Old 02-04-2015, 12:32 PM   #43
Firedog1
Firedog1's Avatar
2018 30' Classic
Woodbridge Connecticut & , Venice Florida
I did replace the fuel tank with a 50 gallon now can tow 700 miles before I refuel
Russ and Lisa
2018 Classic 30
2015 F250 King Ranch 4x4 turbo diesel
Sold but not forgotten: 2005 Classic 25 Limited
2015 Classic 30 RB
Firedog1 is offline   Reply With Quote
Old 02-04-2015, 01:03 PM   #44
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Did that replace the existing tank and integrate with the electronics? I guess that added about 200lbs compared to an existing full tank?
Kelvin
Old 02-04-2015, 01:25 PM   #45
Firedog1
Firedog1's Avatar
2018 30' Classic
yes it replaced the existing tank and yes it integrated with electronics. I had the Ford dealer do it. They installed the Titan 50 gallon tank and reprogramed the computer to recognize 50 gallons. works perfectly. Took less than 3 hours, I waited while they did it.
Russ and Lisa
2018 Classic 30
2015 Classic 30 RB
Old 02-04-2015, 03:07 PM   #46
Storm Master
Ampman's Avatar
2005 25' Classic
2012 6.2l crew 4x4. Empty I get 14-15. Towing around 8k lbs I get 11-12. Great electronics. Navigation is ok until you get way off the road. Would buy again but not for many years. Can't afford to get a new truck every few years. Diesels are great if you tow over 10k and trade every few years. Couldn't afford to own one past the warranty period. There's something for everybody all you have to do is sign on the dotted line.
Ampman is offline   Reply With Quote
Old 02-04-2015, 04:21 PM   #47
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
MoFlash says his 6.7 Ford diesel is as cheap to maintain as an F-150 is smoking something. An F-150 Ecoboost is about $50 every 7500 miles for an oil change and $15 for a fuel filter every 15k. An oil change on a 6.7 is $100-150 depending on who does it and the fuel filters are $100+. Add that to the additional cost of the diesel over gasoline, plus the initial cost of the diesel engine, $8,000, then you have a substantial fence to hurdle before you catch up with an F-150 gas rig.
Again, I think the new 6.7 is a very good engine, with lots of power, but one does not NEED a diesel to tow an AS, all you diesel heads WANT one, and that's ok with me.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is online now   Reply With Quote
Old 02-04-2015, 06:24 PM   #48
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
[QUOTE=pappy19;1577027]MoFlash says his 6.7 Ford diesel is as cheap to maintain as an F-150 is smoking something. An F-150 Ecoboost is about $50 every 7500 miles for an oil change and $15 for a fuel filter every 15k. An oil change on a 6.7 is $100-150 depending on who does it and the fuel filters are $100+. Add that to the additional cost of the diesel over gasoline, plus the initial cost of the diesel engine, $8,000, then you have a substantial fence to hurdle before you catch up with an F-150 gas rig.
Again, I think the new 6.7 is a very good engine, with lots of power, but one does not NEED a diesel to tow an AS, all you diesel heads WANT one, and that's ok with me.[/.
Once again a man that speaks from no experience.I have had two 6.7's.in the past 3 years.I have also owned many F150's.My oil changes run $89 including tax.The fuel filter is less than $100 if the dealer installs it.I will install one during my ownership as I trade before I reach 40k and 3 years max.
Running that 3.5 liter turbo v6 7500 miles between oil changes is taking its toll on your engine internals and your turbo bearings by the way.Turbos will actually glow cherry red on full boost breaking down engine oil very quickly.Pinching pennies in this case is hazardous to that expensive little engine.You should be changing at 3-5k not 7500.
I am not a diesel head as you call it.But until they make a F 150 that has a 8ft box for my 2 up Atv and a payload of 3000 lbs plus to safely haul my Airstream along with my gear I will stick to my F350 6.7.
I can afford the extra $39 for a oil change every 3-5k.
Old 02-04-2015, 06:41 PM   #49
r carl's Avatar
Lin , Ne
I always wondered why people think they should change their oil at 3-5k. In Europe 12k is normal.
Old 02-04-2015, 07:31 PM   #50
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have stuck with a 5,000 mile oil change interval for many years.
Our new Toyota Avalon has 0w20 oil and a 10,000 mile oil change interval, but the tire rotation interval is 5,000 miles. I have been rotating tires every 10,000 miles for many years on every vehicle except the tow vehicle. I rotate the tires every 5,000 miles on the tow vehicle due to the tongue weight of the Airstream.
I will stick with the 10,000 mile oil change and 5,000 mile tire rotation on our new Toyota Avalon because it has synthetic oil and Michelin tires.
I once got 130,000 miles out of a set of Michelins on a Chevy Express van.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 02-04-2015, 09:34 PM   #51
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My dodge with 6.7 takes 3 gallon of oil ,which costs $40 and a $7 Baldwin filter, fuel filter is $30 ,which I change every fall , oil is changed every 4500 to 5000 miles and we got 85000 miles with no problems, no town driving or idling , 12mpg average to either coast, there is no such thing as too much horsepower or money.....
Old 02-04-2015, 09:57 PM   #52
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, if I said it once, I said it a thousand times; OK, only a few times. If you have a huge load and / or want a diesel then buy one, but don't try to justify it on cost.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 02-04-2015, 10:01 PM   #53
Moflash's Avatar
Where did that come from???
Old 02-04-2015, 10:46 PM   #54
Mission Viejo , California
We are in the last days of the internal combustion engine.
They have pretty much perfected them. The Ford Eco Boost is a great setup and was proved by a million mile torture test before they sold the first one.
In a generation from now they will be laughing their butts off at gas or diesel engines. It will be as foreign to them as a Stanley Steamer was to our parents.
Who knows? Maybe the Baker Electric will,be back
Bill Lynch is offline   Reply With Quote
Old 02-05-2015, 04:15 AM   #55
Storm Master
Ampman's Avatar
2005 25' Classic
The future of truck engines will be interesting. The last generation would freak out if they could have the tech and power of the engines standard today. Hah, you had to have a big block gas engine with several after market mods to get anything near the power of what's available now. Fuel injection? That was like super exotic and only found on sports cars. Try and find a mechanic that is good with a carburetor now a days. And at best they would only get 8 mpg. Good times for every body, diesel and gas fans. The only thing I miss is being able to work on the new stuff and fix/rebuild myself.
Old 02-05-2015, 05:34 AM   #56
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
If you look out on to the highways you see all them big trucks, they used to be gas jobs , now they are diesel, why is that? The Europeans even burn more diesel than gas...the big ships are transporting diesel from the east coast to Europe and bring gasoline back...
NorCal : 2015 Jackson Rancheria Fally Rally October 9-11, 2015 Coastalview Forum Rallies & Meet Ups 48 05-30-2017 01:49 PM
2015 F-250 6.2 vs 6.7 keith49090 Tow Vehicles 71 02-16-2015 07:21 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
250 MH :: 1990 Airstream 250 barend Airstream Registry Discussions 0 08-19-2011 08:32 AM
