Old 10-30-2007, 06:44 PM   #1
ptanner's Avatar
Casselberry , Florida
Newbe TV Questions
We are about to take the jump from a SOB (PUP) to a AS, probably 28-31'. My current TV is a V8 Chevy Tahoe with a tow package and a Prodigy brake controller and a SMALL sway bar. The owner's manual says I have 6900# of towing capacity. I have been assured by two sales people that I have plenty of pulling power...salespeople !! One, who is an experience RV'er assured me that since the AS had 40# of "bearing weight X 4 that I only needed 160# of pulling strength. That sorta made sense but then again it sorta didn't, if you know what I mean. Although my home base is Central Florida I plan pulling up and down something larger than an overpass most of the time. My questions are, can I get it up the mountain and can I stop it on the other way down? I realize I my next question is "what type of hitch?" but first I need to know if I can get it rollin'
Thanks for any help
Pete
ptanner is offline   Reply With Quote
Old 10-30-2007, 07:40 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
First of all, welcome to the Forums from the Florida Panhandle. We're glad to have you with us.
We have a 2005 Safari 25FB named Lucy. The rolling weight rolling is in the neighborhood of 7500#. Our primary TV in an '05 Suburban 2500 4x4x4 which does the job in all conditions. We also have an '04 Tahoe with Autoride. We have pulled Lucy with it a couple of times. The Tahoe's towing performance is marginal, at best. I wouldn't consider leaving Florida with the Tahoe doing the towing. The Tahoe is a great vehicle, but not towing a heavy trailer.
Remember that that the salesman will tell you that you that you could pull a 34 footer with a Ford Ranger.
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
newbe caperjoe Member Introductions 2 10-21-2007 06:45 PM
A newbe here... Peggy Member Introductions 7 10-10-2007 09:57 AM
I was a wantabe, now I'm a newbe Frank's Trailer Works Member Introductions 19 08-20-2007 04:34 AM
Greetings from a Norcal newbe gflaig914 Member Introductions 11 02-18-2007 10:42 AM
