Old 10-08-2013, 11:39 PM   #1
Jdh
1967 20' Globetrotter
Slc , Utah
New TV tonight, would love feedback
Just got home tonight with a 2010 Toyota Tundra 4.6 to tow my 67 20' globetrotter, would love some opinions. After getting on the forums I'm second guessing myself as to whether I bought the right truck...... I figured my trailer weight being 3000 lbs dry, the towing capacity of 7800 would be more than enough, with the 4.6 being a bit better on the mpg. Thoughts, anyone?
Jdh is offline   Reply With Quote
Old 10-09-2013, 02:36 AM   #2
r carl's Avatar
Lin , Ne
Try it out and then you will know.
Old 10-09-2013, 04:31 AM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
What r carl said.
If the truck can do 7800 lb and your trailer is 3000, can't imagine you have much to worry about! Hit the road and enjoy! :-)
SteveSueMac is online now   Reply With Quote
Old 10-09-2013, 04:57 AM   #4
andreasduess's Avatar
1984 34' International
Toronto , Ontario
You could tow that trailer with a much smaller car. You've got nothing to worry about. Enjoy
andreasduess is offline   Reply With Quote
Old 10-09-2013, 07:25 AM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Truck discussions here would have you believe you need twice the truck that can do the job well. Or that you are unsafe, or illegal, or just plain stupid if you don't. Or that an oversized truck is somehow better.
You and your wallet are better served overall by a truck that matches the trailer, and that one matches up very well.
Doug and Cheryl
Old 10-09-2013, 08:36 AM   #6
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
I think it's overkill.
Ahab is offline   Reply With Quote
Old 10-09-2013, 09:04 AM   #7
kennyp315's Avatar
1965 20' Globetrotter
Woodland Hills , California
Images: 8
Your Tundra is fine. I have a '65 Globetrotter and tow with a 2005 Tundra. On my rebuild of trailer, I added close to 1500 more pounds. I have a weight distributing hitch and have towed my trailer all over the Western US. It tows like a hot knife through butter.
kennyp315 is offline   Reply With Quote
Old 10-09-2013, 10:27 AM   #8
dkottum's Avatar
We towed our 2007 20' Airstream 5000# fully loaded cross country through mountains with a 2006 Tundra small V8 and it felt unstable at times. The standard P (passenger) tires were too soft a sidewall allowing sideways motion in winds, trucks passing. Called Andy Thomson at CanAm Airstream in Canada (they specialize in all types of towing setups) and he recommended a XL (XL rated tire) of a specific size. Great improvement in stability.
The power was fine, keep it out of overdrive (or use tow/haul mode if you have it) when towing. Shift down as needed to keep 3500 rpm when climbing steep grades, and always approach steep descents slowly and shift the transmission down as needed to keep it that way. The cause of many power complaints is unwillingness to simply use the transmission as needed.
Doug and Cheryl
Old 10-09-2013, 12:52 PM   #9
mandolindave's Avatar
It sounds like a good match
Truck discussions here would have you believe you need half the truck to do the job well ( just kidding)
But I think the right size tow vehicle has more to do with than just the size of the engine and trailer weight as factors.
I think that suspension, weight of the tow vehicle, wheel base of the tow vehicle, and braking also make for a safe match.
It has been said that you can damage your trailer, by getting to " much " of a truck. A suspension set up that is to stiff, could cause stress to your trailer.
I would recommend a weight distribution hitch. Besides safety, I get a nicer ride, with less porpoising. I found this out once when I left the bars off, while I was looking for level ground to put the bars on.
mandolindave is offline   Reply With Quote
Old 10-09-2013, 01:02 PM   #10
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
I'm in agreement with that, Doug. Too often we hear complaints about down-shifting, but isn't that what the transmission is supposed to do? OK, constant upping and downing isn't good, but there's nothing wrong if the transmission down-shifts to deal with a gradient.
I couldn't venture an opinion about the Tundra other than the fact that it's a popular tow vehicle and clearly works for a lot of people
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 10-09-2013, 11:27 PM   #11
Jdh
Slc , Utah
Thanks all, hooked up the trailer today for a short trip around town to get a feel, I felt a lot more comfortable than with my last vehicle. Then promptly jack knifed backing it in and put a nice big dent in my shiny new bumper like an idiot. Sigh.
Old 10-10-2013, 04:15 AM   #12
W , New England
Those are just "character" marks. :-)
Glad you're happy with the truck!
Old 10-10-2013, 04:37 AM   #13
r carl's Avatar
Lin , Ne
Alway's take it easy while backing. Also try to have someone back there watching the whole operation communicating with you.
Old 10-10-2013, 05:12 AM   #14
I have a small Argosy 20'
A little bit of correction goes a long way when backing up a trailer that has wheels so close to the hitch. ( I think it's true for bigger trailers, but maybe not as much, as I have no experience with the huge trailers )
