Old 10-09-2010, 05:36 AM   #1
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
new shocks for tow vehicle
I have sticker shock...how much do shocks cost? My 2004 GMC Serria Quadrasteer AWD....rear $1000.00 Front $650.00
Is this right??????????????????? and 100,000 miles.....should I change...they feel solid
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 10-09-2010, 06:50 AM   #2
1986 25' Sovereign
Plant City , Florida
That does not sound right at all unless you are upgrading to a longer shock with a separate oil pack. Bilstens should be around 150-200 per shock.
ck21084 is offline   Reply With Quote
Old 10-09-2010, 06:52 AM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Please include the model no, 1500 2500 ? and engine.
Shocks do age, wear or leak, sometimes they age gracefully and you may not realize the effects unless you try new shocks. I took a quick look but needed to pin down the quadrasteer option.
GCinSC2 is offline   Reply With Quote
Old 10-09-2010, 07:14 AM   #4
Wayward's Avatar
Broadway , North Carolina
Personally, I'd not even replace $100 shocks unless they were bad. When the front shocks started going out on my 1/2 ton, it was most noticelable with the trailer hooked up on the weight distribution hitch. It would rock like a hobby horse when coming to a stop.
There are probably folks here that know more, but I would not think Quadrasteer would require special shocks. Maybe your truck has a option with the Delphi MagneRide shocks? They have electronics to adjust shock dampening actively.
When the time comes, you probably could replace them with passive adjustable dampening shock like Monroe Sensa-Trac.
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
Old 10-09-2010, 08:05 AM   #5
Wayward's Avatar
If the steep price tag is not due to electronic dampened shocks, it could be you have the airshocks (auto leveling) option. In that case, here is a replacement:
http://www.arnottindustries.com/part_GMC_Air_Suspension_Parts_yid15_pid95.html
2006 Safari SE FB
Broadway, NC
Old 10-09-2010, 09:44 AM   #6
GCinSC2's Avatar
My new suspicion is this truck is equipped with a special shock and or rear strut system for the Quadrasteer option and I saw a with ZX3 electronic ride control option show up in a listing.
Me thinks very special components, but the owner will need to specify M/M/Y/Engine (possibly) and factory options for the suspension.
Good luck.
Old 10-09-2010, 03:54 PM   #7
Islander
shocked
in the cab truck has a button that is labled manual selectable ride switch. this makes for a stiffer or softer ride...
again, i made the parts people input my vin and the came up with shocks
that cost $429 each for rear and $325 for front...
I want original equipment ...so is this the price to paY...does it seem prudent to replace at 100K if pulling trailer fultime???
2004 GMC Sierra K15 Denali truck with all time all wheel drive and quadrasteer.......
Kingfisher24
WBCCI 2541
4CU
Old 10-09-2010, 10:50 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
With an ordinary workaday sort of a shock it would be reasonable to replace it as a scheduled maintenance item after 100k. Given the costs you will want to ascertain whether the shocks are shot and if so which ones. Are there visible oil leaks? What is the ride like? When you tow are you satisfied with the ride?
Old 10-09-2010, 11:31 PM   #9
Hephzibah , Georgia
The quadrasteer is what makes suspension parts approach $1000 for what would normally cost around $200.
Im sure its a useful feature, but that feature entails paying a lot of money for maintenance.
nti06 is offline   Reply With Quote
Old 10-10-2010, 05:59 AM   #10
Islander
thanks to all
I am sure you are quite right about the quadrasteer increasing the price of the suspension parts...but hey, I have the truck and it is paid for so i go with it....
the ride is solid and i most likey will not change the shocks at this point...
the truck is solid as a rock from front to back and i was going to do some other stuff, but the dealer leaves a lot to be desired in confidence so....i don't know
In 100k i have not replaced spark plugs.....how long should one go before replacing....
fuel injection service????
Kingfisher24
WBCCI 2541
4CU
Old 10-10-2010, 06:04 AM   #11
GCinSC2's Avatar
This sounds like the ZX3 option which may or may not be bundled with Quadrasteer, I don't know. To confirm look for a build sticker (sometimes on the glove box door or underhood) or the original window sticker. They will list the factory Regular Production Options, ZXE is an RPO. Are ZX3 and Quadrasteer the same RPO?
Unique limited edition options, Quardasteer and electonic ride controls often are not well supported in aftermarket parts due to limited vehicle population, features and tooling and development costs. GM may be the only source. But before you jump to that conclusion, can you look on a shock and see a manufacturer's name? Search that name and see if they sell aftermarket or just GM. Also might want to search in Google for your inquiry, it will often lead to a thread on a GM P/U forum that you would not be able to see w/o joining and searching within that forum.
Old 10-10-2010, 06:08 AM   #12
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
Plugs should be replaced at 100K. Fuel injection service is a little more iffy. I'm of the opinion that it is ussually not nessasary. Adios, John
Diesel1 is offline   Reply With Quote
Old 10-10-2010, 06:21 AM   #13
r carl's Avatar
Lin , Ne
I wouldn't change them, they may go more than 200k.
Old 10-10-2010, 06:30 AM   #14
Vintage Kin
Fort Worth , Texas
Beyond build sheet/data tag/VIN, check over on an enthusiast site. May well be that someone -- several someones -- have already made some in-depth examinations of the vehicle/mileage/shock absorber questions. The Internet has made this quite easy compared to the day of magazines and getting to know mechanics and dealer service personnel. Until less than 10 years ago I was still behind the counter at NAPA where I was known working the huge paper catalogs to pin down all the cross references on shock absorbers on some ancient cars.
I'm a believer in preventive maintenance -- replace it before it breaks/is worn out -- but your fancy schmancy shocks may last a very long time depending on type. You've a unique vehicle, so, on the other hand, better safe than sorry. But don't trash the old ones, just clean 'em, box 'em, store 'em . . never know that those old pieces may someday be gold.
Good luck
Old 10-10-2010, 06:30 AM   #15
r carl's Avatar
Lin , Ne
I would replace the plugs with what GM recomends.
Replace your fuel filter(s) and add a can of Seafoam to tank.
Old 10-10-2010, 06:59 AM   #16
Vintage Kin
Fort Worth , Texas
BG44K is the old standard reliable fuel system cleaner. Though the formulation has changed, it is miles better than Seafoam (a low dollar, harsh additive). REDLINE and others also make some decent stuff, but BG44K is still standard.
BG Company
As to sparkplugs, again, check against enthusiast boards. Every now and then an alternate selection is a slight bit better (expensive iridium plugs for example).
Old 10-10-2010, 08:11 AM   #17
r carl's Avatar
Lin , Ne
BG Company
True REDNAX, I was hesitant recomending seafoam but it is easily available and better than nothing.
I presonally use Lubrication Engineers products as I have found none better in the last 25yrs, this is the additive I use.
http://www.le-inc.com/products/documents/2300_flyer.pdf
Old 10-10-2010, 03:10 PM   #18
Islander
thanks to all
many choices.....study long...study wrong
Kingfisher24
WBCCI 2541
4CU
Old 10-10-2010, 09:40 PM   #19
Vintage Kin
Fort Worth , Texas
Hey, I've been using LUBE CONTROL LC-20 for nearly 40 years, off and on! FP-60 FUEL POWER has been good to me in diesel and gasoline vehicles (consistency).
Lube Control Distributors
LE was practically next door when I lived in DFW.
And, I guess we both value SCHAEFFERS
Schaeffer Oil | Diesel Fuel Additives, Conditioners, Treatments
I hear good things about their diesel soy fuel additives but haven't yet tried them (from a tribologist and others).
The one I ALWAYS recommend from their line is CLEAN & COOL #258 (as many already understand that their grease and lube oils can't be beat for value).
To the OP: SCHAEFFERS is carried by some NAPA stores now if interested. Main business of America's oldest oil company has always been industrial and agricultural. Truckers know them, too.
Can you tow a 31' with 12 a bhp tow vehicle? goatfarmer Member Introductions 6 06-30-2010 10:40 PM
Possible tow vehicle...! aircooled4 Tow Vehicles 10 11-16-2008 11:04 AM
Best tow vehicle? Chef Jeff Tow Vehicles 88 10-25-2008 09:26 PM
Tow vehicle help...please pamelake Tow Vehicles 8 11-06-2005 06:59 AM
where to look for tow vehicle remcolent Tow Vehicles 5 07-13-2004 10:39 PM
