Old 03-04-2007, 12:46 PM   #1
New clean diesel...or not?
Just about to plunk down more than 40 thou. on a '07 Chev. crew cab with the diesel/allison and given the recent mandated changes in thw new Ultra Low Sulphur fuel, not so sure that I'de be better off with a new '06 or will the '07 perform as well.
Whould appreciate any thoughts/observations/opinions in that regard.
Thanks a million;....or at least 40 thousand.
Topcat
Terry C. Tullier is offline   Reply With Quote
Old 03-04-2007, 12:52 PM   #2
hiker's Avatar
2007 25' International CCD FB
Needham , Massachusetts
Topcat
You may find this thread interesting:
2007 classic vs. 2007 2500HD - Diesel Place
The Diesel Place is a forum similar to the Airstream forum but devoted to all things Duramax. I have found it to be a source of good information.
Mike & Joan
WBCCI #1521 New England Unit
06 Chevy Duramax/Allison
hiker is offline   Reply With Quote
Old 03-04-2007, 12:58 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
You'll get a lot of AS Forums threads discussing the subject if you enter ULSD into the search field to the right on the blue bar above.
5 meter Langford Nahanni
Old 03-04-2007, 03:55 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Is it just the motor, or the ride?
I just went thru the same purchase ordeal. After years with the 250 HD PSD (Ford) I switched over to the Duramax/Allison combo. I went with the 2006 instead of the 2007 specifically for the LBZ motor....not available in 2007. In my ops I can't be burdened with searching out the "correct" fuel. Occasionally red diesel gets put into the truck. Bio is also available to me. You don't have that choice with the new '07 motors. You will never regret the HD choice if there is towing in your future. When you need it...you really need it. Duramax is way more quiet than the PSD....the ride is almost too spongey. The HD Chev truck is generally more "humane" than the Ford too. LT3 trucks appear to be about 3000 to 4000 cheaper here in Texas than West of here...don't know about the East. I hope it works out for us both.
Diesel tow vehicle-tips? maxandgeorgia Tow Vehicles 27 08-27-2006 10:28 PM
Regarding original water tank clean out - thank you! 60stradewind Fresh Water Systems 0 08-22-2002 12:00 AM
Question re how to cut aluminum sheeting and get a clean edge... williamhenshall Ribs, Skins & Rivets 7 06-12-2002 05:58 PM
inside light lens' how to remove to clean Paul Daugherty Mechanics Corner - Engines, Transmission & More... 12 04-25-2002 10:51 PM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
