Old 11-24-2010, 05:42 AM   #1
Snedwid's Avatar
2011 23' FB Flying Cloud
Perry , Florida
Question New Shocks on tug
While rotating tires on my tug ('04 F-150 4wd) I noted that the rear port shock is leaking. Needs replacing. Questions: Other than matching original equipment, are there any other options that I should consider? Should I replace both rears at the same time? What about the front struts?
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Old 11-24-2010, 06:09 AM   #2
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
I am unsure if you need to replace the front struts - I would look at the vehicle maintenance schedule. I was always told "that if you replace shocks on one side then you need to replace both". I was also told that if one shock fails then replace them all - the others will soon follow.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 11-24-2010, 06:54 AM   #3
SteveH's Avatar
Common Sense , Texas
When I bought our '08 GMC 2500 used with 50K+ miles, the shocks seemed too soft. With recommendation from the GM truck forum, I replaced them all with Bilstein shocks. I really like them.
I would at a minimum replace both rear shocks, and at a minimum with original equipment quality.
Regards,
Steve
Old 11-24-2010, 06:55 AM   #4
SteveH's Avatar
Sorry, somehow got a double post.
Regards,
Steve
Old 11-24-2010, 07:22 AM   #5
Wayward's Avatar
Cary , North Carolina
Senatrac is good choice for the money
I put these on my 1/2 ton. Seem as good as OEM, Konis and Ranchos I've had for normal driving, but were a big improvement while towing with WD hitch - especially at front wheels. More stable when braking. Less "hobby horsing" on intestate.
Got great price at Advance Auto with lifetime replacement warranty.
Monroe Sensa-Trac Truck Shocks - The Best in Safety and Stability
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 11-24-2010, 07:27 AM   #6
dznf0g's Avatar
Oswego , Illinois
Always replace in pairs (across axles). How many miles on the fronts? If they have more than 60 - 70K on them, I'd go ahead and do fronts.
All the brands above are good choices.
Old 12-02-2010, 03:20 AM   #7
Snedwid's Avatar
Perry , Florida
Tnx for the advice,,, I bit the bullet and replaced them all around. The truck has >84K and these are the first tires and shocks that I've had to buy. I do pay good attention to pressure, balance and alignment.
Snowmobiling in Tug Hill, NY Catman6 Off Topic Forum 16 02-16-2010 01:42 PM
Shocks or no shocks with new Dexter Axles? nick6930 Axles 5 04-13-2009 03:41 PM
Which shocks? bobfowler Tow Vehicles 6 11-15-2007 08:35 PM
shocks Al1 Shocks 1 07-11-2003 01:21 PM
Shocks: Chuck On The Road... 4 04-30-2003 02:46 PM
