newbie question,please be gentle..2002 gmc express
ok here are the numbers from my door sticker...gvwr 8600,gawr(frt)3800 and lastly gawr (rr)5360 with these numbers what should I stay away from weight wise ? (in other words how heavy is too heavy ? would a 3,640 dry weight trailer be just right or what ?any info would be most helpful!! Thank You All !!!
You need two more numbers before you can get an intelligent answer. Towing capacity and GCW (gross combined weight). Both should be in your owners manual. If not, see your dealer. You should not exceed either.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
