving is only half the equation, stopping is another big part. Personally, tow ratings can be misleading and sometimes give a false sense of security. Add to the fact that most sales folks don't properly qualify a buyer and you have folks towing 30-34' RVs with Tahoes, Expeditions, Armadas and Titians. On flat ground, you might be OK, but get into hills and mountains and you could be asking for disaster. To be fair, I also wouldn't tow a 6k to 7k coach with a 116" or 117" wheelbase 5.3L Tahoe, even though Chevy says it can or a 5.3L 130" wheelbase Suburban. Since this is a Titan thread, by nature I place those concerns squarely on the Titan and it's shorter wheelbase sibling, the Armada. On several other threads, I think you'll find that I'm fairly consistant with my comments about a 1/2 tons regardless of the make (particularly post 2004 camping season). Now if Nissan placed a few more cubes under the hood, had a much more stout rear differential/axle, most of my bigger concerns about it would evaporate. GM did that with the 1500HD.
Old 01-09-2005, 11:47 AM   #92
Big Dee's Avatar
2004 30' Classic
San Jose , California
Images: 24
Twink,
I like that you put in the "(non HD)" disclaimer in there. Probably just to shut me up before I get going. So I won't get started on the erroneous "1/2 tonners can't do it" argument.
As for the Titan, I too don't understand the defensiveness of many of even acknowledging that the Titan is a good TV. The Titan has received high marks on all the road tow tests. Nissan is on fire and spitting out impressive products for over a year now. And I have talked to a few Titan owners who are estatic about their truck. Why such begrudging comments? It is like a new kid moved in on the block but no one will let him play with them.
"It's the journey."
NorCal Fall Rally, Jackson Rancheria, October 7-9 2011 Click here for more info
Come rally with us.
Big Dee is offline   Reply With Quote
Old 01-09-2005, 11:51 AM   #93
Aluminut
2004 25' Safari
. , Illinois
Yea, my behind still stings a bit from the last time I forgot to mention the 1500HD models as a different beast than standard 1500s, as such is now part of the standard company line/disclaimer.
BTW, Dee, I thought you were the one that mentioned the 31 foot floorplan a while back. I took a look recently at the 31' Dinette floorplan that is new for the '05 model year. I think that's our next upgrade...to keep it tow rating related, I am hopeful that our 6.0L Suburban (4.10s) will be able to tow it safely (when the time comes).
Old 01-09-2005, 12:11 PM   #94
Big Dee's Avatar
2004 30' Classic
Images: 24
Twink,
You do make me laugh! And I love your signature.
There is a new Classic floorplan??? Wow. I am off for the AS website to check it out. Another upgrade for you?
The 6.0 is up to the task, I assure you Twink. Read my Death Valley Road Report and you will see that the 6.0 came, the 6.0 saw, the 6.0 conquered! The biggest, longest grades I have ever encountered towing (not the highest, that comes this summer in the Eisenhower Tunnel) and the 6.0 was VERY impressive. I love this engine.
"It's the journey."
Come rally with us.
Old 01-09-2005, 01:08 PM   #95
My apologies for any misunderstanding in my previous post. My point is anyone who straps nearly 7000 pounds to the back of ANY consumer grade tow vehicle (i.e. 1 ton truck or less) is going to feel it when it comes to any appreciable hill/grade -- PERIOD !!! This has nothing to do with brand, make, model, etc. I just don't like to see people be mislead by hype and rhetoric.
Old 01-09-2005, 01:54 PM   #96
Aluminut
2004 25' Safari
. , Illinois
Well they came out with a dinette version of the 31 footer that really has caught my eye. I'm not sure when, but it seems to be the next logical step. It's mainly due to the value of the units holding their value as the model years increase in cost-- fairly substantially over the last few years, so that the hit some folks think one might take doing this is actually nearly a non-issue. Now if I hold onto it for several years, there will no doubt be a good hit, but while the iron is hot, it's almost a you can't lose situation. In addition, if you buy it on time, you can write off the interest on the loan unlike a car note.
I agree the 6.0L is a great engine. I was talking with Jack Canavera about it since he tows his 30' Classic slide with one and has been very pleased as has JohnHD and a few others. Based on the substantial positive info I received, I opted to go with the 6.0L, regardless of the piston slap issues that was circling around. With the 4.10s and 4L80E, I should be good from what it looks like on paper and my gut tells me it should be OK too. The main thing I like about the Suburban is the size of it and the stability it commands (even without the weight bars or sway on it--- yea, I just had to try it once). It really does make for a comfortable tow vehicle.....the Impala did have the power, but the ol Burb really has the best of both worlds as far as I can tell. Wind, etc doesn't really effect it like it did with the Impala. I've heard some concerns about the 8.1L drinking oil and besides that, the 8.1L no doubt will cost more to feed, but as it should I figure since it is producing more power.
Old 01-09-2005, 02:54 PM   #97
For the 2004 and 2005 tax year you can also write off the actual sales tax paid at the time of purchase also.
http://www.irs.gov/pub/irs-pdf/p600.pdf
This may be some good tax info to post for people who are considering purchasing this year. Probably needs to be moved to a new thread though.
Old 01-10-2005, 06:04 PM   #98
Images: 59
To resolve the perpetual argument, go to this page and vote for your favorite truck.
http://www.autorox.com/rsc/fusion_pa...d=2&category=9
