Old 12-31-2013, 12:42 PM   #1
Severna Park , Maryland
Newbie with TV question
Been lurking a bit on the forum, so I guess I now know enough to be dangerous. We have not purchased a TT yet, but do have a TV. It is a Chevy Express 3500 conversion van with 6.0L gas. With the stock 3.73 rear axle ratio, max towing capacity is 7,700 lbs according to the owner's manual. We like the 30' Excella but late 90's to early 2000's models dry weight out from 6,800 to 7,300 lbs, respectively. This leaves little margin for cargo. Frankly, I was surprised at how much heavier these models were over their comparable late 80's to early 90's cousins. I was also surprised to find that a 4.10 rear axle ratio would boost my towing capacity to 9,700 lbs. I know that the engine and transmission would be under less load running at higher RPMs, but that is a huge difference. Ok, here are the questions:
1. Notwithstanding the approx $1,000 cost to switch to a 4.10 gear, is this a good option?
2. If #1 is a no, do you agree that the better option is get a smaller TT?
3. Never having owned an Airstream before, I was curious as to what sets Airstream apart from all other TTs? It appears that there is Airstream and - everything else.
Thank you for indulging a newbie. Be gentle with me. :-)
Sandy Swede is offline   Reply With Quote
Old 12-31-2013, 01:53 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I had to change my 3.42 to a 3.73 in my 1987 1/2 ton 6.2 diesel Suburban to pull my 34. Beyond that I installed a Gear Vendor overdrive. The combination gave me 7 forward speeds and allowed me to tow in 3rd gear over. Did it that way because the Transmission in that truck could not be used in OD while towing. Combined that with a manual convertor lock up and I could tow a 10%+ grade in second with the convertor locked all day long.
If you really want a tow vehicle consider installing the Gear vendors and stay with the 3.73. You will have some gears to ply with.
2004 Excursion 4x4
Old 12-31-2013, 02:11 PM   #3
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
Welcome. Fear not, people here are utterly helpful. I'd go very cautiously on changing to a 4:10 gear. When I bought my Suburban many people (not here) told me that 3:73 was bad, and I should only buy one with 4:10. I did. What I discovered is that it yields very poor gas mileage and for travel trailers is probably not necessary. Most of the people I met with 'Burbs had 3:73.
Maybe boat towing needs a 4:10, but I really don't see it for travel trailers. I would have preferred the 3:73, now that I have had the 4:10 for two years.
Tow ratings---well, there's a lot of opinion about how to use those ratings. One might say that with a WD hitch, you'd be fine with the trailer you mentioned even with the 3:73 gear. Ask more questions, read more of our towing threads! You'll get to the info you need!
Airstreams have a lower CG than most other similar size trailers, better slip through the wind, very good balance, and they handle really well. The rest of the mystique has to do with the timeless classic design that never ages. Go look at a 10 year old white box trailer (called an "SOB") and then look at a 10 year old Airstream. Let's just hope they never resort to gobbing swooopy stripes all over the exterior!
mstephens is offline   Reply With Quote
Old 12-31-2013, 02:22 PM   #4
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
That van should tow any Airstream made as is and do an excellent job. The 1 ton frame feels really stable on the road. We had one with the 5.7- it was really slow, but really sure-footed and confident and comfortable.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-31-2013, 02:34 PM   #5
mariusg78's Avatar
1977 31' Sovereign
Covington , Washington
Images: 21
I tow with a 2012 Ford E-350 5.4L (1977 31'). It pulls just fine over the passes in Western WA. You do end up going slower, but its sturdy and handles well. Be sure to add a good Weight Distribution System and sway bars and you should be good to go. Also be sure to have a transmission cooler installed if you don't already have one. Enjoy!
mariusg78 is offline   Reply With Quote
Old 01-01-2014, 03:30 PM   #6
Thanks much
Thanks to all of you who responded to my questions. Your comments were very helpful and informative. What a great forum. Another reason to buy an Airstream.
Old 01-01-2014, 03:55 PM   #7
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard....
The only 3500 van I would be leery of is the extended version with the longer rear overhang. (12 pass version I tink)
Good Luck
ID:	202724   Click image for larger version
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-01-2014, 04:42 PM   #8
Bbelk's Avatar
2010 27' FB Classic
I live at the top of a big honker hill. I can drive all over Colorado and the hardest pull I have to make is the last 500 yards up to my house.
I had a 1989 Airstream 190 van for 13 years and loved it till I sold it this year. The van weighted about 8,000# About ten years ago, I bought a new 5,000 pound boat. The hill in front of my house brought the whole rig to a halt. It had a 3xx rear end (357 rings a bell, but I don't remember). I switched it to a 410 and my towing problems were solved. You get used to driving at 55 with the speedometer reading 65, but its hard to get used to 5 MPG. I was pulling something for the vast majority of the 1xx,000 miles I put in that rig, so I didn't really mind it.
Unless you have an extream situation like I have in front of my house, I think 410 is probably lower than you want. The new 6L motor is way better than the 454 I had.
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
Bbelk is offline   Reply With Quote
Old 01-01-2014, 05:10 PM   #9
m.hony's Avatar
2013 30' Classic
Good Luck
Only the now defunct Ford Econoline had the longer overhang on the rear of the long wheel base version.
The GM models move the rear axle back towards the rear on the long version- a true long wheel base, not just 18" more van welded on the back...
TAC #MS-10
Airforums #70955
Old 01-01-2014, 06:01 PM   #10
2014 16' Sport
Route 66 , Arizona
Wow...the quality. We just traded our "everything else" trailer for a new Bambi 16. For starters, you can lean against an interior wall in the AS without the sound of paneling cracking. The wetbath floor doesn't seem to have voids underneath. The whole trailer doesn't shake everytime the furnace or A/C cycles. The list goes on. Not only is build quality amazing, the components used (TV, stereo, fridge, etc.) are far superior to what was in our other trailer.
Skooter is offline   Reply With Quote
Old 01-01-2014, 07:49 PM   #11
Thank you
Thanks Robert Cross and others who mentioned potential problems with a long wheelbase van. Ours is the standard wheelbase of 135", not the stretch version.
Also, thanks skooter for your take on Airstream quality vs. the 'others.'
Old 01-01-2014, 08:10 PM   #12
albert's Avatar
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Tulum , Mexico
Send a message via AIM to albert Send a message via Yahoo to albert
I have the same engine on a f250, what transmission cooler do you use? I have never thought of that but sounds like a good idea! Any advise on huh at would be great, as the rpms run quite high when pulling uphill with the 5.4L
albert is offline   Reply With Quote
Old 01-02-2014, 09:24 AM   #13
mariusg78's Avatar
1977 31' Sovereign
Images: 21
The transmission cooler comes standard in the Super Duty package on the E-350, so I'm assuming its just the stock Ford one. I asked about adding an extra fan in front of it, but Ford said it was not necessary.
