Old 03-15-2015, 07:22 AM   #71
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
There is a reason that all the big trucks on the road today are diesel.... Most of the smaller vehicles in Europe are diesel, you get better power and fuel economy with diesel, no such thing as too much horsepower, or money!
Old 03-16-2015, 09:36 AM   #72
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Average price of diesel in UK in Feb was 115p per liter. 3.785 liters per US gallon. 115p is about $1.70 today. So a US gallon of UK diesel is about $6.43/US gallon, about $4/gallon higher than locally. To fill up a F250 6.7L 26 gallon tank, say 23 gallons would be $148, ouch!
Kelvin
Old 03-16-2015, 06:54 PM   #73
N/A , N/A
Originally Posted by silverbp View Post
Well kelvin Im not sure where you got your data on the Payload for the Ford 2015 F250 diesel. I have the very truck your talking about and the number or info that came with truck is 3000 lbs. Thats also what the Ford website has listed as well.
Sent from my iPhone using Airstream Forums silver bp
The 3000# payload that Ford advertises is the maximum payload, and usually you can only get it in regular cab work trucks with little options. The sticker on the driver side door, on the other and, is the payload for your truck, and is usually several hundred pounds less than the maximum payload. All the other car companies follow the same practice (unfortunately).
rostam is offline   Reply With Quote
Old 04-06-2015, 04:12 PM   #74
Firedog1
Firedog1's Avatar
2018 30' Classic
Woodbridge Connecticut & , Venice Florida
1936 payload on my 2015 F250 king ranch 4x4 dieselClick image for larger version
Name:	ImageUploadedByAirstream Forums1428358323.502246.jpg
Russ and Lisa
2018 Classic 30
2015 F250 King Ranch 4x4 turbo diesel
Sold but not forgotten: 2005 Classic 25 Limited
2015 Classic 30 RB
Firedog1 is offline   Reply With Quote
Old 04-06-2015, 07:13 PM   #75
N/A , N/A
Originally Posted by Firedog1 View Post
1936 payload on my 2015 F250 king ranch 4x4 dieselAttachment 235748
Thanks a lot for sharing this
Old 04-06-2015, 11:13 PM   #76
Firedog1
Firedog1's Avatar
2018 30' Classic
I think if I had to do it over again, I would get the F350 because Im now overloaded and sagging in the rear with 1000 lb tongue weight, 50 gal fuel, generator, bed slide, leer cap, gear & passengers etc... Now Im trying to decide if I need airbags or level ride system? Anyone that has level ride or airbags any advice would be appreciated.
Russ and Lisa
2018 Classic 30
2015 Classic 30 RB
Old 04-07-2015, 05:20 AM   #77
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Might be cheaper to add a spring to the rear.
Our F350 Diesel has a DOOR STICKER (for those who question) that reads payload of 3,382 pounds.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 04-07-2015, 05:37 AM   #78
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Russ,
I have adjustable airbags on the rear of my 250. When I load up the bed I make sure that the measurement from the top of my tire to the fender rim remains at a constant 9", which is the unloaded measurement. Remember, that the only difference between the 250 and the 350 is the rear spring as i have been told. Say hello to Linda for us.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 04-07-2015, 05:50 AM   #79
Firedog1
Firedog1's Avatar
2018 30' Classic
Thanks Ron, which air suspension do you have? That's what I will do to correct the problem.
Russ
Russ and Lisa
2018 Classic 30
2015 Classic 30 RB
Old 04-07-2015, 05:59 AM   #80
Gainesville , Florida
My one ton Dodge has a payload of 3500 pounds, newer ones are even higher. Rides like a truck because that Is what it is. Short bed crew cab diesel. I use minimum wd and of course sway control. I only use the wd because that was the easiest way of adding sway control. 2006 model year with 32 gallon fuel tank. 14 to 15 mpg towing at 65 or less. Peace,jim
Old 04-07-2015, 06:27 AM   #81
Storm Master
Ampman's Avatar
2005 25' Classic
I have had the Firestone bags on my old truck. Ok, but you needed to keep a minimum of five pounds in them. I currently have the Airlift bags with the internal jounce bumper built inside on my current truck. Can run with zero air pressure when unloaded. Pretty easy install and gives me an onboard air supply for other needs. Mounted the pump, switch and stuff on the inner wall of the bed where I can reach it all when hitching up.
Ampman is offline   Reply With Quote
Old 04-07-2015, 08:09 PM   #82
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
New 2015 Ford F-250
I would just install a F350 rear leaf spring pack.Your ride will remain the same.When loaded the overloads come onto play and the truck rides good.Without a load it will ride on just the primary leaf an give you the smooth ride your F250 provided as they are the same.
I have a 2015 F350 so I can attest to the above stated facts, I also had a 2012 F350.The 2015 springs ride a little smoother but both ride better than my previous 2010 F150 with a 1790 lbs payload capacity.
Replacing the leaf springs on your truck is a simple solution as F250 and F350 interchange.Simple.
Old 04-08-2015, 05:43 AM   #83
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Interesting. I'm looking at moving to a 250 as well. Seems like it makes sense just to get the 350?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 04-08-2015, 09:11 AM   #84
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
I have the Firestone air bags with on-board compressor (mounted under the hood on the wheel well) on my F-250 and it has been a really good addition. I can pack the bed full and with the 1,000 lb hitch weight, I can still keep things level. Once unloaded and un-hitched, I lower the air bag pressure to 5 lbs and the ride is really good for an HD truck.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
NorCal : 2015 Jackson Rancheria Fally Rally October 9-11, 2015 Coastalview Forum Rallies & Meet Ups 48 05-30-2017 01:49 PM
2015 F-250 6.2 vs 6.7 keith49090 Tow Vehicles 71 02-16-2015 07:21 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
250 MH :: 1990 Airstream 250 barend Airstream Registry Discussions 0 08-19-2011 08:32 AM
