Old 11-16-2007, 09:53 PM   #1
1978 31' Excella 500
Etobicooke , Ontario
Question Need some advice on tow vehicle capacity
Hello all fellow AS's, i am new owner of 76 excella 500 31'. I had the trailer delivered to me intially but at the price of delivery i figure i had best find out what equipment i will need to tow this beauty. I will be towing it approx. 500 kms first off and parking it at my woodlot where it will stay. I have an 88 Ford Bronco to use for this. Could you give me your suggestions. thanks
newbullet is offline   Reply With Quote
Old 11-16-2007, 10:03 PM   #2
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
Bronco?
I don't think I would pull that trailer with a bronco. Just me though.
I have a 31 ft trailer w/ dry weight 6,800lbs. It seems risky to me.
The narrow wheel base on your bronco is a big issue for me.
I pulled ours with a 86 Grand Wagoneer for the first few trips and
the trailer pushed me more than I pulled it.
BTW...Do you have working brakes?
Wayne
wayne.yl is offline   Reply With Quote
Old 11-16-2007, 10:10 PM   #3
Towing a 31 foot Airstream with a Bronco, is like making an appointment with a junk yard for the Airstream, and reservations at a hospital for you and your passengers.
That set up is unsafe even at 20 mph.
Old 11-16-2007, 10:22 PM   #4
Appreciate your quick comments. So it looks like im off to budget for a rental then.
Old 11-17-2007, 05:58 AM   #5
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Newbullet
Welcome
You are a fast learner. Smart move to Budget for a rental. Something at least in the 3/4 ton range. A good Reese Strait-Line hitch setup should do the job.
We would talk to you than read about you.
Roger
Mikethefixit is offline   Reply With Quote
Old 11-17-2007, 06:35 AM   #6
1976 25' Caravanner
Campton , New Hampshire
Is this the full size Bronco or the Bronco II ? The full size can do it with a WD hitch but the set up for one pull would not be economical unless you can borrow one . Best bet is a friend with an RV that has a good tow vehicle . Good luck
ticki2 is offline   Reply With Quote
Passenger van as tow vehicle? DanielB Tow Vehicles 51 05-30-2011 11:02 PM
Tow Vehicle, new-vs-used??? batman Tow Vehicles 26 02-10-2011 10:51 AM
tow vehicle too heavy? Beverly II Tow Vehicles 40 01-31-2011 04:21 PM
New Tow Vehicle - 2010 Dodge 2500 sgray Tow Vehicles 13 01-11-2011 07:41 AM
