Old 04-21-2013, 11:52 AM   #1
Eylon's Avatar
1988 34' Limited
All Over The USA.. , USA
Images: 11
Need Help with wiring...
I just got a 2011 Ram 3500 diesel with factory towing package (integrated brake controller). when i plug my 34' 1988 Airsream limited the Brake and blinkers lights work but the Driving lights doesn't???
I added a Fuse that was missing on the truck ("Trailer lights") but i still cant get the driving lights on the trailer to turn on.
Anyone has any ideas??
Thank's
Ed
Marylou & Ed Porat
1988 Airstream Limited 34'
"At the Lord’s command they encamped, and at the Lord’s command they set out".
Eylon is offline   Reply With Quote
Old 04-21-2013, 12:09 PM   #2
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Confirm that you are receiving power on the truck side of the 7 pin connector. If yes, check at the 12 volt panel in the trailer and check the fuse at the panel. If this is ok, start checking for power at your lights. Check the bulbs and the grounds. If you are not getting power to the panel, check the trailer side of the 7 pin connector. That's all I have.
Jim Flower is offline   Reply With Quote
