Old 09-04-2007, 02:11 PM   #1
Davis's Avatar
1996 34' Excella
Americus , Georgia
Need Help Choosing tires for 04 Suburban
I have a 2004 Suburban that has P265/70R/17 tires on it and would like to upgrade to a tire with a load range D or E rating. Would there be any problems doing that since this has aluminum wheels and I have the electronic air pressure sensors on this Suburban also. Just want to make sure that the wheels won`t crack for any reason or have any other catastrophe by getting a heavier duty tire. I had thought about using a Michelin LTX A/S LR E tire. Thanks Davis
1991 Airstream Excella 1000 34ft (SOLD)
1994 Chevrolet Crew Cab dually 2WD 6.5td
2005 Chevrolet Suburban LT 1500 2WD 5.3
WBCCI # 10219 Georgia Unit
AIR # 5131
Davis is offline   Reply With Quote
Old 09-04-2007, 04:06 PM   #2
bobkelly's Avatar
2003 22' International CCD
Whittier, California , Depoe Bay, Oregon
Davis----The pressure sensors work independently of the tire load rating. I'd double check with your tire shop on your wheel strength if you intend to inflate to max load rating pressure with the LR E
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Old 09-04-2007, 06:56 PM   #3
Davis's Avatar
1996 34' Excella
Americus , Georgia
Thanks Bob.
AIR # 5131
Old 09-04-2007, 07:11 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
"e" Tires & Alloy Wheels
Have E rated on our Burb, keep them at 80-85 psi depending on load, my past experience tells me that some of these alloy wheels are porous and might be more prone to leaks at higher pressures. Took them off our Burb,looked like hell after the third Buffalo winter, replaced with powder coated H/D steel. Iv'e heard a lot of good things on your choice of tires, go with E's....you can never be too safe
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 09-05-2007, 11:00 AM   #5
DayStreamer
grizzy's Avatar
2001 19' Bambi
Mesa , Arizona
My advice is to be careful getting the Michelins. Although I'm a great Michelin fan and have used them for years, when I upgraded to heavy load rated tires on my '02 Chevy Avalanche I first went with the Michelins. After getting stuck twice with my 4x4 truck (that has NEVER gotten stuck) I did some research and found out this is a common problem with those particular Michelin tires. They are great on the road but don't ever stray off the road. Fortunately, Discount Tire was very good about giving a full refund and replacing them with B.F. Goodrich tires.
Dave
DayStreamer
2001 19' Bambi
02 Avalanche
Mesa Arizona
AIR #5591
grizzy is offline   Reply With Quote
Old 09-05-2007, 01:55 PM   #6
Davis's Avatar
1996 34' Excella
Americus , Georgia
Thanks for the replies. I won`t be off roading any just highway for this burb. I did speak with my dealer today and they said that the wheels should be fine with the heavier duty tires but they are not sure about the tire inflation sensors. They said with the higher air pressure it could cause the on board computer to think there is a problem. They are not sure if that will happen or not.My current tires have a max. air pressure of 44 psi and the LR E tires will have a max air pressure of 70 -80 psi. Maybe someone with the sensors can chime in and share their experience as to whether the sensors will work correctly. Davis
AIR # 5131
Old 09-05-2007, 02:25 PM   #7
bobkelly's Avatar
Davis---My OEM sensors work fine to 50 psi which is the max I use for my load situation.
2003 22ft CCD Int'l
WBCCI #2960
Old 09-05-2007, 07:55 PM   #8
Davis's Avatar
1996 34' Excella
Americus , Georgia
Thanks Bob, My owners manual only lists underinflation of tires that will trigger the lights and warnings to come up. So I might be ok by using the LR E or D tires. I guess there is one to find out and that is to try it. Davis
AIR # 5131
Old 09-05-2007, 09:39 PM   #9
_
hi davis
on my second set of e rated tires, and went with a bridgestone this time...
Bridgestone Dueler A/T Revo
so far i like them but the stock goodrich were much better than i expected them to be...
BFGoodrich Rugged Trail T/A
either (or the m'ltx) will improve your towing experience....
really should weigh the whole mess but until then run 68-70 psi....
do you know which sensor is installed?
here is likely model...
TPMS Sensors
but there are others...
http://www.etools.org/files/public/T...te_from_GM.pdf
just GUESSING, yours will need to be reset/calibrated for the new tires....
my concern with e rated tires is that the valve cores be rated for the higher pressures...
Tire Tech - Servicing Direct Tire Pressure Monitoring Sensors
Tire Tech - Tire Pressure Monitoring Systems
apparently there is a tool available for resetting tpms,
http://pegisysotc.com/newcatalog/products/3833_165.pdf
but really the dealer service shop or tire shop should be right on top of this...
cheers
2air'
as 2 the wheels, so many models so little time....
stamped on the wheel backs should be info necessary to sort out the specs, this must be routine info on the ge'em forums...
they are likely rated to 90--100 psi,
but the LOAD rating may be an issue, as in less than than those e rated tires, fully inflated.
Originally Posted by Davis
...I guess there is one to find out and that is to try it. Davis
don't think it is wise to just 'try it' on this issue...
Old 09-06-2007, 06:03 PM   #10
Davis's Avatar
1996 34' Excella
Americus , Georgia
Hi Bob,
Do you have LR E tires on your Denali and if so did it change the solo ride quality ? Thanks Davis
AIR # 5131
Need help in choosing Jericho2550 2005 and newer - Bambi all models 4 06-03-2007 05:45 PM
Choosing the best Air Conditioning Unit William_Mc Furnaces, Heaters, Fireplaces & Air Conditioning 4 02-20-2007 06:25 PM
Need Help Choosing An Airstream Model rec Member Introductions 3 01-14-2007 08:56 AM
Need Help Choosing Trailer Please! tallone Member Introductions 22 01-23-2006 08:54 PM
Choosing the Right Model Airstream MH grassgd Airstream Motorhome Forums 13 01-06-2003 09:59 PM
