Old 05-10-2015, 03:28 PM   #1
1985 34' Excella
Mineral Wells , Texas
Newbie needing towing vehicle
We purchased our first AS - an '85 Excella which is 34 ft in length and weighs 5,800 lbs. we're looking for a new truck and would like any suggestions that might guide us to a truck that could handle this size of camper. We currently have a 95 Chevy Silverado and it's days are numbered.
Bud
Budmart1 is offline   Reply With Quote
Old 05-10-2015, 04:14 PM   #2
JimGolden's Avatar
1977 31' Excella 500
3/4 ton with Big Block or Diesel
Bud,
You will probably see that you'll open a big can of worms with this post....you will get answers ranging from a bicycle to a Kenworth.
A 34' triple can be towed with a front wheel drive Chrysler LHX or similar if it's set up properly. But I wouldn't recommend it.
I pull a 34' triple axle Avion (very similar to Airstream). I use a 3/4 ton pickup and it's been just fine. That is what I would recommend to you.
With the 34's, you get into several things: First is tongue weight. Second is gross weight. Third is how much stuff you want to take with you on top of pulling the trailer (do you want to take your Polaris Sportsman 500 ATV in the back of the truck?).
The triple axles track very nicely. I would argue that they are the most stable of any of the Airstream travel trailers. They pivot about the center axle and you must "scrub" the fore and aft axles to turn sharply. If you make a really sharp turn on a blacktop parking lot, you will see some blackmarks. Don't worry about knocking the tires off the bead...that is essentially an old wive's tale unless your tires are down to 10psi...
But, to answer your question, based upon my experience pulling a 10,000lb gross weight triple axle 34' trailer (actually Avion's are 36')....I recommend a crew cab long bed 3/4 ton pickup. I use a Dodge 2500 with the Cummins Turbodiesel. I've gotten 16mpg on level ground running 60mph or slower, 12mpg on the slab running 75mph (forget ST tires...they are junk; use LT's...but that is a whole 'nother topic that you can find on here).
So: 3/4 ton truck with long wheelbase and big motor and you will be fine.
See ya on the road,
- Jim
JimGolden is offline   Reply With Quote
Old 05-10-2015, 04:19 PM   #3
andreasduess's Avatar
1984 34' International
Toronto , Ontario
There are many, many threads worth reading on this.
First off, congratulations. The big triple axles tow beautifully. We've got a 1984 International, with a similar weight.
We are, happily and safely, towing with a Honda Odyssey van which we'll replace next year with a Dodge Durango. You don't need a huge truck for these trailers, for as long as you have them decently set up.
andreasduess is offline   Reply With Quote
Old 05-10-2015, 07:27 PM   #4
1985 34' Excella
Thanks for the input. Except for a couple bicycles, we'll probably only be hauling clothes and food for my wife and myself along with our daughter when she's home from college. Our 3/4 ton Silverado seems to handle well enough and will probably look for something similar. Thanks again.
Old 05-10-2015, 07:34 PM   #5
1994 34' Excella
Warren , Manitoba
I pull our 34' with a 3/4 Chev diesel. I like the power and the mileage of the diesel. Everyone has their opinions of tow vehicles and set ups. Bigger truck is my preference, because I do not have to worry about any overload problems, or tongue weights. Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 05-10-2015, 07:40 PM   #6
87MH's Avatar
1978 31' Sovereign
Images: 292
5800 pounds?
Prior to doing anything, I would suggest loading the trailer for camping, then obtaining an actual weight of both the trailer and the truck.
The results may surprise you.
Please post back to this thread with the actual weights.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 05-10-2015, 08:07 PM   #7
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Congrats. Can of worms, yes. First, ask what you want. Then find that in what meets your needs.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 05-10-2015, 09:04 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
See my avatar. 2012 Duramax 4x4 crew cab. 9-12MPG below 62MPH. PROPRIDE antisway hitch, Goodyear 15" LT tires, tire pressure and temp sensor.
Also, consider Centramatic static balances. Will reduce vibration significantly.
The rigging is key.
Congrats!
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-11-2015, 08:52 AM   #9
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
i agree 100% with this post.
Anything less will be a disappointment.
Originally Posted by JimGolden View Post
Bud,
See ya on the road,
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 05-11-2015, 09:09 AM   #10
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The choice of tow vehicle has as much to do with how you plan to travel as how big your trailer is. While a gas powered 1/2 ton pickup with a standard bed is capable of pulling ANY Airstream ever made provided you don't overload the bed, and many larger SUV's will do the same, and it's even possible to tow most Airstreams with a large four door sedan, if you are a full timer (or long term traveler) you will appreciate the benefits of larger and more capable cargo space that a 3/4 ton pickup will provide. In your case, it appears that you are still employed and will be a "weekender" and "working person vacation" kind of traveler in a relatively flat part of the country for the foreseeable future so you can err on the side of a smaller and less powerful tow vehicle than a 3/4 ton if that is your preference.
Bob Martel
WBCCI# 5766
Old 05-11-2015, 09:32 AM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
BTW.. Dry weight.. empty... over 6000# by the time I loaded batteries, spare tire, etc... essentials and a full fresh water tank, I was around the 8500# on the Airstream...
Channing
WBCCI# 30676
Old 05-11-2015, 11:14 AM   #12
2005 28' International CCD
Biscayne Park , Florida
Tow Vehicle
We have been towing a 28' Interntional CCD with LOTS of stuff in trailer for about 60,000 miles with 2005 2500 Diesel Silverado. Plenty of torque even for Rockies and the hills of Baja California. Truck now has about 220,000 miles. Rebuilt Transmission at 180,000 (it was those hills of Baja that did it in I think). We have the long wheelbase crew cab model which was a pain to park in an apartment building. But would definitely recommend the long wheelbase for our trailer.
mrawson1 is offline   Reply With Quote
Old 05-11-2015, 11:36 AM   #13
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Drive the '95 till it dies and get a newer truck. A newer half ton is more capable than your '95, but if you can afford a 3/4 ton-
Weight distribution and anti-sway are a must, even if you choose to tow with a mini van.
I tried to buy a 1988 34' from a guy who towed it with a Lincoln Navigator. My plan was to tow it with my 1/2 ton pickup.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-11-2015, 11:49 AM   #14
CentralAir's Avatar
2003 22' International
Park Ridge , Illinois
You indicate 5800 lbs. The factory document shows GVWR at 8900 lbs.
A 2500HD Silverado is a great choice and even better with the optional diesel.
Be careful on towing the 34' with a truck that is not rated for the true packed weight with tanks full. Good luck!
CentralAir is offline   Reply With Quote
Newbie Needing Advice… kdhouston Member Introductions 7 08-27-2013 11:02 AM
Newbie needing some Californian/UK HELP??!!!!!!!!!! montreal Classic Motorhomes 2 10-07-2011 03:34 PM
complete newbie, already needing a shell off? joesheehan Repairing/Replacing Floor &/or Frame 9 03-02-2011 06:39 AM
Airstream Newbie Needing Advice Please StephenBell Jacks, Stabilizers, Lifting and Leveling 6 09-23-2010 01:21 PM
Newbie Needing Electrical Help iHayley Electrical - Systems, Generators, Batteries & Solar 9 06-08-2008 07:36 AM
