Old 11-18-2009, 05:07 PM   #1
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Need help fixing E150 door handle
Our TV is a 95 Ford E150 Club Wagon, and on the side it has two doors that open out (as opposed to the ones with the sliding door on the side). The forward door has the handle, and once you open it you can open the rearward door. On that forward door the exterior door handle no longer works. I determined the cable has stretched, and I put a spacer in there which worked for a year or so, but it has stretched more and that no longer works.
I can get a replacement cable for about $30, but I don't know how to access it to install. Is the work done from entirely inside the door, or do I need to take off the door handle to access it? If I need to remove the door handle, it looks like there is a special tool required.
Does anyone have access to a repair manual for the 95 or newer E150? I believe the assembly is the same from 95 through current models. If anyone could give me the step by step, or scan any blow apart diagrams it would be helpful.
Stephanie
Old 11-18-2009, 05:19 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
A shot in the dark but this might help. WikiAnswers - How do you take apart passenger door Ford E150 Conversion Van Have fabric off can't get to door handle to fix Won't open from outside
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-18-2009, 06:47 PM   #3
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Dang, so close, but not enough detail. Thanks for trying though.
Stephanie
Old 11-18-2009, 08:42 PM   #4
_
stef
there are sites that SELL a downloadable version of the ford/tech manual...
and the haynes ford manual for e150s will have good schematics for the door assembly.
while u can buy a NEW copy, it's also available used and SOME sites have complete pages of the manual online free.
or run by the largest auto parts store and peel the plastic OFF a new copy and read it really fast...
cheers
2air'
Old 11-19-2009, 01:14 AM   #5
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
I can't find a Haynes manual for it on Amazon, but maybe I'll go hit the library tomorrow and see if I can find one there.
Edit: I found it on Amazon, but it's not a 'look inside' book. I'll have to hunt down one to see in person and confirm it has what I need in it.
Stephanie
Old 11-19-2009, 04:30 AM   #6
richinny's Avatar
2011 34' Classic
i don't know how much room you have in there but this might work. you can go into most auto parts stores to look at it.
NAPAONLINE®
an alternative might be to push the center of the cable through a washer and put a pin in the loop. experience tells me that if this continues long enough. the cable will stop stretching and become two shorter cables :-(
Ricky
Old 11-19-2009, 07:14 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That is the same phenomenon that causes electronic components to stop working when the factory-installed smoke container is opened.
Old 01-29-2010, 03:45 PM   #8
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
I have the part, I have the door apart. I can see how to install the lower end of the cable which goes to the door handle. The upper end goes into the latch mechanism, and it is not visible from the cutouts on the inside of the door. I am tempted to grab a hole saw and make an extra little cut out in a strategic location.
Just thought I'd ask again here and see if anyone has a shop manual for a late model E150 and might be able to give me a clue on the order of operations for this repair.
Stephanie
Old 01-29-2010, 03:51 PM   #9
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
hey steph i am in battle ground and I have a manual for a 94 as well as a 2007 e series. you are of course welcome to use them
ol bill
wmarsha is offline   Reply With Quote
Old 01-29-2010, 03:53 PM   #10
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Thanks, Bill, that would be perfect! I'll give you a call this afternoon.
Stephanie
ford van, e-150
Fixing broken fridge door shelves Zeppelinium Refrigerators 10 06-10-2016 06:48 PM
Door Handle - Replacement for 1981 Excella dienst1 General Motorhome Topics 44 10-08-2011 10:36 PM
Looking for door handle- help please old man listening Doors & Locks 10 02-13-2010 12:49 PM
door handle T&Cairstream Doors & Locks 2 12-11-2007 10:58 AM
