Old 05-11-2015, 09:59 PM   #21
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by SteveH View Post
An '85 34' has an 8,900# GVWR.
I don't get the math on that. Generally trailer GVW is cut and dried- x# axle x 1, 2, or 3.
There are only a few axle weights- 3,500# 5,000#, and 7,000#, etc.
8,900 doesn't divide by 3 and equal a round number.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-11-2015, 10:02 PM   #22
m.hony's Avatar
2013 30' Classic
2,966.67# axles?
Hmm...
I would think three 3,500# axles for a GVW of 10,500#, but I wouldn't think those trailers would weigh anything near 8,900 dry weight.
TAC #MS-10
Airforums #70955
Old 05-11-2015, 10:09 PM   #23
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
We pull our 29" ambassador with my 2006 f150. It has the 4.6 v8, and honestly it feels underpowered. My next truck will be f250/350 or 2500 ram. Used truck prices for 250 or 350 are close so not sure what I'll end up with, I'm still dreaming...
Silverflames is offline   Reply With Quote
Old 05-11-2015, 10:27 PM   #24
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Look up the axle weight rating at airstream.com/service/partmanuals. The axles are listed there. My '06 has 3 3800# axles for a gross weight of 11,500#.
Old 05-12-2015, 06:32 AM   #25
SteveH's Avatar
Common Sense , Texas
I got the GVWR from Airstream specs, not from axle ratings.
Regards,
Steve
Old 05-13-2015, 12:39 PM   #26
m.hony's Avatar
2013 30' Classic
How does Airstream arrive at GVW#?
I thought it was pretty cut and dried-
Axle rating x number of axles.
Some gooseneck trailers are rated differently because they take into consideration the part that is in the truck bed- a gooseneck trailer could be rated 16,000# even though it has two 7,000# axles. Generally bumper pull trailers are cut and dried.
Hmm...
TAC #MS-10
Airforums #70955
Old 05-13-2015, 01:44 PM   #27
SteveH's Avatar
I think that's a question better asked of Airstream. Don't shoot the messenger.
Regards,
Steve
Old 05-13-2015, 02:06 PM   #28
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
..yeah.. and I don't see 10% on hitch tongue weight being a big hit on the overall axle capacity... just look at the ranges they offer....
While the 'weights and balance' is not as 'critical' as with aircraft... but still quite important, I would replace whatever 'stock' is for your AS... then see if you can add a few degrees of 'down' angle on the axles... that would lift the AS just a little... the new axle(s) plus the lift, perhaps requiring a 'recalibration' of your hitch solution, but should be good after that.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-15-2015, 07:56 AM   #29
2014 27' FB International
Longview , Texas
Has gotta agree with CentralAir... In fact pulling a 27FB Inbternational I just got rid of a 5.7 Tundra Limited and put it behind a dodge ram 2500. Not that the Trundra would not pull it, just not very well besides the 8 miles per gallon it used going 65 mph. simply did not feel conformable with it. Considering your curb weight empty of that trailer is roughly 8900 and my 27 is 5800 i would certainly do no less than a 3/4 with weight distribution and sway hook up. Then again that is just me.
Wayne Clamp is offline   Reply With Quote
Old 05-15-2015, 08:35 AM   #30
SteveH's Avatar
Posted this on another thread this morning, and I think it's just a relevant here:
"You can pull any Airstream ever built with VW bug, but at what safety margin, what reliability, what performance level, and what comfort level?
It's something the user has to decide."
Regards,
Steve
Old 05-15-2015, 12:04 PM   #31
m.hony's Avatar
2013 30' Classic
My experience with my Tundra and 30' Classic has been a little more favorable than that. I feel totally comfortable with my rig and have gotten as good as 13 mpg and get 12 mpg regularly. 10 mpg on the low side on a windy day.
Granted, I seldom ever exceed 60 mph. 65 is absolutely top speed for me, and would be top speed even in a 3/4 diesel.
Love my Tundra.
2nd choice, if I felt I had to, would be a GM Duramax/Allison.
The Tundra still has bigger back doors that open wider and more room in the back seat and the Tundra turns tighter, allbeit that may be because it is a 1/2 ton.
TAC #MS-10
Airforums #70955
Newbie Needing Advice… kdhouston Member Introductions 7 08-27-2013 11:02 AM
Newbie needing some Californian/UK HELP??!!!!!!!!!! montreal Classic Motorhomes 2 10-07-2011 03:34 PM
complete newbie, already needing a shell off? joesheehan Repairing/Replacing Floor &/or Frame 9 03-02-2011 06:39 AM
Airstream Newbie Needing Advice Please StephenBell Jacks, Stabilizers, Lifting and Leveling 6 09-23-2010 01:21 PM
Newbie Needing Electrical Help iHayley Electrical - Systems, Generators, Batteries & Solar 9 06-08-2008 07:36 AM
