Old 04-11-2007, 06:15 PM   #1
Airstream Dreamin'
Sheffield Village , Ohio
Newbie with a Nitro
I have a 2007 Dodge Nitro with a GVWR of 2500 pounds. Looking to buy a Airstream Bambi next year but want to make sure I can haul it with my car. I have seen them hauled with the Toyota FJ Cruiser and the Jeep Liberty. I'm not sure what the weight is for any airstreams so I'm thinking that the smaller ones would be suitable for hauling with my tow package. I hope you don't think me naive about all of this but any help and suggestions would be wonderful. Thanks so much.
Jackie (33) and Rob (35)
Labs-Abbey and Cinder
Northern Ohio
JackieY is offline   Reply With Quote
Old 04-11-2007, 06:28 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Jackie,
Best I can tell unless you have the factory tow setup you probably aren't going to be able to tow even the smallest Airstream with your Nitro. I checked the Dodge website and it wasn't very clear on towing capacity of the standard Nitro. It did say that you could tow up to 5,000# with the special package. 3,500# without. The lightest of the current Airstreams weighs in around 3,000 empty. Also the manufacturer's play games with the towing numbers, by not allowing for vehicle load, full fuel tanks etc. Run a board search for towing capacity and you will find out things you probably never wanted to know.
Aaron
WBCCI #XXXX AIR #2495
Old 04-11-2007, 06:54 PM   #3
Airstream Dreamin'
Thanks for the reply. That is disappointing. Good thing I only leased for 2 years. What kind of vehicle should I consider buying to tow something like the Bambi or the Globetrotter? I don't want a mammoth vehicle but I don't want something too small either.
Northern Ohio
Old 04-11-2007, 07:28 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Jackie,
I don't know what your personal preferences are but I would make sure that whatever you buy is rated for at least 5,000# of towing capacity for the Bambi. Look for factory installed tow packages, in most cases they will include things like added cooling capacity for the radiator, additional transmission cooler, different rear end ratio, frame hitches Class IV(4) would be ideal and 7 pin wiring. And then there is what is known as 2 footitis. You may start out with the Bambi, but may want to upgrade. It might be a bit cheaper to start out with a slightly larger tow vehicle to avoid upgrading both the trailer and a tow vehicle at the same time
Aaorn
Old 04-11-2007, 07:52 PM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
No with a Nitro.....
You might find a very small vintage it **might** be able to pull, but it'd have to be pretty small.....
Old 04-11-2007, 07:52 PM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I agree with the others. The Dodge Nitro is not much of a tow vehicle. You could maybe do a small Vintage Airstream, but that's probably about it. If you want to tow a modern Airstream, you will need at least a half ton truck/SUV to do the job for the smaller Airstreams.
SuEllyn & Brian McCabe
Old 04-11-2007, 08:10 PM   #7
_
hi jackie
nitro<<tab
ok
nitro<<<basecamp
ok
nitro<<<<vintage bambi
ok
nitro<<<<<modern twinkie
not ok...
go boom!
cheers
2air'
Old 04-11-2007, 08:16 PM   #8
ljmiii's Avatar
2006 16' International CCD
New York , New York
I have a 2007 Dodge Nitro...I'm not sure what the weight is for any airstreams so I'm thinking that the smaller ones would be suitable for hauling with my tow package.
A new 16' Bambi has a GVWR of 3500lbs (vintage bambis are considerably lighter). Another issue is the Bambi's dry tongue weight of 430lbs - it will try to go to 500+lbs if you are not careful. The tongue weight counts against your max payload of 1150lbs.
I assume 'hauling with my tow package' meant that your Nitro came with the Nitro trailer tow group - you'll need to add the coolers and class III weight distributing hitch (500/5000lbs) if you don't. Also, you didn't mention if you have the 3.7L v6 (210HP) or the 4.0L V6 (260HP) and if you have the 3.21 or 3.73 axle ratio.
All that said...if you have the 3.7L v6 and 3.21 axle towing the Bambi won't be fun...particularly on hills. My vote would be no. If you have the 4.0L V6 and 3.73 axle you should be fine. If you have the 3.7L and the 3.73 axle and you don't try to tow in hills or for long distances you'll probably live with it through your lease and then upgrade your tow vehicle.
ljmiii is offline   Reply With Quote
Old 04-11-2007, 08:23 PM   #9
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
Depending on how far you roam, and how frequent, you might consider going with a dedicated TV. Hey, budget dictates and I undertowed for a long time...not much fun..but keep a vehicle that seldom rolls except on the occasional weekend. Some of the thirstier older workhourses can be found reasonbly and usually insurance gives you a break if it is not a heavy driver.
Good luck and welcome aboard.
Rob and Terry
Catmando
"There’s not much in life we can’t over-analyze”
rmpray is offline   Reply With Quote
Old 04-11-2007, 08:45 PM   #10
bobkelly's Avatar
2003 22' International CCD
Whittier, California , Depoe Bay, Oregon
Welcome
Jackie & Rob---Welcome to travel trailers and the forums. You are smart to ask questions and many people here will provide you with their experiences.
Much has been written here in the past couple of years about minimum tow vehicle characteristics for a given size trailer. Use the search function and enjoy the reading. You will see discussions about how tow vehicle weight, wheelbase and power influence both safety and satisfaction with the trailering experience.
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Old 04-11-2007, 09:17 PM   #11
ljmiii's Avatar
New York , New York
As I mentioned earlier, your Nitro may be fine depending on your engine and axle ratio. That said, what follows is a list of the tow vehicles used by those on the forum with 2006 and 2007 16' Bambis:
1995 ford ranger
2000 astro van
2005 Dodge Dakota V8
Dodge Ram 2500 TD
2004 Chevy 2500 Diesel
Dodge Durango
Range Rover
2001 GMC Youkon Denali
2005 Jeep Grand Cherokee
2005 Toyota Tundra 4x4 4dr
2006 jeep liberty
2006 Toyota Highlander Hybrid
2004 Toyota 4Runner
1997 Chevy Tahoe
Range Rover Supercharged
2005 Toyota Tundra dual cab
1996 Toyota Land Cruiser
1968 Wagoneer
2001 GMC C3
2003 Honda Pilot
2001 Range Rover Discovery
2007 Yukon Denali
1993 Suburban
2007 GMC Acadia
2004 Lexus LX430
Toyota FJ Cruiser
honda ridgeline
jeep grand cherokee
2004 Tacoma 4x4 V6
2006 Toyota 4runner Sports Edition
1990 Ford pickup
2002 Jeep Liberty (3.7L)
2002 Volvo X Country
2007 Honda Ridgeline
Old 04-12-2007, 07:49 AM   #12
Airstream Dreamin'
Thanks for all the useful information. You all really know what you are talking about and thanks so much for the list of vehicles that will tow a Bambi. My husband and I currently restore classic cars and would really like to find a Bambi that has a good exterior appearance but needs some TLC for the interior and since it's considerably lighter then the newer models, by the time we are ready to road test it, I will have another vehicle that can actually tow it. Thanks again everyone.
Northern Ohio
Newbie vallan1980 1969 Overlander 27 07-11-2009 03:53 PM
Newbie Overlander Towing Questions 63overlander 1960 - 1964 Overlander 17 05-20-2005 10:44 PM
Newbie Needs Info... TheJarvis Our Community 13 11-06-2002 09:31 AM
Newbie looking to restore old AS Paul Brown Our Community 1 10-05-2002 05:04 AM
General Engine questions from a newbie ErichC Mechanics Corner - Engines, Transmission & More... 1 07-07-2002 05:23 PM
