Old 09-16-2007, 05:57 AM   #1
Davis's Avatar
1996 34' Excella
Americus , Georgia
Need info on 2500 Suburban w/8.1 eng.
I am looking at a 2004 Chevrolet Suburban 2500 4X4 with the 8.1 engine and 41,000 miles on it. I have read some posts on here about the 8.1`s using oil, which year models were affected or is it all 8.1`s. Does the oil consumption decrease the longevity of the engine ? ALso is there any issues with the 4 wheel drive componets for these vehicles ? Any other tips would be appreciated. Thanks Davis
1991 Airstream Excella 1000 34ft (SOLD)
1994 Chevrolet Crew Cab dually 2WD 6.5td
2005 Chevrolet Suburban LT 1500 2WD 5.3
WBCCI # 10219 Georgia Unit
AIR # 5131
Davis is offline   Reply With Quote
Old 09-16-2007, 06:22 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The 4x4 components are usually very reliable, on a par with the other manufacturers' stuff. As far as the oil consumption, it won't adversely effect the lifespan of the engine, unless, of course, you run it out of oil. If that happens the engine's lifespan reaches zero very quickly. The 8.1 does have a reputation of being a "noisy" motor. If it has low miles on it, and doesn't make any noises, start using Mobil1 or comparable lube oil in it, and change it regularly.
Old 09-16-2007, 11:47 AM   #3
Davis's Avatar
1996 34' Excella
Americus , Georgia
Thanks for the reply. Davis
AIR # 5131
Old 09-16-2007, 11:50 AM   #4
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
I have the 8.1 in my Avalanche and love it - yes it is very chattery when you first start up - and I do use a quart or so between oil changes - thats been the way since new, but have had zero problem with the motor - gets about 16-17 on highways, which I think is great and have almost 80,000 on it - and yes I do use Mobil 1
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 09-16-2007, 01:02 PM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I have the 8.1 in an '01 2500hd and have had zero problems with the engine at 68,000 miles. I have heard that some early 8.1's had problems with excessive oil consumption, around a qt. per 1,000 miles and they went to a PCV valve with a smaller hole in the PCV body. I'd say that 1 qt. per 3-4,000 miles is about average. There are also a few TSB's out on the 8.1 and one of them was concerning the manifold bolts working loose and another was the manifold gasket. Neither problem has surfaced with my 8.1 so I am happy.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-16-2007, 04:45 PM   #6
Davis's Avatar
1996 34' Excella
Americus , Georgia
Thanks ya`ll for the info. I think this will make a great vehicle to tow my 34ft trailer with. I had pondered over the 6.0 liter engine but this one came along and seems like it has been taken care of although I wish it had the towing mirrors but I can add those if I buy it.Thanks Davis
AIR # 5131
Old 09-16-2007, 05:50 PM   #7
Ken J, On your Avalanche, what gear ratio do you have that you get that kind of mileage, did you do any other modifications? Just curious.
dano is offline   Reply With Quote
Old 09-16-2007, 05:55 PM   #8
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
1954 22' Flying Cloud
Brussels , Wisconsin
I have the 8.1 in my 04 2500 Suburban and use no oil between changes. (71 K on it) I have had a problem with "vapor lock" when using an ethanol blend and the temps get into the 90's. I have to let it cool and then all is good. If I stay away from ethanol blends it seems to be fine.
Ed
Ed Emerick is offline   Reply With Quote
Old 11-11-2007, 11:27 PM   #9
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
8.1 using oil
Craig,
I am using an average of 1 quart oil per 800-900 miles.
Is this something I just have to live with?
Wayne
wayne.yl is offline   Reply With Quote
Old 11-12-2007, 03:38 AM   #10
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Originally Posted by wayne.yl
Craig,
Wayne
that seems like a lot... unless you're towing...
my burb has the 496, and it burns through a quart every 1000 miles, when i'm towing the a/s
not towing... about a quart every 4-5k miles (oil change)
using 5w-30 (recommended)
blend
boondockdad is offline   Reply With Quote
Old 11-12-2007, 04:03 AM   #11
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The big block gasoline motors of the 1960's, 70's and 80's burned oil at 300-500 miles/quart new and it was considered normal, especially towing; plenty of them lasted well beyond 100 even 200,000 miles. I see nothing above that would cause me concern. I'd have oil analysis done by DYSON ANALYSIS, and use Terry's recommendations to keep it in great shape.
I think it'd be a very nice vehicle to have.
Old 11-12-2007, 08:23 AM   #12
starflyte1's Avatar
2007 25' Safari FB SE
Lady Lake , Florida
Did Davis buy the Avalanche?
IWe have an '05 Avalanche, 8.1 2500 that we have pulled an AS 18,000 miles this year and have used no oil. My husband only has Havoline 10W30 in it now. In the beginning, he used other brands of oil, but had to ad quarts to them.
We are very happy with the Avalanche and Havoline. Always enough power and very comfortable. We towed a 23' Safari 9,000 miles and the other 9,000 miles was a 25' Safari.
Pat
AIR# 16756
WBCCI# 6167
starflyte1 is offline   Reply With Quote
Old 11-14-2007, 02:13 PM   #13
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
using oil
Fellas,
Thanks for the comments and advice.
I will do the oil analysis and see what it says.
I will let you know.
Wayne
Old 11-14-2007, 02:17 PM   #14
2007 25' Classic
Hydes
I had a 2001` 2500 4x4 Suburban with the 8.1 L engine and I wish I still had it. Fantastic motor and mine didn't have any of the piston slap that others complain of and didn't seem to use oil. To bad they no longer offer this engine in the Suburban.
craftsman is offline   Reply With Quote
suburban 2500 LT and 28' int ccd cchapman Tow Vehicles 41 04-23-2007 06:07 PM
Suburban 2500 springs George Jr. Tow Vehicles 9 07-22-2005 10:59 AM
Suburban/Yukon XL 2500 6.0 mpg Davis Tow Vehicles 56 07-11-2005 11:12 PM
2004 2500 Suburban w/Q-steer vajeep Tow Vehicles 18 07-05-2005 09:01 PM
Info Request from Suburban Owners MileHigh On The Road... 32 01-28-2004 06:16 PM
