Old 06-01-2015, 11:15 PM   #15
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Originally Posted by Ohiobrits View Post
SeaAirstream - my own experience with tongue weight on a 27FB International was as follows:-
Catalogue - 770lbs
With options - dealer estimate - 825lbs (2nd AC, 50A)
With options - "as weighed" at factory - 844lbs (I provided the VIN to the factory)
My own "as weighed" at home exactly as delivered - 900lbs (should have matched factory....?!).
I made some mods to the AS and had tongue weight down to about 650lbs with an Eaz-lift hitch (verified on CAT scale)
I'm now using a ProPride hitch which weighs in about 100lbs more than the Eaz-Lift. Tongue weight is around 750lbs fully loaded with water and all our normal gear (scale verified).
Clearly, you should expect something more than the catalogue values for tongue weight. I did a lot of trawling of these forums for tongue weight data and just about every post I found indicated higher than catalogue.
All is not lost though if you want to stick with your current TV AND feel the need to reduce tongue weight based on your research. Tongue weight reduction is possible, depends on how much time/money you are willing to spend to get there. The simple/easy option a lot of people go for is to "just" buy a TV with more payload/tongue weight capacity. In the end it's very much a personal decision.
Would it be possible to articulate what you feel is the best things to do to get ones tongue wright down.
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 06-02-2015, 12:15 PM   #16
phbarnhart's Avatar
2012 25' FB Eddie Bauer
Eugene , Oregon
Images: 14
We opted not to tow our 25' EB with our LR3 for the very reasons you've articulated. These threads go around and around but I think it boils down to modifying your vehicle's hitch (the LR3/4 hitch is odd), installing a brake controller and then ignoring Land Rover's max weights. If you're comfortable doing that, go for it. I wasn't comfortable with it. Either way, make sure you have roadside assistance that covers trailer towing (AAA does not by default so you should give them a call)
If you decide a vehicle change is in order, go check out the Yukon Denali or Expedition Platinum. Neither is as refined as the LR4 but both will tow your new trailer if you pack light.
phbarnhart is offline   Reply With Quote
Old 06-02-2015, 01:36 PM   #17
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
We use a Ford Ecpedition limited EL 4x4 to tow,it does a great job and is very pleasent to be in!
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 06-02-2015, 06:44 PM   #18
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
Arcticfox - take a look at this thread. Lots of discussion here on options (batteries, spare tires, propane bottles, load distribution in the AS) and some actual weights I collected during my decision making process. Towards the end are some pictures of the actual mods I did.
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 06-02-2015, 09:17 PM   #19
SeaAirstream's Avatar
Puyallup , Washington
This is a great thread @ohiobrits and interesting how the weight changed based on location. I am going to do the basic set-up on my LR4 (CURT hitch with WD) and of course brake control, then tow it from the dealership right to the scale. I opted against heavily modifying just yet to see what the weight is like and how much I like towing with the LR4. Our trips for the summer are mostly sub-1K trips and local in Washington (places we know), so going to take it slow and see how it goes. Then decide what truck or large SUV (e.g, Yukon) we decide to target for the long term. Safety first, then LOTs of fun is the plan.
I will update the string with pictures of our set-up and departure from the lot...
SeaAirstream is offline   Reply With Quote
Old 06-02-2015, 09:23 PM   #20
phbarnhart's Avatar
Eugene , Oregon
Images: 14
Sounds like a reasonable plan. Let us know how it goes!
Old 06-03-2015, 07:06 AM   #21
Ohiobrits's Avatar
Howard , Ohio
SeaStream - good plan. You may like it just fine as it is.
Old 06-03-2015, 10:01 PM   #22
LolaT's Avatar
2014 23' International
Salt Lake City , Utah
We were also able to go to a weight station the next day after picking up the 23D before really driving anywhere and it was reassuring to see that the right stuff seemed to be going on with the weight distribution system. Post it so we can sort of compare : )
LolaT is offline   Reply With Quote
Old 06-03-2015, 10:51 PM   #23
Will do. I'll post the readings from the weigh station. There won't be anything in the trailer and the WD will be on, so should be a pretty accurate dry weight, albeit the dealer will likely provide full LP tanks.
Old 06-05-2015, 10:39 AM   #24
runnersg's Avatar
2016 27' Eddie Bauer
TX , Texas
SeaAirstream... I opted to keep one of the full propane bottles at home while I travel. I too am evaluating my current setup so lightening the load wherever possible. Also doing 100% of packing in the back of the trailer and very little in the bed of the truck. Pulling a 27 Eddie Bauer that is tongue heavy by nature. (15% dry - so my assumption is they encourage back loading in the EB toy hauler)
runnersg is offline   Reply With Quote
Old 06-17-2015, 12:22 AM   #25
Name:	ImageUploadedByAirstream Forums1434522082.049431.jpg
ID:	240902 pick up day!!!Click image for larger version
Name:	ImageUploadedByAirstream Forums1434522150.104536.jpg
ID:	240903 first trip next weekend!!
Old 06-17-2015, 07:35 AM   #26
Arcticfox's Avatar
Central , Canada
Originally Posted by SeaAirstream View Post
Attachment 240902 pick up day!!!Attachment 240903 first trip next weekend!!
Good looking rig, with a couple happy looking campers. How did you find your dealing with Airstream NW. Is Danny Quintero still around there?
Old 06-17-2015, 08:30 AM   #27
Gsmblue's Avatar
Bend , Oregon
Sweet!
Old 06-17-2015, 08:44 AM   #28
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Good for you. What a thrill! Great looking camper, TV and family. Joe
jayseejay is offline   Reply With Quote
2013 airstream international sterling 27fb travel trailer brand new! eBay Watch Airstreams on eBay 0 04-30-2013 08:00 PM
2013 airstream international sterling 27fb travel trailer new trades welcome eBay Watch Airstreams on eBay 0 04-04-2013 06:10 PM
2013 airstream 27fb international signature travel trailer brand new! eBay Watch Airstreams on eBay 0 03-28-2013 06:10 PM
2013 airstream international sterling 27fb travel trailer brand new! eBay Watch Airstreams on eBay 0 03-14-2013 06:50 PM
2013 Airstream International Sterling 27FB Ultra Modern Luxury Trailer for Camp eBay Watch Airstreams on eBay 0 08-09-2012 10:00 PM
